VPI - DCF Tracker error
Hello!
I’m trying to use DCF tracker in combination with an object detector for object tracking.
I always receive an error (VPIStatus 2, i.e. VPI_ERROR_INVALID_ARGUMENT) during the Update and Localize stage as soon as I have at least one tracked object.
I have checked that all the inputs are correct according to what is mentioned in the docs, i.e.
 * @retval #VPI_ERROR_INVALID_ARGUMENT     \p stream is NULL.
 * @retval #VPI_ERROR_INVALID_ARGUMENT     \p inPatches or trackedObjects are NULL.
 * @retval #VPI_ERROR_INVALID_ARGUMENT     \p payload not created by vpiCreateDCFTracker.
 * @retval #VPI_ERROR_INVALID_ARGUMENT     \p inPatches dimensions outside valid range.
 * @retval #VPI_ERROR_INVALID_ARGUMENT     Unsupported array type in \p trackedObjects.
 * @retval #VPI_ERROR_INVALID_ARGUMENT     Parameter(s) in \p params outside valid range.
however, the inputs seem to be normal.
Here is the snippet of my code:
initialization:
VPI_CHECK(vpiCreateCropScaler(VPI_BACKEND_CUDA, 1, max_det, &cropPayload));
VPIDCFTrackerCreationParams dcfTrackerCreateParams;
VPI_CHECK(vpiInitDCFTrackerCreationParams(&dcfTrackerCreateParams));
VPI_CHECK(vpiCreateDCFTracker(VPI_BACKEND_CUDA, 1, max_det, &dcfTrackerCreateParams, &dcfPayload));
VPI_CHECK(vpiInitDCFTrackerParams(&dcfTrackerParams));
VPI_CHECK(vpiArrayCreate(max_det, VPI_ARRAY_TYPE_DCF_TRACKED_BOUNDING_BOX, VPI_BACKEND_CUDA|VPI_BACKEND_CPU, &trackedObjects));
VPI_CHECK(vpiArrayCreate(max_det, VPI_ARRAY_TYPE_F32, VPI_BACKEND_CUDA|VPI_BACKEND_CPU, &trackedObjectsCorrelationResponses));
patchH = patchW = dcfTrackerCreateParams.featurePatchSize * dcfTrackerCreateParams.hogCellSize;
VPI_CHECK(vpiImageCreate(patchW,
							 patchH * max_det,
							 VPI_IMAGE_FORMAT_RGBA8,
							 VPI_BACKEND_CUDA,
							 &objPatches));
loop:
VPIImage vpiImg; // U8
VPI_CHECK(vpiImageCreateWrapperOpenCVMat(cvImg, VPI_BACKEND_CUDA, &vpiImg));
VPIImage vpiImgRGBA8; // RGBA8
VPI_CHECK(vpiImageCreate(cvImg.cols, cvImg.rows, VPI_IMAGE_FORMAT_RGBA8, VPI_BACKEND_CUDA, &vpiImgRGBA8));
VPI_CHECK(vpiSubmitConvertImageFormat(vpiStream, VPI_BACKEND_CUDA, vpiImg, vpiImgRGBA8, nullptr));
// Track
// predict and visualy localize
int nTrackedObjects;
VPI_CHECK(vpiArrayGetSize(trackedObjects, &nTrackedObjects));
if (nTrackedObjects > 0)
	VPI_CHECK(vpiSubmitCropScalerBatch(vpiStream, VPI_BACKEND_CUDA, cropPayload,
													 &vpiImgRGBA8, 1, trackedObjects,
													 patchW, patchH, objPatches));
	VPI_CHECK(vpiSubmitDCFTrackerLocalizeBatch(vpiStream, VPI_BACKEND_CUDA, dcfPayload, nullptr, 1,
	                                 nullptr, objPatches, trackedObjects, trackedObjects, nullptr,
	                                 trackedObjectsCorrelationResponses, &dcfTrackerParams));
	VPI_CHECK(vpiStreamSync(vpiStream));
// update objects
if (nTrackedObjects > 0 or numDets[0] > 0)
	VPIArrayData trackedObjectsData;
	VPI_CHECK(vpiArrayLockData(trackedObjects, VPI_LOCK_READ_WRITE, VPI_ARRAY_BUFFER_HOST_AOS, &trackedObjectsData));
	// add new objects (not associated)
	VPI_CHECK(vpiArraySetSize(trackedObjects, nTrackedObjects + nNewObjects));
	for (int i = 0; i < nNewObjects; ++i)
		int idxBbox = newObjects[i];
		int idxObject = nTrackedObjects + i;
		VPIAxisAlignedBoundingBoxF32 newObjectBbox{(float)bboxes[0][idxBbox].x, (float)bboxes[0][idxBbox].y, (float)bboxes[0][idxBbox].width, (float)bboxes[0][idxBbox].height};
		VPIDCFTrackedBoundingBox newObject{newObjectBbox, VPI_TRACKING_STATE_NEW, 0, filterLR, filterChannelWeightsLR, new trackedObjectInfo{0}};
		((VPIDCFTrackedBoundingBox*)trackedObjectsData.buffer.aos.data)[idxObject] = newObject;
	VPI_CHECK(vpiArrayUnlock(trackedObjects));
// update tracker
	// Extract from the current frame the image patches of each object given its refined bounding box.
