QEMU with virgl GPU acceleration works fine with driver version 535. However, newer driver version appears to introduce visual corruption regression to this usage scenario.
People reported this issue at the virgl issue tracker:
Now that I confirm the issue is a regression in recent driver release, it should be a better idea to discuss it here.
The environment where I run into this issue:
- Qemu 9.2.1/10.0
- Guest: Debian 12 liveCD / BlissOS liveCD (more visible in the later)
- virglrenderer 1.1.0
- Driver version 570.133.2 (actually I suspect 535 is the last known good version)
I used the following command line to launch the QEMU VM (for unknown reason, the last two knobs matters)
qemu-system-x86_64 -enable-kvm -M q35 -m 6000 -smp 3 -cpu host -bios /usr/share/ovmf/OVMF.fd -drive file=blissos.img,format=raw,if=virtio -audio pa,model=virtio -device virtio-tablet -device virtio-keyboard -device qemu-xhci,id=xhci -machine vmport=off -device virtio-vga-gl -display sdl,gl=on -net nic,model=virtio-net-pci -net user,hostfwd=tcp::4444-:5555 -parallel none -serial none
