Has anyone gotten the Jetbot to work with the Waveshare Motor Driver HAT? (https://www.waveshare.com/motor-driver-hat.htm)
It seems similar to the Adafruit motor driver. I’m trying it and getting the following errors when creating an instance of the Robot object when running the basic_motion notebook in Jupyter Lab.
OSError Traceback
(most recent call last)
<ipython-input-3-b418ad9f6ab3> in <module>
----> 1 robot = Robot()
/usr/local/lib/python3.6/dist-packages/jetbot-0.4.0-py3.6.egg/jetbot/robot.py in __init__(self, *args, **kwargs)
20 def __init__(self, *args, **kwargs):
21 super(Robot, self).__init__(*args, **kwargs)
---> 22 self.motor_driver = Adafruit_MotorHAT(i2c_bus=self.i2c_bus)
23 self.left_motor = Motor(self.motor_driver, channel=self.left_motor_channel, alpha=self.left_motor_alpha)
24 self.right_motor = Motor(self.motor_driver, channel=self.right_motor_channel, alpha=self.right_motor_alpha)
/usr/local/lib/python3.6/dist-packages/Adafruit_MotorHAT-1.4.0-py3.6.egg/Adafruit_MotorHAT/Adafruit_MotorHAT_Motors.py in __init__(self, addr, freq, i2c, i2c_bus)
229 self.motors = [ Adafruit_DCMotor(self, m) for m in range(4) ]
230 self.steppers = [ Adafruit_StepperMotor(self, 1), Adafruit_StepperMotor(self, 2) ]
--> 231 self._pwm = PWM(addr, debug=False, i2c=i2c, i2c_bus=i2c_bus)
232 self._pwm.setPWMFreq(self._frequency)
233
/usr/local/lib/python3.6/dist-packages/Adafruit_MotorHAT-1.4.0-py3.6.egg/Adafruit_MotorHAT/Adafruit_PWM_Servo_Driver.py in __init__(self, address, debug, i2c, i2c_bus)
57 self.i2c = get_i2c_device(address, i2c, i2c_bus)
58 logger.debug("Reseting PCA9685 MODE1 (without SLEEP) and MODE2")
---> 59 self.setAllPWM(0, 0)
60 self.i2c.write8(self.__MODE2, self.__OUTDRV)
61 self.i2c.write8(self.__MODE1, self.__ALLCALL)
/usr/local/lib/python3.6/dist-packages/Adafruit_MotorHAT-1.4.0-py3.6.egg/Adafruit_MotorHAT/Adafruit_PWM_Servo_Driver.py in setAllPWM(self, on, off)
93 def setAllPWM(self, on, off):
94 "Sets a all PWM channels"
---> 95 self.i2c.write8(self.__ALL_LED_ON_L, on & 0xFF)
96 self.i2c.write8(self.__ALL_LED_ON_H, on >> 8)
97 self.i2c.write8(self.__ALL_LED_OFF_L, off & 0xFF)
/usr/local/lib/python3.6/dist-packages/Adafruit_GPIO-1.0.4-py3.6.egg/Adafruit_GPIO/I2C.py in write8(self, register, value)
114 """Write an 8-bit value to the specified register."""
115 value = value & 0xFF
--> 116 self._bus.write_byte_data(self._address, register, value)
117 self._logger.debug("Wrote 0x%02X to register 0x%02X",
118 value, register)
/usr/local/lib/python3.6/dist-packages/Adafruit_PureIO-1.0.4-py3.6.egg/Adafruit_PureIO/smbus.py in write_byte_data(self, addr, cmd, val)
266 # Send the data to the device.
267 self._select_device(addr)
--> 268 self._device.write(data)
269
270 def write_word_data(self, addr, cmd, val):
OSError: [Errno 121] Remote I/O error
Any help is greatly appreciated!
