When the camera image is obtained through v4l2, an error is reported, which causes the system to restart
HI,
I use jetpack_4_4(32.4.3, Xavier. When the camera image is obtained through v4l2, an error is reported, which causes the system to restart. I use trace to record camera logs and pstore to record system restart logs.
Here is the camera trace log
kworker/0:2-1375 [000] … 219.927838: rtcpu_vinotify_event: tstamp:7204786328 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:7204754591 data:0x021c0200
kworker/0:2-1375 [000] … 219.927839: rtcpu_vinotify_event: tstamp:7204786468 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:7213855360 data:0x01020002
kworker/0:2-1375 [000] … 219.927840: rtcpu_vinotify_event: tstamp:7204786613 tag:CSIMUX_FRAME channel:0x01 frame:0 vi_tstamp:7204755183 data:0x00600264
kworker/0:2-1375 [000] … 219.927840: rtcpu_vinotify_event: tstamp:7204786738 tag:FS channel:0x01 frame:0 vi_tstamp:7204757790 data:0x00000014
kworker/0:2-1375 [000] … 219.927841: rtcpu_nvcsi_intr: tstamp:7204796699 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000002
kworker/0:2-1375 [000] … 219.927841: rtcpu_nvcsi_intr: tstamp:7204796699 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000010
kworker/0:2-1375 [000] … 219.927842: rtcpu_nvcsi_intr: tstamp:7204796699 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000002
kworker/0:2-1375 [000] … 219.927842: rtcpu_nvcsi_intr: tstamp:7204796699 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:0 st:0 vc:0 status:0x00000010
kworker/0:2-1375 [000] … 219.927842: rtcpu_nvcsi_intr: tstamp:7204797613 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000002
kworker/0:2-1375 [000] … 219.927842: rtcpu_nvcsi_intr: tstamp:7204797613 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927843: rtcpu_nvcsi_intr: tstamp:7204797613 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000006
kworker/0:2-1375 [000] … 219.927843: rtcpu_nvcsi_intr: tstamp:7204797613 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927844: rtcpu_nvcsi_intr: tstamp:7204797613 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927844: rtcpu_nvcsi_intr: tstamp:7204798666 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000006
kworker/0:2-1375 [000] … 219.927844: rtcpu_nvcsi_intr: tstamp:7204798666 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000004
kworker/0:2-1375 [000] … 219.927845: rtcpu_nvcsi_intr: tstamp:7204798666 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927845: rtcpu_nvcsi_intr: tstamp:7204798666 class:GLOBAL type:PHY_INTR0 phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927845: rtcpu_nvcsi_intr: tstamp:7204798666 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000006
kworker/0:2-1375 [000] … 219.927846: rtcpu_nvcsi_intr: tstamp:7204798666 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000006
kworker/0:2-1375 [000] … 219.927846: rtcpu_nvcsi_intr: tstamp:7204798666 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927846: rtcpu_nvcsi_intr: tstamp:7204798666 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927846: rtcpu_nvcsi_intr: tstamp:7204800179 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000002
kworker/0:2-1375 [000] … 219.927847: rtcpu_nvcsi_intr: tstamp:7204800179 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000006
kworker/0:2-1375 [000] … 219.927847: rtcpu_nvcsi_intr: tstamp:7204800179 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927847: rtcpu_nvcsi_intr: tstamp:7204800179 class:GLOBAL type:PHY_INTR0 phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927848: rtcpu_nvcsi_intr: tstamp:7204800179 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000006
kworker/0:2-1375 [000] … 219.927848: rtcpu_nvcsi_intr: tstamp:7204800179 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927848: rtcpu_nvcsi_intr: tstamp:7204800179 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927849: rtcpu_nvcsi_intr: tstamp:7204801534 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000004
kworker/0:2-1375 [000] … 219.927849: rtcpu_nvcsi_intr: tstamp:7204801534 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000006
kworker/0:2-1375 [000] … 219.927849: rtcpu_nvcsi_intr: tstamp:7204801534 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927850: rtcpu_nvcsi_intr: tstamp:7204801534 class:GLOBAL type:PHY_INTR0 phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927850: rtcpu_nvcsi_intr: tstamp:7204801534 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000002
kworker/0:2-1375 [000] … 219.927850: rtcpu_nvcsi_intr: tstamp:7204801534 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000006
kworker/0:2-1375 [000] … 219.927851: rtcpu_nvcsi_intr: tstamp:7204801534 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927851: rtcpu_nvcsi_intr: tstamp:7204801534 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927851: rtcpu_nvcsi_intr: tstamp:7204803049 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000006
