whats is the size of extern __shared__ float share memory
i can not use sizeof…
as i know THAT the size of the array is determined at launch time
Sabbaba.
kernel_call<<<gridDim, blockDim, sharedMemSize>>>()
You specify it yourself
And you can pass that size as an integer parameter to your kernel, if the amount of shared memory to use cannot be derived from other kernel parameters.
Aaa
Yes I am starting to understand…
10x ALL
:wub: love you all External Image :wub:
