Hi, full log is below
Matt
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-3531) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Wed Mar 13 00:32:22 PDT 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00140000@92cb6000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 23 pages/cpu @ffffffc0fefd2000 s53400 r8192 d32616 u94208
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x140000@0x92cb6000 is_hdmi_initialised=1 root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 root=/dev/mmcblk0p1 rw rootwait
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29384(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3574784K/4159488K available (15166K kernel code, 2914K rwdata, 6616K rodata, 8512K init, 605K bss, 109568K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f50000 ( 15168 KB)
[ 0.000000] .rodata : 0xffffff8008f50000 - 0xffffff80095d0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095d0000 - 0xffffff8009e20000 ( 8512 KB)
[ 0.000000] .data : 0xffffff8009e20000 - 0xffffff800a0f8808 ( 2915 KB)
[ 0.000000] .bss : 0xffffff800a0f8808 - 0xffffff800a18fe3c ( 606 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] boot misc1 0x90000000: expected 0x10000000
[ 0.000000] (comparison mask = 0xf8000000)
[ 0.000000] boot misc2 0x0: expected 0xf6e0f620
[ 0.000000] (comparison mask = 0xffffffff)
[ 0.000000] boot misc3 0x559: expected 0x10000
[ 0.000000] PLL_D2 already enabled. Postponing set full defaults
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001494] Console: colour dummy device 80x25
[ 0.002434] console [tty0] enabled
[ 0.002459] kmemleak: Kernel memory leak detector disabled
[ 0.002488] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[ 0.002515] pid_max: default: 32768 minimum: 301
[ 0.002973] Security Framework initialized
[ 0.003204] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003223] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.004427] ftrace: allocating 46802 entries in 183 pages
[ 0.175578] ASID allocator initialised with 65536 entries
[ 0.211344] tegra-id: chipid=22117.
[ 0.211386] tegra-id: opt_subrevision=0.
[ 0.211415] Tegra Speedo/IDDQ fuse revision 4
[ 0.211430] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.211447] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[ 0.211463] Tegra: CPU Speedo Value 2084, SoC Speedo Value 1968, GPU Speedo Value 2075
[ 0.211482] Tegra: CPU IDDQ Value 2180, SoC IDDQ Value 2240, GPU IDDQ Value 2755
[ 0.211518] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[ 0.211543] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02.dts
[ 0.211577] DTB Build time: Mar 15 2019 09:52:07
[ 0.261048] CPU1: Booted secondary processor [411fd071]
[ 0.292955] CPU2: Booted secondary processor [411fd071]
[ 0.324945] CPU3: Booted secondary processor [411fd071]
[ 0.325031] Brought up 4 CPUs
[ 0.325095] SMP: Total of 4 processors activated.
[ 0.325112] CPU features: detected feature: 32-bit EL0 Support
[ 0.325387] CPU: All CPU(s) started at EL2
[ 0.325416] alternatives: patching kernel code
[ 0.333437] devtmpfs: initialized
[ 0.367897] Initilizing CustomIPI irq domain
[ 0.368288] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.368334] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.378972] pinctrl core: initialized pinctrl subsystem
[ 0.379603] OS set in device tree is not L4T.
[ 0.380009] regulator-dummy: no parameters
[ 0.380309] Initializing plugin-manager
[ 0.380478] Plugin module not found
[ 0.380693] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[ 0.381258] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[ 0.382013] node /plugin-manager/fragment@5 match with board 3449-0000-200
[ 0.385307] NET: Registered protocol family 16
[ 0.386646] pstore: using zlib compression
[ 0.387330] console [pstore-1] enabled
[ 0.387348] pstore: Registered ramoops as persistent store backend
[ 0.387366] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.401064] cpuidle: using governor menu
[ 0.404849] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.406394] vdso: 2 pages (1 code @ ffffff8008f57000, 1 data @ ffffff8009e24000)
[ 0.406441] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.409476] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.410982] tegra_bpmp_of_clk_init: EMC proxy not found.
[ 0.411909] tegra_powergate_init: DONE
[ 0.411947] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02.dts
[ 0.411985] DTB Build time: Mar 15 2019 09:52:07
[ 0.413634] Tegra reboot handler registered.
