Looking to implement a POC using VMWare as the hypervisor and XenAPP and a single K2 card. The users will be architects using autoCAD. Since VMware only currently support vDGA and vSGA. We are looking to implement vDGA first a shared desktop. If that fails looking at dedicated desktops. I have the following questions:
1 - Will autoCAD work with this configuration.
2 - What are specific recommendation or where can I find them running it in this configuration
3 - What is the minimum hardware requirements? Do you know any company that will loan the cards for a POC.
4 - What are the gotchas for such a deployment?
5 - Should I rather be looking at Xenserver for vGPU pass through? The reason I want to use VMware as our current hosts are on VMware. As this is a POC and I need it signed off and spend as little as possible. If successful will purchase new hardware.
