What's the right way to OC monitor HZ on linux?
I’ve been following several arch wiki documents. But none of them seem to work on nvidia closed drivers.
METHOD 1: Using a custom EDID FILE
description: I got an EDID file from nvidia and edited it with aw-edid-editor as described here. Then I use it like this and reboot.
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Philips PHL 288E2"
    HorizSync       30.0 - 140.0
    VertRefresh     40.0 - 60.0
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    BoardName      "GeForce GTX 1070"
    Option         "UseEDID"           "false"
    Option         "UseEDIDFreqs"      "false"
    Option         "NoBandWidthTest"   "true"
    Option         "ModeValidation"    "AllowNonEdidModes,NoEdidMaxPClkCheck,NoMaxPClkCheck"
    Option         "AllowDDCCI"        "true"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    30
    Option         "Stereo" "0"
    Option         "nvidiaXineramaInfoOrder" "DFP-6"
    Option         "CustomEDID" "DP-4: ~/tweaks/os-configure/misc/edid-profiles-for-screens/edid-right-4k-71hz.bin;HDMI-0: ~/tweaks/os-configure/misc/edid-profiles-for-screens/edid-left-4k-71hz.bin"
    Option         "metamodes" "HDMI-0: nvidia-auto-select +0+0 {ForceCompositionPipeline=On}, DP-4: nvidia-auto-select +3840+0 {ForceCompositionPipeline=On, AllowGSYNCCompatible=On}"
    Option         "SLI" "Off"
    Option         "MultiGPU" "Off"
    Option         "BaseMosaic" "off"
    SubSection     "Display"
        Depth      30
    EndSubSection
EndSection
Then I press alt+F2 and launch xstart – -logverbose 6 and check /var/log/xorg.0.log and there’s nothing about the EDID profile.
[   213.225] (II) event0  - Power Button: device removed
[   213.257] (II) event6  - Blue Microphones Yeti Stereo Microphone Consumer Control: device removed
[   213.310] (II) event7  - Kingsis Peripherals ZOWIE Gaming mouse: device removed
[   213.364] (II) event9  - SONiX USB DEVICE: device removed
[   213.390] (II) event10 - SONiX USB DEVICE Keyboard: device removed
[   213.430] (II) event11 - SONiX USB DEVICE System Control: device removed
[   213.457] (II) event2  - foostan H4ck3r k3yBo4rd (crkbd): device removed
[   213.497] (II) event3  - foostan H4ck3r k3yBo4rd (crkbd) Mouse: device removed
[   213.550] (II) event4  - foostan H4ck3r k3yBo4rd (crkbd) System Control: device removed
[   213.617] (II) event12 - SONiX USB DEVICE Consumer Control: device removed
[   213.644] (II) event5  - foostan H4ck3r k3yBo4rd (crkbd) Consumer Control: device removed
[   243.249] (--) NVIDIA(GPU-0): DFP-0: disconnected
[   243.249] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[   243.249] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[   243.278] (--) NVIDIA(GPU-0): Philips PHL 288E2 (DFP-1): connected
[   243.278] (--) NVIDIA(GPU-0): Philips PHL 288E2 (DFP-1): Internal TMDS
[   243.278] (--) NVIDIA(GPU-0): Philips PHL 288E2 (DFP-1): 600.0 MHz maximum pixel clock
[   243.278] (--) NVIDIA(GPU-0): DFP-2: disconnected
[   243.278] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[   243.278] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[   243.278] (--) NVIDIA(GPU-0): DFP-3: disconnected
[   243.278] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[   243.279] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[   243.279] (--) NVIDIA(GPU-0): DFP-4: disconnected
[   243.279] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[   243.279] (--) NVIDIA(GPU-0): DFP-4: 1440.0 MHz maximum pixel clock
[   243.279] (--) NVIDIA(GPU-0): DFP-5: disconnected
[   243.279] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[   243.279] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[   243.279] (--) NVIDIA(GPU-0): Philips PHL 288E2 (DFP-6): connected
[   243.279] (--) NVIDIA(GPU-0): Philips PHL 288E2 (DFP-6): Internal DisplayPort
[   243.279] (--) NVIDIA(GPU-0): Philips PHL 288E2 (DFP-6): 1440.0 MHz maximum pixel clock
[   243.280] (--) NVIDIA(GPU-0): DFP-7: disconnected
[   243.280] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[   243.280] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[   243.296] (II) NVIDIA(0): Setting mode "DP-4:3840x2160_60+3840+0{ForceCompositionPipeline=On,AllowGSYNCCompatible=On},HDMI-0:nvidia-auto-select+0+0{ForceCompositionPipeline=On}"
[   243.523] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[   243.523] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[   243.523] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[   243.523] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[   243.524] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[   243.524] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[   243.524] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[   243.524] (II) NVIDIA(0):     Config Options in the README.