[ 0.418051] iommu: Adding device tegra-carveouts to group 0
[ 0.418216] platform tegra-carveouts: domain=ffffffc0f9b98318 allocates as[0]=ffffffc0f9bfc0a8
[ 0.418597] iommu: Adding device smmu_test to group 1
[ 0.418664] platform smmu_test: domain=ffffffc0f9b98558 allocates as[0]=ffffffc0f9bfc110
[ 0.419503] mc: mapped MMIO address: 0xffffff800802e000 -> 0x70019000
[ 0.419576] mc: mapped MMIO address: 0xffffff8008065000 -> 0x7001c000
[ 0.419649] mc: mapped MMIO address: 0xffffff8008079000 -> 0x7001d000
[ 0.419673] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.419708] mc-err: mcerr ops are set to t21x
[ 0.429379] iommu: Adding device 70090000.xusb to group 2
[ 0.429692] iommu: Adding device 70006000.serial to group 3
[ 0.429790] platform 70006000.serial: domain=ffffffc0f947c6d8 allocates as[0]=ffffffc0f9bfc178
[ 0.430224] iommu: Adding device 70006040.serial to group 4
[ 0.430509] iommu: Adding device 70006200.serial to group 5
[ 0.430753] iommu: Adding device sound to group 6
[ 0.430814] platform sound: domain=ffffffc0f947cc18 allocates as[0]=ffffffc0f9bfc1e0
[ 0.431396] iommu: Adding device 7000d400.spi to group 7
[ 0.431679] iommu: Adding device 7000d600.spi to group 8
[ 0.431970] iommu: Adding device 70410000.spi to group 9
[ 0.432289] iommu: Adding device 50000000.host1x to group 10
[ 0.432593] iommu: Adding device 54080000.vi to group 11
[ 0.433055] iommu: Adding device 54600000.isp to group 12
[ 0.433342] iommu: Adding device 54680000.isp to group 13
[ 0.433668] iommu: Adding device tegradc.0 to group 14
[ 0.433737] platform tegradc.0: domain=ffffffc0f9489b58 allocates as[0]=ffffffc0f9bfc248
[ 0.435141] platform tegradc.0: IOVA linear map 0x0000000092cb6000(140000)
[ 0.435547] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.435887] iommu: Adding device tegradc.1 to group 15
[ 0.435956] platform tegradc.1: domain=ffffffc0f9489d98 allocates as[0]=ffffffc0f9bfc2b0
[ 0.437373] platform tegradc.1: IOVA linear map 0x0000000092cb6000(140000)
[ 0.437785] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.438056] iommu: Adding device 54340000.vic to group 16
[ 0.438280] iommu: Adding device 544c0000.nvenc to group 17
[ 0.438491] iommu: Adding device 54500000.tsec to group 18
[ 0.438707] iommu: Adding device 54100000.tsecb to group 19
[ 0.438912] iommu: Adding device 54480000.nvdec to group 20
[ 0.439148] iommu: Adding device 54380000.nvjpg to group 21
[ 0.440215] iommu: Adding device 546c0000.i2c to group 22
[ 0.440561] iommu: Adding device 57000000.gpu to group 23
[ 0.440627] platform 57000000.gpu: domain=ffffffc0f9495d98 allocates as[0]=ffffffc0f9bfc318
[ 0.440687] platform 57000000.gpu: domain=ffffffc0f9495d98 allocates as[1]=ffffffc0f9bfc380
[ 0.440750] platform 57000000.gpu: domain=ffffffc0f9495d98 allocates as[2]=ffffffc0f9bfc3e8
[ 0.440807] platform 57000000.gpu: domain=ffffffc0f9495d98 allocates as[3]=ffffffc0f9bfc450
[ 0.441757] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.441797] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.441824] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.441844] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.441860] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.493135] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.493169] tegra-pmc: Clear bootloader IO dpd settings
[ 0.493201] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.493279] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.493594] iommu: Adding device 70012000.se to group 24
[ 0.494461] iommu: Adding device 7000c000.i2c to group 25
[ 0.494788] iommu: Adding device 7000c400.i2c to group 26
[ 0.495111] iommu: Adding device 7000c500.i2c to group 27
[ 0.495426] iommu: Adding device 7000c700.i2c to group 28
[ 0.495783] iommu: Adding device 7000d000.i2c to group 29
[ 0.496106] iommu: Adding device 7000d100.i2c to group 30
[ 0.496483] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.496554] platform sdhci-tegra.0: domain=ffffffc0f9525f18 allocates as[0]=ffffffc0f9bfc4b8
[ 0.497542] iommu: Adding device 700d0000.xudc to group 32
[ 0.503660] vdd-ac-bat: 5000 mV
[ 0.504130] vdd-5v0-sys: 5000 mV
[ 0.505409] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.505500] vdd-5v0-hdmi: 5000 mV
[ 0.506041] vdd-1v8: 1800 mV
[ 0.506553] vdd-fan: supplied by vdd-5v0-sys
[ 0.506607] vdd-fan: 5000 mV
[ 0.507102] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.507183] vdd-usb-vbus: 5000 mV
[ 0.507891] vdd-usb-vbus2: 5000 mV
[ 0.537878] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.540344] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.540726] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.549596] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.549980] SCSI subsystem initialized
