Hi! I want to use cuda11.7 and I have updated the latest NV driver. But I meet this!
(sorry the language)
Could you help me? Thank you!!!
Interesting. Which GeForce driver version are you using? Can you successfully install the GeForce driver?
Have you tried to use DDU (Display Driver Uninstaller) to remove the driver and reinstall it, then install CUDA?
Thank you very much!!! I find out the problem and solved it. I just remove all the NVIDIA software and then install the cuda11.7. Previously I did not remove all of them and failed.
