I had use FPGA for HDMI video to MIPI CSI on Xavier, and it could play video by /dev/video0 on AGX Xavier.
I move this deivce tree from AGX Xavier to AGX Orin L4T R34.1.1, and driver can probe and pass the v4l2_async_register_subdev(), but it can’t see /dev/video0.
May I to know what’s difference of tegra camera platform from AGX Xavier to AGX Orin?
or any suggetion for debugging root cuase?
I change vi to tegra-capture-vi in device tree, but result are same, and can’t see /dev/video0.
I check the media0 topology, and it are empty:
# media-ctl --device /dev/media0 --print-topology
Media controller API version 5.10.65
Media device information
driver tegra-camrtc-ca
model NVIDIA Tegra Video Input Device
serial
bus info
hw revision 0x3
driver version 5.10.65
Device topology
I review the device tree and probe, and it could create /dev/video0 now.
But I can’t see video after vlc play /dev/video0, and see some tegra-capture-vi errors in dmsg log.
[ 235.744440] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 235.744714] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
Review the pix_clk_hz/serdes_pix_clk_hz for the output data rate.
Skew calibration is required if sensor or deserializer is using DPHY, and the output data rate is > 1.5Gbps.
An initiation deskew signal should be sent by sensor or deserializer to perform the skew calibration. If the deskew signals is not sent, the receiver will stall, and the capture will time out.
You can calculate the output data rate with the following equation:
Output data rate = (sensor or deserializer pixel clock in hertz) * (bits per pixel) / (number of CSI lanes)
My FPGA resolution are 1920x1080x60P(YUV422), and output data rate is below 1.5Gbps.
It could get video some time, and the rate of video success/NO video are 20%/80%.
2.I check the sensor DPHY datasheet, and which deskew mode need to set? Auto initial deskew on?
If the output data rate < 1.5Gbps you can ignore the deskew cal.
Your case could be the settle time cause the issue.
Please make sure the timing as below.