[ 0.550493] usbcore: registered new interface driver usbfs
[ 0.550565] usbcore: registered new interface driver hub
[ 0.550651] usbcore: registered new device driver usb
[ 0.554709] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.556261] random: fast init done
[ 0.561121] vdd-core: 600 <--> 1162 mV at 1075 mV
[ 0.562353] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.565037] vdd-ddr-1v1: 1150 mV
[ 0.568965] vdd-pre-reg-1v35: 1350 mV
[ 0.572963] vdd-1v8: 1800 mV
[ 0.573241] vdd-1v8: Failed to create debugfs directory
[ 0.576961] avdd-sys-1v2: 1200 mV
[ 0.580961] vdd-pex-1v0: 1050 mV
[ 0.581732] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[ 0.582377] max77620-ldo3: at 3100 mV
[ 0.584964] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[ 0.585638] max77620-ldo5: at 3100 mV
[ 0.586317] max77620-ldo6: at 2800 mV
[ 0.588960] avdd-1v05-pll: 1050 mV
[ 0.592961] avdd-io-hdmi-dp: 1050 mV
[ 0.594486] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.594769] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.596848] max77620 4-003c: max77620 probe successful
[ 0.599106] i2c i2c-6: Unbalanced pm_runtime_enable!
[ 0.599674] media: Linux media interface: v0.10
[ 0.599739] Linux video capture interface: v2.00
[ 0.600682] pps_core: LinuxPPS API ver. 1 registered
[ 0.600711] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.600760] PTP clock support registered
[ 0.604054] tegra_fiq_debugger_init: found FIQ source (IRQ 98)
[ 0.610426] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.611300] Advanced Linux Sound Architecture Driver Initialized.
[ 0.611975] Bluetooth: Core ver 2.22
[ 0.612045] NET: Registered protocol family 31
[ 0.612063] Bluetooth: HCI device and connection manager initialized
[ 0.612091] Bluetooth: HCI socket layer initialized
[ 0.612113] Bluetooth: L2CAP socket layer initialized
[ 0.612148] Bluetooth: SCO socket layer initialized
[ 0.613996] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.614034] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.614092] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.614120] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.616897] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.618229] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.618317] vdd-3v3-sys: 3300 mV
[ 0.618608] vdd-1v8: supplied by vdd-3v3-sys
[ 0.621195] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.621705] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.621766] vdd-3v3-sd: 3300 mV
[ 0.622959] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.623021] avdd-io-edp-1v05: 1050 mV
[ 0.623516] vdd-usb-hub-en: supplied by vdd-1v8
[ 0.623569] vdd-usb-hub-en: 5000 mV
[ 0.624930] camchar: rtcpu character device driver loaded
[ 0.625692] extcon-gpio-states extcon:extcon@1: Cable state:0, cable id:0
[ 0.627068] clocksource: Switched to clocksource arch_sys_counter
[ 0.666683] VFS: Disk quotas dquot_6.6.0
[ 0.666849] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.667436] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.667881] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.667930] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.668160] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.668184] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.668212] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.668260] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.668286] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.668315] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.668336] nvmap_page_pool_init: Total RAM pages: 1012480
[ 0.668353] nvmap_page_pool_init: nvmap page pool size: 126560 pages (494 MB)
[ 0.668459] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.668908] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.669839] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.677899] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.678295] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.678558] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.678788] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.678984] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.679325] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.679347] pre_t19x_iso_plat_init(): max_iso_bw=33280000KB
[ 0.679794] NET: Registered protocol family 2
[ 0.680776] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.681015] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.681529] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.681688] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.681788] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.682219] NET: Registered protocol family 1
[ 0.683002] RPC: Registered named UNIX socket transport module.
