There is a “sampleINT8” in tensorrt,
1. how to control the IBuilder to call IInt8Calibrator::readCalibrationCache or IInt8Calibrator::WriteCalibrationCache?
First time we need to generate the CalibrationTable file, it seems using the “search” option in sampleINT8 command line to generate one. anyone can confirm this one?
I read and debugged the code, it seems IBuilder::buildCudaEngine call IInt8Calibrator::WriteCalibrationCache when IInt8Calibrator::readCalibrationCache return nullptr.
2. Does ICudaEngine serialized calibration table to gieModelStream, and then no need IInt8Calibrator in deserializeCudaEngine?
3. Why turn off search when using CalibrationAlgoType::kENTROPY_CALIBRATION algorithm?
It is the code:
//sampleINT8.cpp
int main(int argc, char** argv)
if (calibrationAlgo == CalibrationAlgoType::kENTROPY_CALIBRATION)
<b>search = false</b>;
I just commented these out, and it doesn’t crash. anyone has reasons?
//sampleINT8.cpp
int batchSize = 100, firstScoreBatch = 100, nbScoreBatches = 400; // by default we score over 40K images starting at 10000, so we don't score those used to search calibration
4. what’s the recommend input count(40K images) for INT8 calibration, and can we use different batch number with calibration and inference?
different means: I use batchSize=100 for generate the CalibrationTable, but call IExecutionContext::execute(batchSize = 4, …).