[   243.592] (II) event1  - Power Button: is tagged by udev as: Keyboard
[   243.592] (II) event1  - Power Button: device is a keyboard
[   243.593] (II) event0  - Power Button: is tagged by udev as: Keyboard
[   243.593] (II) event0  - Power Button: device is a keyboard
[   243.594] (II) event6  - Blue Microphones Yeti Stereo Microphone Consumer Control: is tagged by udev as: Keyboard
[   243.594] (II) event6  - Blue Microphones Yeti Stereo Microphone Consumer Control: device is a keyboard
[   243.595] (II) event7  - Kingsis Peripherals ZOWIE Gaming mouse: is tagged by udev as: Mouse
[   243.595] (II) event7  - Kingsis Peripherals ZOWIE Gaming mouse: device set to 800 DPI
[   243.595] (II) event7  - Kingsis Peripherals ZOWIE Gaming mouse: device is a pointer
[   243.597] (II) event9  - SONiX USB DEVICE: is tagged by udev as: Keyboard
[   243.597] (II) event9  - SONiX USB DEVICE: device is a keyboard
[   243.598] (II) event10 - SONiX USB DEVICE Keyboard: is tagged by udev as: Keyboard
[   243.598] (II) event10 - SONiX USB DEVICE Keyboard: device is a keyboard
[   243.599] (II) event11 - SONiX USB DEVICE System Control: is tagged by udev as: Keyboard
[   243.599] (II) event11 - SONiX USB DEVICE System Control: device is a keyboard
[   243.601] (II) event12 - SONiX USB DEVICE Consumer Control: is tagged by udev as: Keyboard
[   243.601] (II) event12 - SONiX USB DEVICE Consumer Control: device is a keyboard
[   243.602] (II) event2  - foostan H4ck3r k3yBo4rd (crkbd): is tagged by udev as: Keyboard
[   243.602] (II) event2  - foostan H4ck3r k3yBo4rd (crkbd): device is a keyboard
[   243.603] (II) event3  - foostan H4ck3r k3yBo4rd (crkbd) Mouse: is tagged by udev as: Mouse
[   243.603] (II) event3  - foostan H4ck3r k3yBo4rd (crkbd) Mouse: device is a pointer
[   243.604] (II) event4  - foostan H4ck3r k3yBo4rd (crkbd) System Control: is tagged by udev as: Keyboard
[   243.604] (II) event4  - foostan H4ck3r k3yBo4rd (crkbd) System Control: device is a keyboard
[   243.606] (II) event5  - foostan H4ck3r k3yBo4rd (crkbd) Consumer Control: is tagged by udev as: Keyboard
[   243.606] (II) event5  - foostan H4ck3r k3yBo4rd (crkbd) Consumer Control: device is a keyboard
The profile is not applied, nvidia seems to ignore it. (why?)
METHOD 2:
description: I try to add an unsuported resolution like described here. So I run
cvt 3840 2160 70
xrandr --newmode "3840x2160_70.00"  839.00  3840 4160 4584 5328  2160 2163 2168 2250 -hsync +vsync
xrandr --addmode DP-4 "3840x2160_70.00"
This last line fails with the error:
X Error of failed request: BadMatch
At this point arch wiki basically recommends you to use nouveau drivers instead.
So… I’m out of options. ideas?
Solved: My system was using /etc/X11/xorg.conf.d/90-mhwd.conf instead of /etc/X11/xorg.conf
Manjaro I3.
You set a relative path with ~ for the custom edid, which likely doesn’t work. Please only use absolute paths.
In your second attempt, you’ll also have to set IgnoreEDID and add a monitor section with H/V frequencies to be able to set custom modelines.