[ 0.683031] RPC: Registered udp transport module.
[ 0.683110] RPC: Registered tcp transport module.
[ 0.683129] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.683398] Trying to unpack rootfs image as initramfs...
[ 0.692719] host1x 50000000.host1x: initialized
[ 0.694568] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.697822] audit: initializing netlink subsys (disabled)
[ 0.697933] audit: type=2000 audit(0.547:1): initialized
[ 0.698692] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.708787] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.710282] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.711101] 9p: Installing v9fs 9p2000 file system support
[ 0.714329] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.714491] io scheduler noop registered
[ 0.714783] io scheduler cfq registered (default)
[ 0.717641] gic 702f9000.agic: GIC IRQ controller registered
[ 0.720661] iommu: Adding device 702ef000.adsp to group 33
[ 0.727692] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 0.727870] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 0.728462] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x9a28410
[ 0.728495] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 0.730137] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 0.730266] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 0.730389] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.730608] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 0.730722] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 0.730829] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 0.730943] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 0.731086] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 0.731226] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.731345] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.737659] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.738986] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.740893] tegra-pcie 1003000.pcie-controller: 4x1, 1x1 configuration
[ 0.742213] tegra-pcie 1003000.pcie-controller: PCIE: Enable power rails
[ 0.742583] tegra-pcie 1003000.pcie-controller: probing port 0, using 4 lanes
[ 0.743833] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.744098] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=750000, max_bw=1500000
[ 0.744397] Adding domain tsec-pd to PM domain host1x-pd
[ 0.746384] tegra-pcie 1003000.pcie-controller: probing port 1, using 1 lanes
[ 0.747301] tsec 54500000.tsec: initialized
[ 0.749004] tsec 54100000.tsecb: initialized
[ 0.749739] Adding domain nvdec-pd to PM domain host1x-pd
[ 0.752904] nvdec 54480000.nvdec: initialized
[ 0.753956] Adding domain vic03-pd to PM domain host1x-pd
[ 0.754157] Adding domain msenc-pd to PM domain host1x-pd
[ 0.754334] Adding domain nvjpg-pd to PM domain host1x-pd
[ 0.758153] falcon 54340000.vic: initialized
[ 0.759446] falcon 544c0000.nvenc: initialized
[ 0.760796] falcon 54380000.nvjpg: initialized
[ 0.765453] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 0.765577] display board info: id 0x0, fab 0x0
[ 0.765650] generic_infoframe_type: 0x87
[ 0.765788] tegradc tegradc.0: DT parsed successfully
[ 0.765845] tegradc tegradc.0: Display dc.ffffff800ab40000 registered with id=0
[ 0.766514] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 640x480 (on 0x0mm) pclk=25173906
[ 0.769780] tegradc tegradc.0: probed
[ 0.773454] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 0.778255] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 10 channels
[ 0.779264] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 0.779653] kfuse 7000fc00.kfuse: initialized
[ 0.781272] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 0.782205] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.783652] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 0.783698] vdd-cpu: 708 <--> 1322 mV at 708 mV
[ 0.784244] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 0.786017] vdd-gpu: applied init 1000000uV constraint
[ 0.786046] vdd-gpu: 708 <--> 1323 mV at 997 mV
[ 0.786473] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 0.791187] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.791400] No Device Node present for smmu client: serial8250 !!
