What is your power management solution?
I just got my first electricity bill running a 4-node GB10 cluster at home. Not great. Maybe even bad.
So I wanted a power schedule where the nodes will sleep after 15 min of inactivity during night time, and 30 min of inactivity during daytime.
Setting it up brought nothing but headaches. The only viable solution seems to be shutting down the machine completely, then having my home lab send a signal to a smart plug on request, which restores AC power to the nodes and has them power on automatically.
This can’t be right… right? What am I missing?
yep, I came to the same conclusion. Stopping all the LLM services + ConnectX7 to save power and then start them back, that takes the same time as a cold start. So, a smart plug is the most reasonable solution.
This is disgusting behavior from a $4k a piece prosumer device
This is more of a datacenter type device where power is of no interest.
My 4 nodes plus the 10G management switch is idling at 238W according to the smart plugs. Add in a CRS 504 and it is cool 260W that is begging for a solution.
However, it is probably the 800W+ during inferance that is the main cause of your power bill.
Yes the only solution i found so far is an autoshutdown on idle + AC cutoff and restart upon demand. I run my sparks downclocked the gpu to 1400Mhz. You save with that on inference power usage with 4 spark around 200W / hour. You loose maybe 5-10% speed token output speed ( modell dependent ) - prefill suffers more slowdown but with chaching you can make it invisible in agentic loops.
This is a prosumer device aimed at homes or small organizations, and is clearly designed with performance to power consumption in mind. The GB10 community frequently pulls out the “yeah but it only uses 300 watts vs 1 bijilion watts of your setup” card.
I cap my clock speed at 2000 so I don’t get 800W. And my workload is bursty. 250w at idle is 216 kWh every month, and that’s the majority share of its power bill.
I run mine at 2000. I mainly want to cut down on idle cost. I guess smartplug it is.
It is 40W in idle if it is connected to network. 27W if no activity at all. About 50W idle with LLM running. I think there is no way to fix it.
The RTX Spark is limited to 80W so something was changed in approach after the DGX Spark was developed.
When you get smart plugs, get something like the TAPU P110 that also monitor power usage. I personally have one per node as well as one for my switch.
I already have smart plugs, and the power usage I reported in my original post was monitored through them. Probably should’ve mentioned it but I was mostly expecting conversations on power management, not power usage.
Besides turning things off there isn’t much else to do. Someone posted elsewhere how you can force the CX7 interfaces offline saving 17W of idle power per node. Thinking about it not a bad idea.
Solar panels, with battery and utilising the cheaper night fee’s to keep the battery fully charged
Btw, setting cpu scheduler to powersave will save 0.5-1W of idle power (cpupower frequency-set -g powersave).
Nvidia kernel and/or bios for spark doesn’t support S3 mode suspend, only quite useless s2idle (which i couldn’t activate anyway as something wakes up immediately). And kernel doesn’t have hibernate option which could help if BIOS had network wake-up (didn’t found that too). So, best option is full shutdown with network-controlled AC power switch.
Aww this is disheartening. I was hoping that they would wake via USB, is that not the case?
If they do, and wake-from-suspend is reliable and relatively fast my plan was to trigger a keypress via something like a raspberry pi and build some kind of proxy running on the Pi that waits for inference requests, queues them and orchestrates a wakeup / handoff.
Sounds like S3 is off the table anyway even if wake-from-USB was possible. Maybe when the laptops come out we’ll get lucky and S3 will be possible!
Since Wake-on-Lan is not supported setting the BIOS to restart after a power outage and marrying it with a smart plug is the best option I’ve been able to come up with. Though my UPS could also replace the smart plug as it has control app I can use to shutoff AC flow to my GX10s
Cheap and good
So you ended up with something like 200 kwh per month if you do not turn it off?
i have 4x Asus GX-10 and a CRS812 switch plugged into a Shelly Power strip 4. My inference goes trough a MacMini that is always on and holds a proxy-ish kinda thing that turns on the strip one outlet at a time starting with the last worker + switch then every 5 seconds turns on another GX-10.
After all are confirmed on, the script starts vLLM with the profile of the model my coding agent has requested trough the MacMini. GLM-5.2 starts serving in about 12 minutes.
Now for the power off I use another script that checks, every few seconds, all GPUs for power consumption and any SSH sessions on the head (that is the maintenance mode when I tinker with the cluster).
If power is on, GPUs are used and messages are queued in vLLM the timer keeps resetting back to 30 min. If I am logged in via SSH then the timer script pauses completely. If the units go idle the timer starts to count to 30 min.
If during any of these 30 min there’s no activity what so ever the units + the switch get a shutdown command.
When the Strip registers under 1.5W per plug (that means everything has shut down properly) it triggers a power off. All GX-10s and switch are set to wake up on AC
