I’m new to Nvidia Modulus and I have some questions:
- Does Modulus automatically run on GPU?
- Can Modulus run on CPU? How?
- What are the limitations for choosing a GPU for Modulus? Only the amount of VRAM?
HI @elin.hm20
Thanks for your interest in Modulus:
If PyTorch see’s GPUs, Modulus will use them
Some parts will work with CPU. If theres no GPU present, packages like Modulus Sym should default to CPU. In Modulus-Launch you may need to change the example script.
Typically VRAM is the critical spec, more is better for all deep learning. But of course also speed / flops of the GPU. Newer Nvidia GPUs will run faster naturally and maybe have some improved / different features (E.g. tensor cores). But many problems will still work just fine and converge in a timely manner on many GPU models. For development we use A100 and V100 GPUs.
In general, if a GPU is good for deep learning / PyTorch. It will be good for Modulus.
Thanks for your quick and complete response.
In the website there are some recommendations for GPUs such as A100, A30, A4000, V100, RTX 30xx.
What about A6000 model? Can this model support Modulus?
Hi @elin.hm20
The listed GPUs are ones we have officially tested ourselves and verified the examples work on. Multiple other users have been successful on GPUs outside this list, some times with a few modifications.
Thank you very much for the help.
Hi @ngeneva what do you mean by
I’m unable to run modulus-sym on cpu I’m getting this error:
RuntimeError: CUDA error: CUDA driver version is insufficient for CUDA runtime version
CUDA kernel errors might be asynchronously reported at some other API call, so the stacktrace below might be incorrect.
