VPI thread safe
Is vpiImageLockData and vpiImageDataExportOpenCVMat in VPI 2.3.9 thread safe?
The VPI documentation mentioned that “All API functions are thread-safe”.
I tested it a few times showing that it might not.
I run these two functions in my thread pool, showing that it might cause a segmentation fault program. Once I add a mutex to ensure the vpiImageLockData and vpiImageDataExportOpenCVMat are not running in parallel, no segmentation happens anymore.
Steps to reproduce the problem
// Note: You need to create a vpiImage first.
  // Step 1: Get the VPIImage data
  VPIImageData vpiImageData;
  checkVPIErrors(vpiImageLockData(vpiImage, VPI_LOCK_READ, VPI_IMAGE_BUFFER_HOST_PITCH_LINEAR, &vpiImageData));
  // Step 2: Convert VPIImageData to OpenCV Mat
  cv::Mat cvImage;
  checkVPIErrors(vpiImageDataExportOpenCVMat(vpiImageData, &cvImage));
  // Step 3: Just clone the image
  // Segmentation fault happens here.
  cv::Mat tmp = cvImage.clone();
  // Step 4: Unlock the VPIImage
  checkVPIErrors(vpiImageUnlock(vpiImage));
Put the above code into a multithreading function and keep calling it.
Would you mind sharing a complete sample so we can test it?
