"warning : Double is not supported. Demoting to float" on GTX295 under ubuntu 9.10
i’ve just made a fresh installation of Ubuntu 9.10 64bit with the latest version of cuda driver(256.40), cuda toolkit and sdk (all in 64bit version).
Every example from cuda SDK or piece of code i compile i get this error:
“warning : Double is not supported. Demoting to float”
but i’m working on 2 GTX295 and, looking at the deviceQuery, the device is correct (gtx295 with computing capabilty 1.3).
Previously i had a working 8.04 Ubuntu 64bit with cuda driver of realease 2.0.
Any idea to identify/solve this problem?
More info are available in the attached nvidia bug report file.
Thanks in advance,
Danielta
I’ve seen this on my GTX 280 (Cuda 2.3) but it doesn’t seem to occur on my Tesla. (Cuda 3.1)
-Nachiket
-Nachiket
Are you compiling with [font=“Courier New”]-arch sm_13[/font]?
Yes, I am.
Yes, I am.
Hi im in 64 bits, and i cant use memcpy, it says memory or pointers are too large to fit in 32bits, what flags should i use? or do you know something about my problem? it is not memory cause im only transfering 1024*sizeof(int) bytes.
Hi im in 64 bits, and i cant use memcpy(devicetohost), it says memory or pointers are too large to fit in 32bits, what flags should i use? or do you know something about my problem? it is not memory cause im only transfering 1024*sizeof(int) bytes.