[ 0.791436] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.791522] iommu: Adding device serial8250 to group 35
[ 0.794988] console [ttyS0] disabled
[ 0.795180] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.271241] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 1.675602] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 2.079973] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 2.081991] tegra-pcie 1003000.pcie-controller: link 0 down, ignoring
[ 2.082371] tegra-pcie 1003000.pcie-controller: PCI host bridge to bus 0000:00
[ 2.082382] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.082387] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.082393] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 2.082398] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.082801] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.091252] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 2.091258] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.091267] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[ 2.091293] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[ 2.091316] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.091327] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.091333] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.091341] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ 2.092143] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.092148] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 3.208532] console [ttyS0] enabled
[ 3.208897] Console: switching to colour frame buffer device 80x30
[ 3.212333] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 3.212664] serial-tegra 70006200.serial: RX in PIO mode
[ 3.212757] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 3.213743] [drm] Initialized
[ 3.245195] brd: module loaded
[ 3.248764] tegradc tegradc.0: fb registered
[ 3.255620] loop: module loaded
[ 3.258885] tegra_profiler: version: 1.132, samples/io: 46/26
[ 3.261765] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
[ 3.261808] tegradc tegradc.0: hdmi: tmds rate:25174K prod-setting:prod_c_hdmi_0m_54m
[ 3.262289] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[ 3.262298] tegradc tegradc.0: hdmi: BL set VIC 0
[ 3.262303] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[ 3.262627] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 3.262632] Extcon AUX1(HDMI) enable
[ 3.263241] edid invalid
[ 3.265128] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 3.265197] tegradc tegradc.1: No lt-data, using default setting
[ 3.265222] tegradc tegradc.1: No hpd-gpio in DT
[ 3.265253] tegradc tegradc.1: DT parsed successfully
[ 3.265303] tegradc tegradc.1: Display dc.ffffff800f4c0000 registered with id=1
[ 3.266721] tegradc tegradc.1: dpd enable lookup fail:-19
[ 3.270946] tegradc tegradc.1: probed
[ 3.290681] tegradc tegradc.0: nominal-pclk:25174825 parent:25173906 div:1.0 pclk:25173906 24923052~27440532
[ 3.359759] tegradc tegradc.1: fb registered
[ 3.359904] tegra_profiler: auth: init
[ 3.361358] THERMAL EST: found 2 subdevs
[ 3.361364] THERMAL EST num_resources: 0
[ 3.361370] [THERMAL EST subdev 0]
[ 3.361376] [THERMAL EST subdev 1]
[ 3.361843] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 3.361844] THERMAL EST: thz register success.
[ 3.362017] THERMAL EST: end of probe, return err: 0
[ 3.363514] hisi_sas: driver version v1.6
[ 3.370060] tegra-qspi 70410000.spi: Prod settings list not found
[ 3.371270] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 3.371278] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 3.374205] libphy: Fixed MDIO Bus: probed
[ 3.374906] tun: Universal TUN/TAP device driver, 1.6
[ 3.374908] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 3.376280] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 3.376284] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.376342] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 3.376344] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.376393] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 3.376397] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 3.376441] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 3.376445] Copyright(c) 1999 - 2017 Intel Corporation.
