A bit of context. I am currently in the process of reworking how I do wireless communication between an Android phone and a Jetson Tx2. As it is I am using the “Serial Bluetooth” app on android to send text to the Tx2. This works OK, but it would require that I develop my own app in the future for better control. In addition, I have had issues with spotty connections and Bluetooth doesn’t have the bandwidth to do video streaming. Which is something that I want to add.
So I wanted to switch over to using WiFi instead. Now i have looked around an the best approach seems to be to use WiFi-Direct. I did consider if it would be possible to use some other form of ad hoc network, but then I read that android devices don’t list ad hoc networks normally. As a side note, if anyone has any recommendations for network configurations that work with android and iOS I would appreciate it.
So on to the main question, creating a web interface for interacting with the app on the Tx2. My current application is currently written in C++ and C++ generally isn’t a programming language associated with web interfaces. Now the only library that I am heavily locked into is deep-streamer. Given that deep-streamer is C/C++ and Python bindings I feel like the back end is more or less locked into either of these. Most of the other libraries I use also have a python library so its not that big of an issue to switch. As it currently stands I was thinking about either sticking with C++ and using something like Wt or changing to python and using a web framework like Django. So I was wondering if anyone else has been down this particular rabbit hole and might have some insight and what might work the best and if there are any major pitfalls?