kworker/0:2-1375 [000] … 219.927852: rtcpu_nvcsi_intr: tstamp:7204803049 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000002
kworker/0:2-1375 [000] … 219.927852: rtcpu_nvcsi_intr: tstamp:7204803049 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927852: rtcpu_nvcsi_intr: tstamp:7204803049 class:GLOBAL type:PHY_INTR0 phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927853: rtcpu_nvcsi_intr: tstamp:7204803049 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000004
kworker/0:2-1375 [000] … 219.927853: rtcpu_nvcsi_intr: tstamp:7204803049 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000006
kworker/0:2-1375 [000] … 219.927853: rtcpu_nvcsi_intr: tstamp:7204803049 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927854: rtcpu_nvcsi_intr: tstamp:7204803049 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927854: rtcpu_nvcsi_intr: tstamp:7204804554 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000006
kworker/0:2-1375 [000] … 219.927854: rtcpu_nvcsi_intr: tstamp:7204804554 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000004
kworker/0:2-1375 [000] … 219.927855: rtcpu_nvcsi_intr: tstamp:7204804554 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927855: rtcpu_nvcsi_intr: tstamp:7204804554 class:GLOBAL type:PHY_INTR0 phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927855: rtcpu_nvcsi_intr: tstamp:7204804554 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000006
kworker/0:2-1375 [000] … 219.927856: rtcpu_nvcsi_intr: tstamp:7204804554 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000006
kworker/0:2-1375 [000] … 219.927856: rtcpu_nvcsi_intr: tstamp:7204804554 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927856: rtcpu_nvcsi_intr: tstamp:7204804554 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927857: rtcpu_nvcsi_intr: tstamp:7204806061 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000006
kworker/0:2-1375 [000] … 219.927857: rtcpu_nvcsi_intr: tstamp:7204806061 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000006
kworker/0:2-1375 [000] … 219.927857: rtcpu_nvcsi_intr: tstamp:7204806061 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927858: rtcpu_nvcsi_intr: tstamp:7204806061 class:GLOBAL type:PHY_INTR0 phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927858: rtcpu_nvcsi_intr: tstamp:7204806061 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000006
kworker/0:2-1375 [000] … 219.927858: rtcpu_nvcsi_intr: tstamp:7204806061 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000006
kworker/0:2-1375 [000] … 219.927859: rtcpu_nvcsi_intr: tstamp:7204806061 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927859: rtcpu_nvcsi_intr: tstamp:7204806061 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927859: rtcpu_nvcsi_intr: tstamp:7204807574 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000002
kworker/0:2-1375 [000] … 219.927860: rtcpu_nvcsi_intr: tstamp:7204807574 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000006
kworker/0:2-1375 [000] … 219.927860: rtcpu_nvcsi_intr: tstamp:7204807574 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927860: rtcpu_nvcsi_intr: tstamp:7204807574 class:GLOBAL type:PHY_INTR0 phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927861: rtcpu_nvcsi_intr: tstamp:7204807574 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000006
kworker/0:2-1375 [000] … 219.927861: rtcpu_nvcsi_intr: tstamp:7204807574 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927861: rtcpu_nvcsi_intr: tstamp:7204807574 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927862: rtcpu_nvcsi_intr: tstamp:7204808962 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000004
kworker/0:2-1375 [000] … 219.927862: rtcpu_nvcsi_intr: tstamp:7204808962 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000006
kworker/0:2-1375 [000] … 219.927862: rtcpu_nvcsi_intr: tstamp:7204808962 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927863: rtcpu_nvcsi_intr: tstamp:7204808962 class:GLOBAL type:PHY_INTR0 phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927863: rtcpu_nvcsi_intr: tstamp:7204808962 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000002
kworker/0:2-1375 [000] … 219.927863: rtcpu_nvcsi_intr: tstamp:7204808962 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000006
kworker/0:2-1375 [000] … 219.927864: rtcpu_nvcsi_intr: tstamp:7204808962 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927864: rtcpu_nvcsi_intr: tstamp:7204808962 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927864: rtcpu_nvcsi_intr: tstamp:7204810467 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000006
