I recently purchased a Dell T630 Server with the following specs to add to our citrix farm as an AutoCAD server.
(2) Intel Xeon E5-2660 v3 2.6GHz,25M Cache,9.60GT/s QPI,Turbo,HT,10C/20T
96 GB RAM
NVIDIA GRID K2A GPU
(4) 400GB Solid State Read / Write Drives - Configured to a RAID 10 set
I loaded ESXi onto the T630 box
Loaded the NVIDIA .vib drivers and ran the tests to verify, everything looked good
In advanced settings I added the GRID for passthrough
I then created a Windows 2008 R2 Virtual machine w/all updated drivers - Loaded CITRIX XenApp on it and also installed AutoCAD IDS Suite
My problem now is, when I run AutoCAD via CITRIX the program is not seeing the GRID card. I am unable to turn on Hardware acceleration because of this.
Can anybody help me setup / configure this GRID card so it works properly in CITRIX & AutoCAD?
From what I can tell everything is setup correctly but it’s obviously not working correctly.
Thank You
