I want to build a project to realize a video capture ,process by my code ,h264 encode and rtsp.but i happened to a problem
#include <stdio.h>
#include <opencv2/highgui/highgui.hpp>
#include <opencv2/opencv.hpp>
int main(int argc, char** argv) {
// first part of sender pipeline
cv::VideoCapture cap("v4l2src ! video/x-raw, framerate=30/1, width=640, height=480, format=RGB ! videoconvert ! appsink");
if (!cap.isOpened()) {
printf("=ERR= can't create video capture\n");
return -1;
// second part of sender pipeline
cv::VideoWriter writer;
writer.open("appsrc ! videoconvert ! x264enc noise-reduction=10000 tune=zerolatency byte-stream=true threads=4 ! mpegtsmux ! udpsink host=localhost port=9999"
, 0, (double)30, cv::Size(640, 480), true);
if (!writer.isOpened()) {
printf("=ERR= can't create video writer\n");
return -1;
cv::Mat frame;
int key;
while (true) {
cap >> frame;
if (frame.empty())
break;
/* Process the frame here */
writer << frame;
key = cv::waitKey( 30 );
i can’t open the v4l2src
Have you enabled gstreamer support when building opencv ?
You may check this thread [url]https://devtalk.nvidia.com/default/topic/1001696/jetson-tx1/failed-to-open-tx1-on-board-camera/post/5117370/#5117370[/url].
Furthermore, this should not be your case, but I remember some people faced problems with pipelines in VideoWriter, where just adding a space at the end of the string was a workaround. But I think this was related to IP address in pipeline having dots, and it was then processed as a file name with extension.
hi Honey_Patouceul
Thank you for your guidance!The code is just for testing.When I test it, I met a problem as you said:
OpenCV Error: Unsupported format or combination of formats (Gstreamer Opencv backend doesn’t support this codec acutally.) in CvVideoWriter_GStreamer::open, file /home/ubuntu/opencv-2.4.9/modules/highgui/src/cap_gstreamer.cpp, line 505
terminate called after throwing an instance of ‘cv::Exception’
what(): /home/ubuntu/opencv-2.4.9/modules/highgui/src/cap_gstreamer.cpp:505: error: (-210) Gstreamer Opencv backend doesn’t support this codec acutally. in function CvVideoWriter_GStreamer::open
Aborted
Do you know how to solve it?
Thank you in advance.
The problem seems in writer.
I would advise to build and install your own opencv-3.2.0 lib enabling gstreamer-1.0 support and use it instead of 2.4.9.
If you have a lot of sources tied to opencv2 API, you can rather try building 2.4.13 enabling gstreamer-1.0 support.
