Webrtc composer can not access by browser with error [streamclient] Stopping Stream with error 0xC0F2221A
• GPU
• 6.3
• TensorRT Version
• 525.116.04
• bugs
**• i use docker image nvcr.io/nvidia/deepstream:6.3-gc-triton-devel with command docker run -it --entrypoint /bin/bash --gpus all --rm --network=host -e DISPLAY=${DISPLAY} -e MESA_GL_VERSION_OVERRIDE=4.6 -v /tmp/.X11-unix/:/tmp/.X11-unix --privileged -v /var/run/docker.sock:/var/run/docker.sock nvcr.io/nvidia/deepstream:6.3-gc-triton-devel and in container with command composer --enable-streaming webrtc **
Duplicate with this topic. let us discuss in the main post
i already set she cros options
kit_20231214_030758.log (226.8 KB)
i start the webrtc composer ,but i cant access in local network. the error is up.
thanks,what i have to do about this issue, and what you need me to try.
Nothing looks wrong with the log. Only thing I can suggest is to make sure no other instances of kit are running.
killall kit