	// Update tracking information
	VPI_CHECK(vpiSubmitDCFTrackerUpdateBatch(vpiStream, VPI_BACKEND_CUDA, dcfPayload,
																					 nullptr, 1,
																					 nullptr, nullptr,
																					 objPatches, trackedObjects, &dcfTrackerParams));
	for (int i = 0; i < nTrackedObjects; ++i) {
		if (((VPIDCFTrackedBoundingBox *) trackedObjectsData.buffer.aos.data)[i].state != VPI_TRACKING_STATE_LOST)
			((VPIDCFTrackedBoundingBox *) trackedObjectsData.buffer.aos.data)[i].state = VPI_TRACKING_STATE_TRACKED;
Could you share where the VPI_ERROR_INVALID_ARGUMENT triggers?
To check it further, could you share a reproducible sample for us to check?
Hi!
The error is triggered by vpiSubmitDCFTrackerUpdateBatch, and if I do not throw an exception, then also by vpiSubmitDCFTrackerLocalizeBatch (in the next iteration).
To reproduce, you can use this code (single iteration). You need to take some image as an input, which has at least the dimensions of the bounding box:
#include <vpi/Stream.h>
#include <vpi/OpenCVInterop.hpp>
#include <vpi/Pyramid.h>
#include <vpi/algo/DCFTracker.h>
#include <vpi/algo/CropScaler.h>
#include <vpi/Array.h>
#include <vpi/algo/ConvertImageFormat.h>
#include <vpi/Status.h>
#include <opencv2/imgcodecs.hpp>
void VPI_CHECK(VPIStatus status, const std::string& errorMessage = "") { if (status) throw std::runtime_error("VPIStatus code: " + std::to_string(status) + ". " + errorMessage); }
struct trackedObjectInfo {
	int nNotTracked = 0;
int main() {
	VPIStream vpiStream;
	VPIPayload cropPayload;
	VPIPayload dcfPayload;
	VPIDCFTrackerParams dcfTrackerParams;
	VPIArray trackedObjects;
	VPIArray trackedObjectsCorrelationResponses;
	VPIImage objPatches;
	int patchW;
	int patchH;
	int max_det = 10;
	float filterLR = 0.5f;
	float filterChannelWeightsLR = 0.5f;
	vpiStreamCreate(0, &vpiStream);
	                         patchH * max_det,
	                         &objPatches));
	// DEFINE IMG AND BBOXES HERE
	auto cvImg = cv::imread("/path/to/image");
	std::vector<std::vector<cv::Rect>> bboxes{{{200, 200, 200, 200}}};
	VPIImage vpiImg;
	// Track
	// update objects
	if (bboxes[0].size() > 0)
		// collect new objects
		std::vector<int> newObjects;
		for (int i = 0; i < bboxes[0].size(); ++i) {
			if (true)
				newObjects.push_back(i);
		int nNewObjects = newObjects.size();
	// update tracker
		                                         nullptr, 1,
		                                         nullptr, nullptr,
	vpiImageDestroy(vpiImg);
	return 0;
Cmake file contents:
add_executable(vpiError
        vpiError.cu)
find_package(vpi REQUIRED)
find_package(OpenCV 4 REQUIRED)
target_link_libraries(vpiError
        PUBLIC
        ${OpenCV_LIBS}
        vpi)
target_include_directories(vpiError
        PUBLIC
        ${OpenCV_INCLUDE_DIRS}
Thanks for sharing.
We will check it and provide you with more information.
Hello!
One week has passed since my last message. Are there any updates?
Thank you in advance
Our internal team is still checking this issue.
Will let you know once we get feedback.
Hello!
Just a reminder. Any updates?
VPI_ERROR_INVALID_ARGUMENT might relate to the usage of our DCF feature.
Our internal team is working on a sample to demonstrate the functionality.
Will let you know once it is ready.
Hello!
Thank you! Looking forward for your sample.
