Hi, I’m trying to run vxFastCornersNode from VisionWorks API, without success so far. The current issue is that each key point in the result array has an x and y fields equal to zero.
Here is my code:
#include <tuple>
#include <iostream>
#include <opencv2/imgcodecs.hpp>
#include <opencv2/imgproc.hpp>
#include <NVX/nvx.h>
#include <NVX/nvx_opencv_interop.hpp>
#include <OVX/UtilityOVX.hpp>
int main(int argc, char *argv[]) {
std::string image_file_path = PROJECT_SOURCE_DIR"/test/vlcsnap-2021-12-22-14h05m41s129.png";
std::cout << image_file_path << "\n";
cv::Mat image = cv::imread(image_file_path, cv::IMREAD_GRAYSCALE);
assert(!image.empty());
assert(image.rows > 0);
assert(image.cols > 0);
cv::resize(image, image, cv::Size(image.cols / 4, image.rows / 4), cv::INTER_LINEAR);
vx_context context = vxCreateContext();
NVXIO_CHECK_REFERENCE(context);
vx_graph graph = vxCreateGraph(context);
NVXIO_CHECK_REFERENCE(graph);
vx_image input = nvx_cv::createVXImageFromCVMat(context, image);
NVXIO_CHECK_REFERENCE(input);
vx_float32 strength_thresh_init_value = 20.0f;
vx_scalar strength_thresh = vxCreateScalar(context, VX_TYPE_FLOAT32, &strength_thresh_init_value);
NVXIO_CHECK_REFERENCE(strength_thresh);
vx_array keypoints = vxCreateVirtualArray(graph, VX_TYPE_KEYPOINT, 10000);
NVXIO_CHECK_REFERENCE(keypoints);
vx_size n_corners_init_value = 0;
vx_scalar n_corners = vxCreateScalar(context, VX_TYPE_SIZE, &n_corners_init_value);
NVXIO_CHECK_REFERENCE(n_corners);
vx_node corner_detection_node = vxFastCornersNode(
graph, input, strength_thresh, vx_true_e, keypoints, n_corners);
NVXIO_CHECK_REFERENCE(corner_detection_node);
// Ensure highest graph optimization level
const char *option = "-O3";
NVXIO_SAFE_CALL(vxSetGraphAttribute(graph, NVX_GRAPH_VERIFY_OPTIONS, option, strlen(option)));
NVXIO_SAFE_CALL(vxVerifyGraph(graph));
vxReleaseScalar(&strength_thresh);
vxReleaseImage(&input);
vx_image input_periodic = nvx_cv::createVXImageFromCVMat(context, image);
NVXIO_CHECK_REFERENCE(input_periodic);
NVXIO_SAFE_CALL(vxSetParameterByIndex(corner_detection_node, 0, (vx_reference)input_periodic));
// Process graph
NVXIO_SAFE_CALL(vxProcessGraph(graph));
vxReleaseImage(&input_periodic);
vx_int32 n_corners_value = 0;
NVXIO_SAFE_CALL(vxReadScalarValue(n_corners, &n_corners_value));
vx_size num_items = 0ul;
NVXIO_SAFE_CALL(vxQueryArray(keypoints, VX_ARRAY_ATTRIBUTE_NUMITEMS, &num_items, sizeof(num_items)));
vx_size i, stride = 0ul;
void *base = NULL;
NVXIO_SAFE_CALL(vxAccessArrayRange(keypoints, 0, num_items, &stride, &base, VX_READ_ONLY));
for (i = 0; i < 10; i++) {
std::cout
<< "x: " << vxArrayItem(nvx_keypointf_t, base, i, stride).x << " "
<< "y: " << vxArrayItem(nvx_keypointf_t, base, i, stride).y << " "
<< "scale: " << vxArrayItem(nvx_keypointf_t, base, i, stride).scale << " "
<< "strength: " << vxArrayItem(nvx_keypointf_t, base, i, stride).strength << " "
<< "tracking_status: " << vxArrayItem(nvx_keypointf_t, base, i, stride).tracking_status << " "
<< "orientation: " << vxArrayItem(nvx_keypointf_t, base, i, stride).orientation << " "
<< "\n";
vxCommitArrayRange(keypoints, 0, num_items, base);
std::cout
<< "num_items: " << num_items << " "
<< "n_corners_value: " << n_corners_value << " "
<< "stride: " << stride << " "
<< "\n";
return 0;
Here is the output:
/tmp/tmp.DpoYHlrS19/test/vlcsnap-2021-12-22-14h05m41s129.png
x: 0 y: 0 scale: 0 strength: 33 tracking_status: 1 orientation: 0
x: 0 y: 0 scale: 0 strength: 79 tracking_status: 1 orientation: 0
x: 0 y: 0 scale: 0 strength: 22 tracking_status: 1 orientation: 0
x: 0 y: 0 scale: 0 strength: 27 tracking_status: 1 orientation: 0
x: 0 y: 0 scale: 0 strength: 31 tracking_status: 1 orientation: 0
x: 0 y: 0 scale: 0 strength: 21 tracking_status: 1 orientation: 0
num_items: 5128 n_corners_value: 5128 stride: 28
There are several things I’m not sure in:
- If I have to release all the refs used during the graph creation before its execution?
- What does tracking_status=1 mean in the context of corner detection? There is no tracking involved, so why it was set to 1?
Many thanks for any hint!
Best regards,
Alex
