First, According to the build kernel of kernel customization in the Jetson Linux Developer Guide, it is guided to replace nvgpu.ko. What changes if I replace it?
Is it similar in function to installing the L4T 32.7.x version of the module on the rootfs after building, as demonstrated in the following command?
$ sudo make ARCH=arm64 O=$TEGRA_KERNEL_OUT modules_install
INSTALL_MOD_PATH=/Linux_for_Tegra/rootfs/
Second, Why is there a significant difference in size between the nvgpu.ko file generated after running apply_binary.sh on the sample rootfs provided by Jetson Linux 35.4.1 and the nvgpu.ko file generated after building the default kernel source?
I understand the second question.
But in the first question, I didn’t understand for sure because I lacked knowledge.
Could you tell me exactly what file “nvgpu.ko” is?
It is just one of the ko file built out from nvidia driver source code. Rel-32 install every ko files (including nvgpu.ko) to the rootfs. Rel-35 only gives simplified steps.
Kernel has form as kernel image and kernel modules (.ko files). Ko files are also part of the kernel drivers.
Thank you !
I’m really sorry, but let me check one last time, the nvgpu.ko file contains all the drivers from the kernel build, not the module type driver for gpu, right?
If not, is there a separate command to install all drivers from kernel build like Rel-32?
That’s because building real-time kernel changes the kernel suffix, which would definitely cause kernel modules to fail to load because the version/name does not match. Otherwise, you usually don’t need to replace/re-install kernel modules after re-building kernel images if the kernel suffix is the same.
Note that the RT kernel is a modification of the existing kernel, and so this counts as needing both the base kernel Image and the modules to all need install, preferably with a new CONFIG_LOCALVERSION.
