I am pretty much new to VisionWorks on TX2. I have written a class for Houghline detection using graph nodes of visionworks with help of the hough transform class. only diffrence between my class and sample program is that the image data is passed via OpenCV and it’s a single channel gray image.
So the issue i have is:
- the performance of my class is very slow (~60-80ms) per frame compared to sample (~1-3ms).
- Results are not correct.
it will be really helpful if someone could help me in understanding and point out the mistakes am doing.
I have also went through the samples in details and observed that if disable canny node then algorithm will be slow even if the input is single channel U8 input but if i enable canny node then performance is super fast. am very much puzzled here.
Below is my class which i have written. Thanks in advance.
#include <cmath>
#include <iostream>
#include <sstream>
#include <iomanip>
#include <string>
#include <memory>
#include <NVX/nvx.h>
#include <NVX/nvx_timer.hpp>
#include <NVX/Application.hpp>
#include "NVX/nvx_opencv_interop.hpp"
#include <NVX/ConfigParser.hpp>
#include <OVX/FrameSourceOVX.hpp>
#include <OVX/RenderOVX.hpp>
#include <NVX/SyncTimer.hpp>
#include <OVX/UtilityOVX.hpp>
// Utility
struct HoughTransformParams
public:
vx_float32 scaleFactor;
vx_enum scaleType;
vx_float32 rho;
vx_float32 theta;
vx_uint32 Threshold;
vx_uint32 minLineLength;
vx_uint32 maxLineGap;
vx_uint32 linesCapacity;
HoughTransformParams()
scaleFactor = (.5f);
scaleType = (VX_INTERPOLATION_TYPE_BILINEAR);
rho = (1.f);
theta=(1.f);
Threshold=(100);
minLineLength=(10);
maxLineGap=(5);
linesCapacity=(300);
class nvxHoughLineLaneDetect
public:
HoughTransformParams params;
ovxio::ContextGuard context;
vx_image m_nvxframe;
vx_uint32 m_nvxImgHeight,m_nvxImgWidth;
vx_array m_nvxLines;
vx_graph m_nvxGraph;
vx_node m_HoughSegmentsNode;
int m_nvxErrorStatus;
double m_proc_ms;
nvx::Timer procTimer;
//nvxHoughLineLaneDetect()
//vxDirective(context, VX_DIRECTIVE_ENABLE_PERFORMANCE);
try
cout<< "graph intialisation"<<endl;
m_nvxImgHeight = 720;
m_nvxImgWidth = 1280;
params.theta *= ovxio::PI_F / 180.0f; // convert to radians
// Messages generated by the OpenVX framework will be given
// to ovxio::stdoutLogCallback
vxRegisterLogCallback(context, &ovxio::stdoutLogCallback, vx_false_e);
if ((m_nvxImgWidth * params.scaleFactor < 16) ||
(m_nvxImgHeight * params.scaleFactor < 16))
std::cerr << "Error: Scale factor is too small" << std::endl;
m_nvxframe = vxCreateImage(context,m_nvxImgWidth, m_nvxImgHeight, VX_DF_IMAGE_U8);
NVXIO_CHECK_REFERENCE(m_nvxframe);
// Similary the lines vx_array objects are created to hold
// the output from Hough line-segment detector
m_nvxLines = vxCreateArray(context, NVX_TYPE_POINT4F, params.linesCapacity);
NVXIO_CHECK_REFERENCE(m_nvxLines);
// vxCreateGraph() instantiates the pipeline
m_nvxGraph = vxCreateGraph(context);
NVXIO_CHECK_REFERENCE(m_nvxGraph);
m_HoughSegmentsNode = nvxHoughSegmentsNode(m_nvxGraph, m_nvxframe,m_nvxLines, params.rho, params.theta,params.Threshold, params.minLineLength,params.maxLineGap, nullptr);
NVXIO_CHECK_REFERENCE(m_HoughSegmentsNode);
// Ensure highest graph optimization level
const char* option = "-O3";
NVXIO_SAFE_CALL( vxSetGraphAttribute(m_nvxGraph, NVX_GRAPH_VERIFY_OPTIONS, option, strlen(option)) );
// Verify the graph
vx_status verify_status = vxVerifyGraph(m_nvxGraph);
if (verify_status != VX_SUCCESS)
std::cerr << "Error: Graph verification failed. See the NVX LOG for explanation." << std::endl;
m_nvxErrorStatus = nvxio::Application::APP_EXIT_CODE_INVALID_GRAPH;
catch (const std::exception& e)
std::cerr << "Initialistion Error: " << e.what() << std::endl;
m_nvxErrorStatus = nvxio::Application::APP_EXIT_CODE_ERROR;
~nvxHoughLineLaneDetect()
try
cout<<"graph deletion\n";
vxReleaseNode(&m_HoughSegmentsNode);
vxReleaseGraph(&m_nvxGraph);
vxReleaseImage(&m_nvxframe);
vxReleaseArray(&m_nvxLines);
std::cerr << "Delettion Error: " << e.what() << std::endl;
void runNVXHoughLine(Mat &img,std::vector<cv::Vec4i> &lines,int &thresh)
try
cout<<"Running module\n";
//OpenCV Mat to vx_image conversion
m_nvxframe = nvx_cv::createVXImageFromCVMat(context, img);
procTimer.tic();
NVXIO_SAFE_CALL( vxProcessGraph(m_nvxGraph) );
m_proc_ms = procTimer.toc();
cout<<"NVX Hough time = "<<m_proc_ms<<" ms\n";
vx_size lines_count = 0;
NVXIO_SAFE_CALL( vxQueryArray(m_nvxLines, VX_ARRAY_ATTRIBUTE_NUMITEMS, &lines_count, sizeof(lines_count)) );
std::cout << "Found " << lines_count << " lines" << std::endl;
if (lines_count > 0)
vx_map_id map_id;
vx_size stride;
void *ptr;
NVXIO_SAFE_CALL( vxMapArrayRange(m_nvxLines, 0, lines_count, &map_id, &stride, &ptr, VX_READ_AND_WRITE, VX_MEMORY_TYPE_HOST, 0) );
for (vx_size i = 0; i < lines_count; ++i)
nvx_point4f_t *coord = (nvx_point4f_t *)vxFormatArrayPointer(ptr, i, stride);
cv::Vec4i temp = cv::Vec4i(coord->x,coord->y,coord->z,coord->w);
lines.push_back(temp);
NVXIO_SAFE_CALL( vxUnmapArrayRange(m_nvxLines, map_id) );
std::cerr << "Processing Error: " << e.what() << std::endl;
