I’m trying to follow the instructions in the “NVIDIA Tegra Linux Driver Package Development Guide” for enabling the watchdog via the “To enable WDT0 from user space” section on Page 74. I’m running L4T 21.4 and /dev/watchdog0 is present.
It’s unclear to me… Do I need to recompile the kernel and flash it? I don’t understand the instructions in the guide:
- Go to the kernel configuration file:
arch/arm/configs/tegra12_defconfig - Add the following line under CONFIG_WATCHDOG_NOWAYOUT=y:
CONFIG_TEGRA_WATCHDOG=y
If I have to recompile the kernel under this method, how is this notably different from the instructions in the “To enable WDT0 from the Linux kernel”, which state:
arch/arm/configs/tegra12_defconfig - Add the following 2 lines under CONFIG_WATCHDOG_NOWAYOUT=y:
CONFIG_TEGRA_WATCHDOG_ENABLE_ON_PROBE=y
I’ve tried the code below on my current platform. It compiles fine, but if fails to open the watchdog device: “Open watchdog device failed!”
Here’s my code, which is basically identical to that in the manual except I have the #includes and I also try to close the watchdog after kicking it once.
// watchdogtest.cpp
#include <stdio.h>
#include <fcntl.h> // for watchdog timer
#include <unistd.h> // needed only if close() is used to close watchdog timer
#include <sys/ioctl.h> // for watchdog timer
#include <linux/watchdog.h> // for watchdog timer
int main() {
int fd, ret;
int timeout = 0;
/* open WDT0 device (WDT0 enables itself automatically) */
fd = open("/dev/watchdog0", O_RDWR);
if (fd<0) {
fprintf(stderr, "Open watchdog device failed!\n");
return -1;
/* WDT0 is counting now,check the default timeout value */
ret = ioctl(fd, WDIOC_GETTIMEOUT, &timeout);
if(ret) {
fprintf(stderr, "Get watchdog timeout value failed!\n");
return -1;
fprintf(stdout, "Watchdog timeout value: %d\n", timeout);
/* set new timeout value 60s */
/* Note the value should be within [5, 1000] */
timeout = 60;
ret = ioctl(fd, WDIOC_SETTIMEOUT, &timeout);
if(ret) {
fprintf(stderr, "Set watchdog timeout value failed!\n");
return -1;
fprintf(stdout, "New watchdog timeout value: %d\n", timeout);
/*Kick WDT0, this should be running periodically */
ret = ioctl(fd, WDIOC_KEEPALIVE, NULL);
if(ret) {
fprintf(stderr, "Kick watchdog failed!\n");
return -1;
/* close WDT0 device */
close(fd);
if (ret<0) {
fprintf(stderr, "Failed to close watchdog device.");
return -1;
return 0;
