Watchdog Timer on Jetson TX1 : How can I change the timeout value and kick WDT?
Hi.
I am trying to use watchdog timer on Jetson TX1.
Firstly, I tried following sample code after setup TX1 by JetPack for L4T 2.1, but it did not work.
#include <stdio.h>
#include <fcntl.h>
#include <unistd.h>
#include <string.h>
#include <errno.h>
#include <sys/ioctl.h>
#include <linux/watchdog.h>
int main (void) {
	int fd, ret;
	int timeout = 0;
	/* open WDT0 device (WDT0 enables itself automatically) */
	fd = open("/dev/watchdog0", O_RDWR);
	if(fd < 0) {
		fprintf(stderr, "Open watchdog device failed!\n");
		return -1;
	/* WDT0 is counting now,check the default timeout value */
	ret = ioctl(fd, WDIOC_GETTIMEOUT, &timeout);
	if(ret) {
		fprintf(stderr, "Get watchdog timeout value failed!\n");
		return -1;
	fprintf(stdout, "Watchdog timeout value: %d\n", timeout);
	/* set new timeout value 60s */
	/* Note the value should be within [5, 1000] */
	timeout = 60;
	ret = ioctl(fd, WDIOC_SETTIMEOUT, &timeout);
	if(ret) {
		fprintf(stderr, "Set watchdog timeout value failed!\n");
		return -1;
	fprintf(stdout, "New watchdog timeout value: %d\n", timeout);
	/*Kick WDT0, this should be running periodically */
	ret = ioctl(fd, WDIOC_KEEPALIVE, NULL);
	if(ret) {
		fprintf(stderr, "Kick watchdog failed!\n");
		return -1;
Then, setup TX1 again by building the NVIDIA kernel according to “Tegra Linux Driver Package Development Guide”.
I set kernel configuration as follows:
CONFIG_WATCHDOG=y
CONFIG_WATCHDOG_CORE=y
# CONFIG_WATCHDOG_NOWAYOUT is not set
# Watchdog Device Drivers
# CONFIG_SOFT_WATCHDOG is not set
CONFIG_SOFT_PLATFORM_WATCHDOG=y
CONFIG_TEGRA_WATCHDOG=y
CONFIG_MAX77620_WATCHDOG=y
# CONFIG_ALIM7101_WDT is not set
# CONFIG_I6300ESB_WDT is not set
# PCI-based Watchdog Cards
# CONFIG_PCIPCWATCHDOG is not set
# CONFIG_WDTPCI is not set
But, “WDIOC_GETTIMEOUT” and “WDIOC_SETTIMEOUT” shows error “operation not supported”.
And it seems that “WDIOC_KEEPALIVE” does not work, so TX1 reboot after 120 seconds.
I have tried changing kernel source (tegra_wdt.c) as follows:
-static int heartbeat = 120;
+static int heartbeat = 10;
The timout value does not change, either.
The kernel version is 3.10.67, and it is able to kick and close WDT by the following way.
# tail -f /dev/watchdog0   // open wdt
# echo 1 > /dev/watchdog0  // kick wdt
# echo V > /dev/watchdog0  // close wdt
Can anyone help me?
What did you mean “it did not work”? What’s the message?
Regarding ioctl and watchdog timers, see also:
[url]https://devtalk.nvidia.com/default/topic/975935/jetson-tx1/how-can-i-change-the-timeout-value-and-kick-watchdog-on-jetson-tx1-/[/url]
Locked this thread out as the same issue is under discussing at [url]https://devtalk.nvidia.com/default/topic/975935/jetson-tx1/how-can-i-change-the-timeout-value-and-kick-watchdog-on-jetson-tx1-/[/url]
