iphands
1
Hi all, I have a pair of Mellanox MCX353A-FCBT coming my way.
I want to setup a point to point (no switch) 40Gbe link between a workstation and server.
I was also thinking about experimenting with the 56Gb Infiniband links and NFS + RDMA.
I was digging through documentation and came across this: https://www.mellanox.com/related-docs/prod_cables/PB_MC22061xx-00x_MC22071xx-0xx_MC22101xx-00x_MCP170L-F0xx_MCP1700-B0xxx_56Gbps_QSFP+_DAC.pdf
I am kinda confused about the description column.
Do some cables support VPI and Infiniband, and others support Ethernet only?
Or does a 56Gb card support all of the above?
For example:
MC2210126-005 Mellanox® passive copper cable, ETH 40GbE, 40Gb/s, QSFP, 5m
If I buy this and setup 40GbE can I not do infiniband with the same cable?
MC2207126-004 Mellanox® passive copper cable, VPI, up to 56 Gb/s, QSFP, 4m
If I buy this can I do ethernet via VPI but not infiniband?
MC2206125-007 Mellanox® passive copper cable, IB QDR, 40 Gb/s, QSFP, 7m
If I buy this am I relegated to only Infiniband?
I guess the real question for me is… do the 56G cables work with 40GbE. I would assume yes, but because I see this in the Mellanox PDF:
It kinda seems like the MC2206125 is IB specific, the MC2207126 is VPI specific, and the MC2210126 is Ethernet specific.
I would guess the 56G cable is backwards compatible though.
Hi Ian,
Regarding the questions , please see below:
Answer - Only Ethernet
Answer - Ethernet and IB
Answer - Infiniband Only
Full list of supported cables
https://www.mellanox.com/products/interconnect/cables-configurator.php
In addition for ConnectX-3 VPI adapter please refer to the supported cables in the release notes
http://www.mellanox.com/pdf/firmware/ConnectX3-FW-2_42_5000-release_notes.pdf
Regarding MC2207126-004 it’s backward compatible.
For further questions, you can refer to our Sales department
Sales@mellanox.com
Thanks,
Samer
@Samer what about MC220731V-010?
Does that support IB and Ethernet?
Yes it’s VPI FDR, refer to the table