[ 3.381459] r8168 0000:01:00.0: enabling device (0000 -> 0003)
[ 3.381489] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 3.396384] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 3.396420] r8168 Copyright (C) 2017 Realtek NIC software team <nicfae@realtek.com>
[ 3.396420] This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
[ 3.396420] This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 3.397017] PPP generic driver version 2.4.2
[ 3.397226] PPP BSD Compression module registered
[ 3.397232] PPP Deflate Compression module registered
[ 3.397274] PPP MPPE Compression module registered
[ 3.397282] NET: Registered protocol family 24
[ 3.397354] usbcore: registered new interface driver r8152
[ 3.397397] usbcore: registered new interface driver asix
[ 3.397451] usbcore: registered new interface driver ax88179_178a
[ 3.397503] usbcore: registered new interface driver cdc_ether
[ 3.397539] usbcore: registered new interface driver net1080
[ 3.397584] usbcore: registered new interface driver cdc_subset
[ 3.397623] usbcore: registered new interface driver zaurus
[ 3.397680] usbcore: registered new interface driver cdc_ncm
[ 3.397859] VFIO - User Level meta-driver version: 0.3
[ 3.399345] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.399366] ehci-pci: EHCI PCI platform driver
[ 3.399418] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 3.399430] ohci-pci: OHCI PCI platform driver
[ 3.399472] ohci-platform: OHCI generic platform driver
[ 3.402243] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 3.402847] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 3.404042] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f9416400 id
[ 3.404150] tegra-xusb 70090000.xusb: Direct firmware load for tegra21x_xusb_firmware failed with error -2
[ 3.404153] tegra-xusb 70090000.xusb: Falling back to user helper
[ 3.405454] usbcore: registered new interface driver uas
[ 3.405512] usbcore: registered new interface driver usb-storage
[ 3.405632] usbcore: registered new interface driver usbserial
[ 3.408958] tegra-xudc-new 700d0000.xudc: device count: 1
[ 3.410195] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 3.410210] tegra-xudc-new 700d0000.xudc: vbus state: 0
[ 3.410244] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 3.410504] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 3.411222] mousedev: PS/2 mouse device common for all mice
[ 3.411304] usbcore: registered new interface driver xpad
[ 3.543662] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 3.546197] rtc rtc1: alarm rtc device
[ 3.546213] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 3.546263] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 3.546843] i2c /dev entries driver
[ 3.548528] imx219 6-0010: tegracam sensor driver:imx219_v2.0.6
[ 3.571840] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 3.571909] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[ 3.571939] imx219 6-0010: board setup failed
[ 3.572035] imx219: probe of 6-0010 failed with error -121
[ 3.573333] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.576316] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 3.576320] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 3.576771] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.576786] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 3.576794] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 3.576926] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.576934] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 3.576940] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 3.577082] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.577092] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 3.577096] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 3.577310] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 3.578098] tegra_aotag tegra-aotag: Registering sensor 0
[ 3.578151] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.578175] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.578191] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 3.578199] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 3.579131] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.579151] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[ 3.579349] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.579378] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[ 3.579840] parse_throttle_dt_data: Num cap clks = 6
[ 3.579845] parse_throttle_dt_data: clk=cclk_g type=2
[ 3.579860] parse_throttle_dt_data: clk=gpu type=4
[ 3.579886] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 3.579906] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 3.579927] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 3.579930] parse_throttle_dt_data: clk=emc type=3
[ 3.580369] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.580482] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.580635] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.581466] FAN dev name: pwm-fan
[ 3.581517] FAN:gpio request success.
[ 3.581587] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.581886] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 3.582083] pwm_fan_driver pwm-fan: fan tach request irq success
[ 3.582093] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.582175] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 3.582180] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 3.582184] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 3.582188] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 3.582192] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 3.582196] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 3.582199] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 3.582202] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 3.582206] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 3.582209] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 3.582855] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 3.583253] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 3.584166] device-mapper: uevent: version 1.0.3
[ 3.584639] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 3.589961] tegra210-cpufreq cpufreq: probe()...completed
[ 3.590684] sdhci: Secure Digital Host Controller Interface driver
[ 3.590685] sdhci: Copyright(c) Pierre Ossman
[ 3.590686] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.591199] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 3.591559] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 3.591685] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 3.595228] tegra-se 70012000.se: tegra_se_probe: complete
[ 3.595767] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.597132] usbcore: registered new interface driver usbhid
[ 3.597133] usbhid: USB HID core driver
[ 3.599281] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[ 3.599449] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 3.601204] nvpmodel: initialized successfully
[ 3.602267] usbcore: registered new interface driver snd-usb-audio
[ 3.602327] No Device Node present for smmu client: snd-soc-dummy !!
