I want to run the blueprint on my GCP instance. Wanted to check the number of concurrent live streams that one could run in parallel with the blueprint. The github readme says scalable but it does not give any threshold measurements on how much video data can be processed per second. When I launch the blueprint using brev, I see that the estimate is $11/hour. Does this stay the same when I push say 1000 concurrent streams into the instance?
Yes, the charge is based on the time. About the maximum number of the streams, you can stay tuned for future GA releases.
