What is right for ColorConversionCode in CVCUDA
Hi all,
Now I am testing cvtcolor() function of Python API of CVCUDA lib. However, I do not know how to select an exact code for converting from RGB to BGR image. The below is my test code:
from nvidia import nvimgcodec
import cvcuda
nvimg = decoder.read(<path_to_image>)
nvtensor = cvcuda.as_tensor(nvimg, "HWC")
nvimg = cvcuda.cvtcolor(nvimg, cvcuda.NVCV_COLOR_RBG2BGR)
My error message is:
AttributeError: type object 'cvcuda' has no attribute 'NVCV_COLOR_RGB2BGR'
Can you help me to show the right way to use this function?
Thank you so much.
Based on this for RGB2BGR I would try using:
nvimg = cvcuda.cvtcolor(nvimg, cvcuda.ColorConversion.RGB2BGR)
Thanks. I tried your suggestion and it seems working right. However, there occur a syntax error that is
Could you help me solve it?
Sorry I won’t be able to work with screenshots. I need to copy text out of your screenshot and I can’t do that. I’m not going to try typing it. Please make it easier for others to help you by posting text as text on this forum, not as screenshots.
In a nutshell, I would say that the first argument in your call is a nv image codec object, and cvcuda is expecting something else there. You created nvtensor right before this line of code. Why are you passing nvimg instead of nvtensor ?
Try this:
cc = cvcuda.cvtcolor(nvtensor, cvcuda.ColorConversion.RGB2BGR)
Oh. Sorry. I missed it. Pushing a cvcuda tensor to cvtcolor() function will solve this problem.
Thanks so much.