kworker/0:2-1375 [000] … 219.927865: rtcpu_nvcsi_intr: tstamp:7204810467 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000006
kworker/0:2-1375 [000] … 219.927865: rtcpu_nvcsi_intr: tstamp:7204810467 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927866: rtcpu_nvcsi_intr: tstamp:7204810467 class:GLOBAL type:PHY_INTR0 phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927867: rtcpu_nvcsi_intr: tstamp:7204810467 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000004
kworker/0:2-1375 [000] … 219.927867: rtcpu_nvcsi_intr: tstamp:7204810467 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000006
kworker/0:2-1375 [000] … 219.927867: rtcpu_nvcsi_intr: tstamp:7204810467 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927868: rtcpu_nvcsi_intr: tstamp:7204810467 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927868: rtcpu_nvcsi_intr: tstamp:7204811979 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000006
kworker/0:2-1375 [000] … 219.927868: rtcpu_nvcsi_intr: tstamp:7204811979 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927869: rtcpu_nvcsi_intr: tstamp:7204811979 class:GLOBAL type:PHY_INTR0 phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927869: rtcpu_nvcsi_intr: tstamp:7204811979 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000006
kworker/0:2-1375 [000] … 219.927869: rtcpu_nvcsi_intr: tstamp:7204811979 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000006
kworker/0:2-1375 [000] … 219.927870: rtcpu_nvcsi_intr: tstamp:7204811979 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927870: rtcpu_nvcsi_intr: tstamp:7204813177 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000002
kworker/0:2-1375 [000] … 219.927870: rtcpu_nvcsi_intr: tstamp:7204813177 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000006
kworker/0:2-1375 [000] … 219.927870: rtcpu_nvcsi_intr: tstamp:7204813177 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927871: rtcpu_nvcsi_intr: tstamp:7204813177 class:GLOBAL type:PHY_INTR0 phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927871: rtcpu_nvcsi_intr: tstamp:7204813177 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000006
kworker/0:2-1375 [000] … 219.927871: rtcpu_nvcsi_intr: tstamp:7204813177 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927872: rtcpu_nvcsi_intr: tstamp:7204813177 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927872: rtcpu_nvcsi_intr: tstamp:7204814528 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000004
kworker/0:2-1375 [000] … 219.927872: rtcpu_nvcsi_intr: tstamp:7204814528 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000006
kworker/0:2-1375 [000] … 219.927873: rtcpu_nvcsi_intr: tstamp:7204814528 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927873: rtcpu_nvcsi_intr: tstamp:7204814528 class:GLOBAL type:PHY_INTR0 phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927873: rtcpu_nvcsi_intr: tstamp:7204814528 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000002
kworker/0:2-1375 [000] … 219.927874: rtcpu_nvcsi_intr: tstamp:7204814528 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000006
kworker/0:2-1375 [000] … 219.927874: rtcpu_nvcsi_intr: tstamp:7204814528 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927874: rtcpu_nvcsi_intr: tstamp:7204814528 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927875: rtcpu_nvcsi_intr: tstamp:7204816034 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000006
kworker/0:2-1375 [000] … 219.927875: rtcpu_nvcsi_intr: tstamp:7204816034 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000006
kworker/0:2-1375 [000] … 219.927875: rtcpu_nvcsi_intr: tstamp:7204816034 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927876: rtcpu_nvcsi_intr: tstamp:7204816034 class:GLOBAL type:PHY_INTR0 phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927876: rtcpu_nvcsi_intr: tstamp:7204816034 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000004
kworker/0:2-1375 [000] … 219.927876: rtcpu_nvcsi_intr: tstamp:7204816034 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000006
kworker/0:2-1375 [000] … 219.927877: rtcpu_nvcsi_intr: tstamp:7204816034 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927877: rtcpu_nvcsi_intr: tstamp:7204816034 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927877: rtcpu_nvcsi_intr: tstamp:7204817539 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000006
kworker/0:2-1375 [000] … 219.927878: rtcpu_nvcsi_intr: tstamp:7204817539 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927878: rtcpu_nvcsi_intr: tstamp:7204817539 class:GLOBAL type:PHY_INTR0 phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927878: rtcpu_nvcsi_intr: tstamp:7204817539 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000006
kworker/0:2-1375 [000] … 219.927879: rtcpu_nvcsi_intr: tstamp:7204817539 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000006