[ 3.602331] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 3.602350] iommu: Adding device snd-soc-dummy to group 36
[ 3.607924] snd_hda_codec_hdmi hdaudioC0D3: HDMI: Unknown ELD version 0
[ 3.608302] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 3.632425] OPE platform probe
[ 3.632512] OPE platform probe successful
[ 3.632893] OPE platform probe
[ 3.632976] OPE platform probe successful
[ 3.635366] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 3.658114] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 3.658243] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 3.658368] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 3.658491] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 3.658614] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 3.658736] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 3.658859] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 3.658986] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 3.659136] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 3.659261] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 3.672104] u32 classifier
[ 3.672105] Actions configured
[ 3.672174] Initializing XFRM netlink socket
[ 3.672914] NET: Registered protocol family 10
[ 3.673659] NET: Registered protocol family 17
[ 3.673669] NET: Registered protocol family 15
[ 3.673746] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 3.673794] Bluetooth: RFCOMM socket layer initialized
[ 3.673801] Bluetooth: RFCOMM ver 1.11
[ 3.673806] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.673810] Bluetooth: HIDP socket layer initialized
[ 3.673828] 9pnet: Installing 9P2000 support
[ 3.673865] Key type dns_resolver registered
[ 3.678154] Registered cp15_barrier emulation handler
[ 3.678163] Registered setend emulation handler
[ 3.679325] registered taskstats version 1
[ 3.679903] Adding domain ve2-pd to PM domain host1x-pd
[ 3.680142] Adding domain ve-pd to PM domain host1x-pd
[ 3.952755] mmc0: hw tuning done ...
[ 3.952786] mmc0: new ultra high speed SDR104 SDHC card at address 0001
[ 3.953124] mmcblk0: mmc0:0001 EB1QT 29.8 GiB
[ 3.956877] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12
[ 4.475089] tegradc tegradc.0: blank - powerdown
[ 4.478194] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 4.478197] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 4.478202] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 4.479403] isp 54600000.isp: initialized
[ 4.480338] isp 54680000.isp: initialized
[ 4.492187] clk_cbus_recalc_rate: no gbus parent
[ 4.492191] clk_cbus_round_rate: no gbus parent
[ 4.492193] clk_cbus_round_rate: no gbus parent
[ 4.492199] clk_cbus_recalc_rate: no gbus parent
[ 4.492302] clk_cbus_recalc_rate: no gbus parent
[ 4.492305] clk_cbus_round_rate: no gbus parent
[ 4.492306] clk_cbus_round_rate: no gbus parent
[ 4.492309] clk_cbus_recalc_rate: no gbus parent
[ 4.493001] tegra_dvfs: GPU-cap: registered
[ 4.493055] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 4.493056] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[ 4.493058] tegra dvfs: vdd-gpu: nominal 1058mV, offset 708000uV, step 10000uV, scaling enabled
[ 4.495099] tegra_dvfs: vdd-gpu-vts: registered
[ 4.496117] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[ 4.496726] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[ 4.497302] input: gpio-keys as /devices/gpio-keys/input/input1
[ 4.514586] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 4.514588] Extcon AUX1(HDMI) disable
[ 4.527922] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:26 UTC (946688426)
[ 4.528884] vi 54080000.vi: vi_probe: ++
[ 4.532945] vi 54080000.vi: initialized
[ 4.535253] vi 54080000.vi: subdev nvcsi--1 bound
[ 4.535502] mmcblk mmc0:0001: Card claimed for testing.
[ 4.536725] Disable partitions left on by BL
[ 4.536727] disb
[ 4.536778] bwmgr: missing cdev-type property
[ 4.536914] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.536920] DRAM derating cdev registered.
[ 4.537997] vdd-1v8: disabling
[ 4.537999] vdd-fan: disabling
[ 4.538001] vdd-usb-vbus: disabling
[ 4.538003] vdd-usb-vbus2: disabling
[ 4.538012] avdd-io-edp-1v05: disabling
[ 4.538013] vdd-usb-hub-en: disabling
[ 4.538175] ALSA device list:
[ 4.538177] #0: tegra-hda at 0x70038000 irq 83
[ 4.538178] #1: tegra-snd-t210ref-mobile-rt565x
[ 4.552023] tegradc tegradc.0: unblank
[ 4.589550] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 4.589602] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 4.594255] tegradc tegradc.0: sync windows ret = 250
[ 4.872557] tegradc tegradc.1: blank - powerdown
[ 4.879092] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 4.879093] Extcon DP: HPD disabled
[ 4.879095] hpd: hpd_switch 0
[ 4.879098] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 4.879107] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 4.879111] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 4.923455] extcon-disp-state extcon:disp-state: cable 40 state 1
[ 4.931515] Extcon HDMI: HPD enabled
[ 4.936996] tegradc tegradc.0: hdmi: plugged
[ 4.990990] extcon-disp-state extcon:disp-state: cable 47 state 0 already set.
