We successfully installed JetPack 7.2.1‑b49 on the Jetson Orin Nano and it boots fine, but Agent Skills (e.g., Workflow, ModelInferencing, ModelBenchm
am currently working with the Jetson Orin Nano Developer Kit.
  • I was able to install JetPack 7.2.1‑b49, and the board boots and works correctly.
  • However, I noticed that Agent Skills are not available in this build.
For example, when I try to use the following packages:
python
from agent_framework import Workflow
from agent_skills import ModelInferencing, ModelBenchmark
the features are missing in b49.
From what I understand, these capabilities are included only in the JetPack 7.2.1‑b184 production build. Could someone guide me on where to download b184 from the NVIDIA Developer Repository?
Hello @ponmuthukumar!
Based on the title and content of your topic, it looks like it may receive better visibility and feedback in a different category. We took the liberty of moving it for you.
If this was an incorrect assessment, please send me a direct message.
Disclaimer: this moderation suggestion and message were generated with AI assistance.
Have you tried to install it?
We can import the agent_skills on 7.2.1-b49 without issue after instaling with the below command:
$ pip3 install agent_skills
Thank you. I successfully installed agent_skills using:
and can import the package. However, the following example still fails:
ImportError: cannot import name ‘ModelInferencing’
Shell
Show more lines
and I can import the package successfully.
Python
Show more lines
with the error:
Plain Text
ImportError: cannot import name 'ModelInferencing'
Show more lines
Additionally, when I check the NVIDIA installation directories:
Shell
ls /opt/nvidia/
Show more lines
I do not see any agent_framework or agent_skills folders.
Could you please share:
  1. A sample application demonstrating the currently supported Agent Skills APIs.
  2. Documentation showing the available classes and functions in the current agent_skills package.
  3. Whether Workflow, ModelInferencing, and ModelBenchmark are available in the public release of JetPack 7.2.1.
  4. How to upgrade from JetPack 7.2.1-b49 to JetPack 7.2.1-b184, or how to verify whether the installed system is already running the b184 build.
Thank you for your support.
