my tx2 board connects to tc358748, and input rgb888 mipi csi singals to tx2,
when i command:
v4l2-ctl -d /dev/video0 --set-fmt-video=width=1024,height=1024,pixelformat=AR24 --stream-mmap --stream-count=10000 --set-ctrl bypass_mode=0 --stream-to=stream.raw
it is sucessful to capture rgb888 raw data,
but when i command:
gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=BGRA,width=1024,height=1024 ! videoconvert
i got some errros as below:
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-linked (-1)
Execution ended after 0:00:00.114996848
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
my formats list is :
jetson@linux:/proc/device-tree/i2c@c240000/imx185@0e$ v4l2-ctl -d /dev/video0 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'AR24'
Name : 32-bit BGRA 8-8-8-8
Interval: Discrete 0.017s (60.000 fps)
Size: Discrete 1280x1024
Size: Discrete 1680x1050
Size: Discrete 1920x1080
Size: Discrete 1024x1024
Interval: Discrete 0.022s (45.000 fps)
Index : 1
Pixel Format: 'UYVY'
Index : 2
Pixel Format: 'NV16'
Index : 3