[ 5.000019] Extcon AUX1(HDMI) disable
[ 5.011411] tegradc tegradc.0: blank - powerdown
[ 5.016263] extcon-disp-state extcon:disp-state: cable 40 state 0
[ 5.022384] Extcon HDMI: HPD disabled
[ 5.026080] tegradc tegradc.0: hdmi: unplugged
[ 5.235895] EXT4-fs (mmcblk0p1): 3 orphan inodes deleted
[ 5.241235] EXT4-fs (mmcblk0p1): recovery complete
[ 5.320495] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 5.328605] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 5.336961] devtmpfs: mounted
[ 5.343023] Freeing unused kernel memory: 8512K
[ 5.997398] tegradc tegradc.0: blank - powerdown
[ 5.997515] Host read timeout at address 5458045c
[ 6.005293] tegradc tegradc.0: unblank
[ 6.033492] systemd[1]: System time before build time, advancing clock.
[ 6.043042] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 6.043112] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 6.047494] tegradc tegradc.0: sync windows ret = 250
[ 6.111803] extcon-disp-state extcon:disp-state: cable 40 state 1
[ 6.119802] Extcon HDMI: HPD enabled
[ 6.119819] tegradc tegradc.0: hdmi: plugged
[ 6.159179] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 6.177355] cgroup: cgroup2: unknown option "nsdelegate"
[ 6.197789] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 6.224009] systemd[1]: Detected architecture arm64.
[ 6.244316] extcon-disp-state extcon:disp-state: cable 47 state 0 already set.
[ 6.253644] Extcon AUX1(HDMI) disable
[ 6.264676] tegradc tegradc.0: blank - powerdown
[ 6.269623] extcon-disp-state extcon:disp-state: cable 40 state 0
[ 6.269625] Extcon HDMI: HPD disabled
[ 6.269642] tegradc tegradc.0: hdmi: unplugged
[ 6.284593] systemd[1]: Set hostname to <tegra-ubuntu>.
[ 6.361958] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 6.379058] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 6.511512] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.519865] systemd[1]: Created slice System Slice.
[ 6.525005] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.531659] systemd[1]: Reached target Slices.
[ 6.536250] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.543023] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 6.549961] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 6.556878] systemd[1]: Listening on Journal Audit Socket.
[ 6.616953] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 7.249374] Host read timeout at address 5458045c
[ 7.262854] tegradc tegradc.0: blank - powerdown
[ 7.272388] tegradc tegradc.0: unblank
[ 7.285347] systemd-journald[1881]: Received request to flush runtime journal from PID 1
[ 7.311000] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 7.311094] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 7.314644] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 7.315537] tegradc tegradc.0: sync windows ret = 250
[ 7.401214] extcon-disp-state extcon:disp-state: cable 40 state 1
[ 7.409843] Extcon HDMI: HPD enabled
[ 7.409918] tegradc tegradc.0: hdmi: plugged
[ 7.512321] extcon-disp-state extcon:disp-state: cable 47 state 0 already set.
[ 7.522158] Extcon AUX1(HDMI) disable
[ 7.532797] tegradc tegradc.0: blank - powerdown
[ 7.537722] extcon-disp-state extcon:disp-state: cable 40 state 0
[ 7.544884] Extcon HDMI: HPD disabled
[ 7.549757] tegradc tegradc.0: hdmi: unplugged
[ 8.517407] Host read timeout at address 5458045c
[ 9.011775] random: crng init done
[ 9.015181] random: 7 urandom warning(s) missed due to ratelimiting
[ 9.769447] Host read timeout at address 5458045c
[ 11.013460] Host read timeout at address 5458045c
[ 12.249499] Host read timeout at address 5458045c
[ 13.485477] Host read timeout at address 5458045c
[ 14.729398] Host read timeout at address 5458045c
[ 15.989456] Host read timeout at address 5458045c
[ 17.245454] Host read timeout at address 5458045c
