VLC error when running python rtsp app
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 5.0.0
• TensorRT Version 7.1
• Issue Type( questions, new requirements, bugs) questions
list all deepstream version with deepstream-app --version-all
deepstream-app version 5.0.0
DeepStreamSDK 5.0.0
CUDA Driver Version: 11.0
CUDA Runtime Version: 10.2
TensorRT Version: 7.1
cuDNN Version: 8.0
libNVWarp360 Version: 2.0.1d3
when I run python3 deepstream_test1_rtsp_out.py -i '/opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_720p.h264'
it shows below, I guess the app is running now.
python3 deepstream_test1_rtsp_out.py -i ‘/opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_720p.h264’
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Creating H264 Encoder
Creating H264 rtppay
Playing file /opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_720p.h264
Adding elements to Pipeline
Linking elements in the Pipeline
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8554/ds-test ***
Starting pipeline
ERROR: …/nvdsinfer/nvdsinfer_func_utils.cpp:33 [TRT]: coreReadArchive.cpp (38) - Serialization Error in verifyHeader: 0 (Version tag does not match)
ERROR: …/nvdsinfer/nvdsinfer_func_utils.cpp:33 [TRT]: INVALID_STATE: std::exception
ERROR: …/nvdsinfer/nvdsinfer_func_utils.cpp:33 [TRT]: INVALID_CONFIG: Deserialize the cuda engine failed.
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:1567 Deserialize engine failed from file: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
0:00:00.772046786 13536 0x2f36520 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1690> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed
0:00:00.772078980 13536 0x2f36520 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1797> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed, try rebuild
0:00:00.772090166 13536 0x2f36520 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 1]: Trying to create engine from model files
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Reading Calibration Cache for calibrator: EntropyCalibration2
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Generated calibration scales using calibration cache. Make sure that calibration cache has latest scales.
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: To regenerate calibration cache, please delete the existing one. TensorRT will generate a new calibration cache.
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Detected 1 inputs and 2 output network tensors.
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:1495 Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine opened error
0:00:16.619379778 13536 0x2f36520 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1743> [UID = 1]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:16.623874617 13536 0x2f36520 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 1]: Load new model:dstest1_pgie_config.txt sucessfully
Frame Number=0 Number of Objects=6 Vehicle_count=4 Person_count=2
Frame Number=1 Number of Objects=6 Vehicle_count=4 Person_count=2
Frame Number=2 Number of Objects=6 Vehicle_count=4 Person_count=2
Frame Number=3 Number of Objects=6 Vehicle_count=4 Person_count=2
Frame Number=4 Number of Objects=7 Vehicle_count=5 Person_count=2
Frame Number=5 Number of Objects=7 Vehicle_count=5 Person_count=2
Frame Number=6 Number of Objects=6 Vehicle_count=4 Person_count=2
But at the sametime when I try to open RTSP streaming in VLC as suggested rtsp://localhost:8554/ds-test, VLC output > Your input can’t be opened:
VLC is unable to open the MRL 'rtsp://localhost:8554/ds-test'. Check the log for details.
Anything else need to be done for configuring VLC?
Best regards,
The uri is correct if you use vlc in the same device with deepstream.