kworker/0:2-1375 [000] … 219.927879: rtcpu_nvcsi_intr: tstamp:7204817539 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927879: rtcpu_nvcsi_intr: tstamp:7204818737 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000002
kworker/0:2-1375 [000] … 219.927880: rtcpu_nvcsi_intr: tstamp:7204818737 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000006
kworker/0:2-1375 [000] … 219.927880: rtcpu_nvcsi_intr: tstamp:7204818737 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927880: rtcpu_nvcsi_intr: tstamp:7204818737 class:GLOBAL type:PHY_INTR0 phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927881: rtcpu_nvcsi_intr: tstamp:7204818737 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000006
kworker/0:2-1375 [000] … 219.927881: rtcpu_nvcsi_intr: tstamp:7204818737 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927881: rtcpu_nvcsi_intr: tstamp:7204818737 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927882: rtcpu_nvcsi_intr: tstamp:7204820090 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000004
kworker/0:2-1375 [000] … 219.927882: rtcpu_nvcsi_intr: tstamp:7204820090 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000006
kworker/0:2-1375 [000] … 219.927882: rtcpu_nvcsi_intr: tstamp:7204820090 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927883: rtcpu_nvcsi_intr: tstamp:7204820090 class:GLOBAL type:PHY_INTR0 phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927883: rtcpu_nvcsi_intr: tstamp:7204820090 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000002
kworker/0:2-1375 [000] … 219.927883: rtcpu_nvcsi_intr: tstamp:7204820090 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000006
kworker/0:2-1375 [000] … 219.927884: rtcpu_nvcsi_intr: tstamp:7204820090 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927884: rtcpu_nvcsi_intr: tstamp:7204820090 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927884: rtcpu_nvcsi_intr: tstamp:7204821595 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000006
kworker/0:2-1375 [000] … 219.927885: rtcpu_nvcsi_intr: tstamp:7204821595 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000006
kworker/0:2-1375 [000] … 219.927885: rtcpu_nvcsi_intr: tstamp:7204821595 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927885: rtcpu_nvcsi_intr: tstamp:7204821595 class:GLOBAL type:PHY_INTR0 phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927886: rtcpu_nvcsi_intr: tstamp:7204821595 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000004
kworker/0:2-1375 [000] … 219.927886: rtcpu_nvcsi_intr: tstamp:7204821595 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000006
kworker/0:2-1375 [000] … 219.927886: rtcpu_nvcsi_intr: tstamp:7204821595 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927887: rtcpu_nvcsi_intr: tstamp:7204821595 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927887: rtcpu_nvcsi_intr: tstamp:7204823107 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000006
kworker/0:2-1375 [000] … 219.927887: rtcpu_nvcsi_intr: tstamp:7204823107 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927888: rtcpu_nvcsi_intr: tstamp:7204823107 class:GLOBAL type:PHY_INTR0 phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927888: rtcpu_nvcsi_intr: tstamp:7204823107 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000006
kworker/0:2-1375 [000] … 219.927888: rtcpu_nvcsi_intr: tstamp:7204823107 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000006
kworker/0:2-1375 [000] … 219.927889: rtcpu_nvcsi_intr: tstamp:7204823107 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927889: rtcpu_nvcsi_intr: tstamp:7204824300 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000002
kworker/0:2-1375 [000] … 219.927889: rtcpu_nvcsi_intr: tstamp:7204824300 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000006
kworker/0:2-1375 [000] … 219.927890: rtcpu_nvcsi_intr: tstamp:7204824300 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927890: rtcpu_nvcsi_intr: tstamp:7204824300 class:GLOBAL type:PHY_INTR0 phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927890: rtcpu_nvcsi_intr: tstamp:7204824300 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000006
kworker/0:2-1375 [000] … 219.927890: rtcpu_nvcsi_intr: tstamp:7204824300 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927891: rtcpu_nvcsi_intr: tstamp:7204824300 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927891: rtcpu_nvcsi_intr: tstamp:7204825651 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000004
kworker/0:2-1375 [000] … 219.927891: rtcpu_nvcsi_intr: tstamp:7204825651 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000006
