VK_EXT_descriptor_heap driver shader compilation error
I am using the new extension “VK_EXT_descriptor_heap”.
Driver version: 595.58.03
When I am loading data from SSBO using certain types, my GPU freezes and crashes vulkan.
But if I load the data using vec4 then the the shader works normally.
This crashes.
struct Model
    mat4 model_matrix;
layout(descriptor_heap, std430) readonly buffer Model_Buffer
    Model models[];
} model_data[];
// crashes
mat4 model_matrix = model_data[MODEL_DATA_INDEX].models[gl_DrawID].model_matrix;
This works.
struct Model
    vec4 model_matrix0;
    vec4 model_matrix1;
    vec4 model_matrix2;
    vec4 model_matrix3;
    Model models[];
} model_data[];
vec4 model_matrix0 = model_data[MODEL_DATA_INDEX].models[gl_DrawID].model_matrix0;
vec4 model_matrix1 = model_data[MODEL_DATA_INDEX].models[gl_DrawID].model_matrix1;
vec4 model_matrix2 = model_data[MODEL_DATA_INDEX].models[gl_DrawID].model_matrix2;
vec4 model_matrix3 = model_data[MODEL_DATA_INDEX].models[gl_DrawID].model_matrix3;
mat4 model_matrix = mat4(model_matrix0, model_matrix1, model_matrix2, model_matrix3);
When I enable NVIDIA Aftermath I get
error   : Undefined reference to 'nv.glv.untypedaccesschain._p1_i8._p1_i83' in '<input>'
error   : Undefined reference to 'nv.glv.resourceheapaccesschain._p1_i8._p4_p1_i8' in '<input>'
NVVM compilation failed: 3
