Want segmentation model with 25 fps for jetson nano
if using fakesink, please use the following code:
    if is_aarch64():
        #nvsegvisual.link(transform)
        #transform.link(sink)
        nvsegvisual.link(sink)
Thank you it worked. Max i get is 11 fps with one stream.
I check sudo tegrastats
output is
test1.txt (17.5 KB)
I found one of the CPU core is 100% used. But others are not used to full there might be the scope of increasing the fps i guess what are your view onit.
thanks for the sharing! can you use β€œtop -H -p ” or jtop check which task cost too much CPU resource?
you can add more queue plugin in pipeline. queue is Gstreamer opensource plugin. AYK, there are multiple threads in queue, multiple threads will use more CPU cores.
