When I run video-viewer with:
video-viewer --input-width=640 --input-height=480 --input-flip=rotate-180 /dev/video0
the image does not flip. i tried two different USB cameras and other flip modes but it never does anything with the orientation of the image.
This is what it spits out before capturing:
gstCamera video options:
– URI: v4l2:///dev/video0
- protocol: v4l2
– deviceType: v4l2
– ioType: input
– codec: raw
– width: 640
– height: 480
– frameRate: 30.000000
– bitRate: 0
– numBuffers: 4
– zeroCopy: true
– flipMethod: rotate-180
– loop: 0
– rtspLatency 2000
[OpenGL] glDisplay – X screen 0 resolution: 1920x1080
[OpenGL] glDisplay – X window resolution: 1920x1080
[OpenGL] glDisplay – display device initialized (1920x1080)
[video] created glDisplay from display://0
glDisplay video options:
– URI: display://0
- protocol: display
– deviceType: display
– ioType: output
– codec: raw
– width: 1920
– height: 1080
– frameRate: 0.000000
– bitRate: 0
– numBuffers: 4
– zeroCopy: true
– flipMethod: none
– loop: 0
– rtspLatency 2000
[gstreamer] opening gstCamera for streaming, transitioning pipeline to GST_STATE_PLAYING
[gstreamer] gstreamer changed state from NULL to READY ==> mysink
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter0
[gstreamer] gstreamer changed state from NULL to READY ==> v4l2src0
[gstreamer] gstreamer changed state from NULL to READY ==> pipeline0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter0
[gstreamer] gstreamer stream status CREATE ==> src
[gstreamer] gstreamer changed state from READY to PAUSED ==> v4l2src0
[gstreamer] gstreamer changed state from READY to PAUSED ==> pipeline0
[gstreamer] gstreamer stream status ENTER ==> src
[gstreamer] gstreamer message new-clock ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter0
[gstreamer] gstreamer message stream-start ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> v4l2src0
video-viewer: failed to capture video frame
[gstreamer] gstCamera – onPreroll
[gstreamer] gstCamera recieve caps: video/x-raw, format=(string)YUY2, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, colorimetry=(string)2:4:5:1, interlace-mode=(string)progressive
[gstreamer] gstCamera – recieved first frame, codec=raw format=yuyv width=640 height=480 size=614400
RingBuffer – allocated 4 buffers (614400 bytes each, 2457600 bytes total)
[gstreamer] gstreamer changed state from READY to PAUSED ==> mysink
[gstreamer] gstreamer message async-done ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> mysink
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> pipeline0
RingBuffer – allocated 4 buffers (921600 bytes each, 3686400 bytes total)
video-viewer: captured 1 frames (640 x 480)
[OpenGL] glDisplay – set the window size to 640x480
[OpenGL] creating 640x480 texture (GL_RGB8 format, 921600 bytes)
[cuda] registered openGL texture for interop access (640x480, GL_RGB8, 921600 bytes)
I can’t figure out why it doesn’t work
, it seems to parse the parameter but then ignores it?
I’m running the latest image and have built jetson-inference from source a few days back.
Any ideas why it doesn’t work?
