Hi kulve,
I tried the pipeline you mentioned but it shows
ubuntu@tegra-ubuntu:~/Videos$ gst-launch-1.0 -v -e uridecodebin uri=file:///home/ubuntu/Videos/2160p.mp4 ! nveglglessink
Setting pipeline to PAUSED ...
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0: source = "\(GstFileSrc\)\ source"
Pipeline is PREROLLING ...
Got context from element 'eglglessink0': gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstTypeFindElement:typefind.GstPad:src: caps = video/quicktime, variant=(string)iso
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstTypeFindElement:typefind.GstPad:src: caps = NULL
Missing element: H.264 decoder
WARNING: from element /GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0: No decoder available for type 'video/x-h264, stream-format=(string)avc, alignment=(string)au, level=(string)5.1, profile=(string)high, codec_data=(buffer)01640033ffe1001a67640033acd300f0010fb0110000030001000003003c0f18313801000468cebcb0, width=(int)3840, height=(int)2160, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1'.
Additional debug info:
gsturidecodebin.c(930): unknown_type_cb (): /GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0: max-size-buffers = 5
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0: max-size-time = 0
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0: max-size-bytes = 2097152
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0.GstPad:sink_0: caps = audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)1210, rate=(int)44100, channels=(int)2
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0.GstPad:src_0: caps = audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)1210, rate=(int)44100, channels=(int)2
Missing element: MPEG-4 AAC decoder
WARNING: from element /GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0: No decoder available for type 'audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)1210, rate=(int)44100, channels=(int)2'.
ERROR: from element /GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0: Your GStreamer installation is missing a plug-in.
gstdecodebin2.c(3928): gst_decode_bin_expose (): /GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0:
no suitable plugins found
ERROR: pipeline doesn't want to preroll.
Setting pipeline to NULL ...
Caught SIGSEGV
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstAacParse:aacparse0.GstPad:src: caps = audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)1210, rate=(int)44100, channels=(int)2
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstAacParse:aacparse0.GstPad:sink: caps = audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)1210, rate=(int)44100, channels=(int)2
#0 __libc_do_syscall ()
#1 0xb6d82ec2 in pthread_join (threadid=<optimized out>, thread_return=0x0)
#2 0xb6dfc6a6 in ?? () from /lib/arm-linux-gnueabihf/libglib-2.0.so.0
Spinning. Please run 'gdb gst-launch-1.0 2727' to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
and ‘gdb gst-launch-1.0 2727’ shows that
Loaded symbols for /usr/lib/arm-linux-gnueabihf/gstreamer-1.0/libgstaudioparsers.so
__libc_do_syscall () at ../ports/sysdeps/unix/sysv/linux/arm/libc-do-syscall.S:43
43 ../ports/sysdeps/unix/sysv/linux/arm/libc-do-syscall.S: No such file or directory.
Did I miss anything? Thanks for your help!
