When i use the nvcc compiler,i can't use the cuda
i want to try the cuda,while in hello.cu i have program like below,while i canโ€™t have the right answer
after the compile and i got this
add:
cudaDeviceSynchronize();
before the cudaDeviceReset(); line.
then try:
compute-sanitizer ./hello
Hi,Robert,thank you for you answer,now i use the compute-snitizer,and i got the question below
so whether is the question of the nvcc,when i use the nvidia-smi,i got this
and i use the
,how can i fix it?
install the latest driver for your GPU
or switch to a CUDA version that is 12.0 or older.
thank,i use the Nvtoolkit12.0 and the problem was solved
