nvidia-bug-report.log.gz (140.8 KB)
Hi, I’ve noticed the nvenc powered transcoding now fails in my self-hosted media server (jellyfin running within docker on Ubuntu 22.04 LTS running inside vmware). I assume some update wrecked my setup, as it was working fine not long ago.
During initial setup I used nvidia-drivers-515.
So far I’ve tried uninstalling/purging then reinstalling all nvidia and libnvidia packages, both 515 and 525 versions (never used “-open” drivers).
apt remove --purge '^nvidia-.‘*
apt remove --purge '^libnvidia-.’*
apt install nvidia-driver-525
Tried setting kenel parameter: nvidia.NVreg_OpenRmEnableUnsupportedGpus=1
sudo vi /etc/modprobe.d/nvidia.conf
options nvidia NVreg_OpenRmEnableUnsupportedGpus=1
sudo update-initramfs -u
Tried blacklisting nouveau
sudo vi /etc/modprobe.d/blacklist-nvidia-nouveau.conf
blacklist nouveau
options nouveau modeset=0
sudo lspci -d “10de:*” -v -xxx
03:00.0 VGA compatible controller: NVIDIA Corporation GP107GL [Quadro P600] (rev a1) (prog-if 00 [VGA controller])
DeviceName: pciPassthru0
Subsystem: NVIDIA Corporation GP107GL [Quadro P600]
Physical Slot: 160
Flags: bus master, fast devsel, latency 64, IRQ 18
Memory at fc000000 (32-bit, non-prefetchable) [size=16M]
Memory at d0000000 (64-bit, prefetchable) [size=256M]
Memory at e4000000 (64-bit, prefetchable) [size=32M]
I/O ports at 4000 [size=128]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [128] Power Budgeting <?> Capabilities: [420] Advanced Error Reporting Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900] Secondary PCI Express
Kernel driver in use: nvidia
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
systemctl status nvidia-persistenced.service
● nvidia-persistenced.service - NVIDIA Persistence Daemon
Loaded: loaded (/lib/systemd/system/nvidia-persistenced.service; static)
Active: active (running) since Sun 2023-04-09 22:48:25 CEST; 7min ago
Process: 834 ExecStart=/usr/bin/nvidia-persistenced --user nvidia-persistenced --no-persistence-mode --verbose (code=exited, status=0/SUCCESS)
Main PID: 835 (nvidia-persiste)
Tasks: 1 (limit: 4466)
Memory: 804.0K
CPU: 3ms
CGroup: /system.slice/nvidia-persistenced.service
└─835 /usr/bin/nvidia-persistenced --user nvidia-persistenced --no-persistence-mode --verbose
sudo nvidia-smi
No devices were found
Can somebody point out what am I missing?
