we need a 200Gb Infiniband connection over about 90m and want to use existing OM4 fibers and HDR QSFP56 MMF Transceivers.
I think, we need MPO-12 polarity type B, where fibers 1 and 12, 2 and 11 and so on have to be connected (RX-TX).
Is it correct both cable ends must have two guide pins mating with two holes inside the transceiver (cable with male MPO connector) in contrast with Ethernet-MPO transceivers, which use female MPO connector cables?
If based on the product brief you still have any additional questions / inquiry, please open a Mellanox Support ticket (as you have a valid Support contract) and we will be able to assist you further. You can open a Mellanox Support ticket through the following email address → support@mellanox.com