kworker/0:2-1375 [000] … 219.927892: rtcpu_nvcsi_intr: tstamp:7204825651 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927892: rtcpu_nvcsi_intr: tstamp:7204825651 class:GLOBAL type:PHY_INTR0 phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.927892: rtcpu_nvcsi_intr: tstamp:7204825651 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000006
kworker/0:2-1375 [000] … 219.755168: rtcpu_nvcsi_intr: tstamp:7199403448 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000004
kworker/0:2-1375 [000] … 219.755169: rtcpu_nvcsi_intr: tstamp:7199403448 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.755170: rtcpu_nvcsi_intr: tstamp:7199403448 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:0 st:0 vc:0 status:0x00000010
kworker/0:2-1375 [000] … 219.755172: rtcpu_vinotify_error: tstamp:7199404147 tag:CSIMUX_STREAM channel:0x00 frame:256 vi_tstamp:7199293067 data:0x00010000
kworker/0:2-1375 [000] … 219.755174: rtcpu_nvcsi_intr: tstamp:7199404217 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000010
kworker/0:2-1375 [000] … 219.755175: rtcpu_nvcsi_intr: tstamp:7199404217 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:0 st:0 vc:0 status:0x00000010
kworker/0:2-1375 [000] … 219.755176: rtcpu_nvcsi_intr: tstamp:7199404736 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000004
kworker/0:2-1375 [000] … 219.755177: rtcpu_nvcsi_intr: tstamp:7199404736 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000010
kworker/0:2-1375 [000] … 219.755178: rtcpu_nvcsi_intr: tstamp:7199404736 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000004
kworker/0:2-1375 [000] … 219.755179: rtcpu_nvcsi_intr: tstamp:7199404736 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:0 st:0 vc:0 status:0x00000100
kworker/0:2-1375 [000] … 219.755180: rtcpu_nvcsi_intr: tstamp:7199404736 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.755181: rtcpu_nvcsi_intr: tstamp:7199405782 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000100
kworker/0:2-1375 [000] … 219.755182: rtcpu_nvcsi_intr: tstamp:7199405782 class:GLOBAL type:PHY_INTR0 phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.755183: rtcpu_nvcsi_intr: tstamp:7199405782 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:0 st:0 vc:0 status:0x00000100
kworker/0:2-1375 [000] … 219.755185: rtcpu_nvcsi_intr: tstamp:7199405782 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.755186: rtcpu_nvcsi_intr: tstamp:7199406608 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000004
kworker/0:2-1375 [000] … 219.755187: rtcpu_nvcsi_intr: tstamp:7199406608 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000100
kworker/0:2-1375 [000] … 219.755188: rtcpu_nvcsi_intr: tstamp:7199406608 class:GLOBAL type:PHY_INTR0 phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.755189: rtcpu_nvcsi_intr: tstamp:7199406608 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000004
kworker/0:2-1375 [000] … 219.755190: rtcpu_nvcsi_intr: tstamp:7199406608 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.755191: rtcpu_nvcsi_intr: tstamp:7199407653 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000010
kworker/0:2-1375 [000] … 219.755192: rtcpu_nvcsi_intr: tstamp:7199407998 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000010
kworker/0:2-1375 [000] … 219.755193: rtcpu_nvcsi_intr: tstamp:7199407998 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000004
kworker/0:2-1375 [000] … 219.755194: rtcpu_nvcsi_intr: tstamp:7199407998 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:0 st:0 vc:0 status:0x00000010
kworker/0:2-1375 [000] … 219.755195: rtcpu_nvcsi_intr: tstamp:7199408700 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000004
kworker/0:2-1375 [000] … 219.755196: rtcpu_nvcsi_intr: tstamp:7199408700 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.755197: rtcpu_nvcsi_intr: tstamp:7199408700 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:0 st:0 vc:0 status:0x00000100
kworker/0:2-1375 [000] … 219.755199: rtcpu_nvcsi_intr: tstamp:7199408700 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.755200: rtcpu_nvcsi_intr: tstamp:7199409567 class:GLOBAL type:PHY_INTR0 phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.755201: rtcpu_nvcsi_intr: tstamp:7199409567 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:0 st:0 vc:0 status:0x00000100
kworker/0:2-1375 [000] … 219.755202: rtcpu_nvcsi_intr: tstamp:7199409567 class:CORRECTABLE_ERR type:PHY_INTR phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.755203: rtcpu_nvcsi_intr: tstamp:7199410236 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000004
kworker/0:2-1375 [000] … 219.755204: rtcpu_nvcsi_intr: tstamp:7199410236 class:GLOBAL type:PHY_INTR0 phy:2 cil:0 st:0 vc:0 status:0x00000100
kworker/0:2-1375 [000] … 219.755205: rtcpu_nvcsi_intr: tstamp:7199410236 class:GLOBAL type:PHY_INTR0 phy:2 cil:1 st:0 vc:0 status:0x00000110
kworker/0:2-1375 [000] … 219.755206: rtcpu_nvcsi_intr: tstamp:7199410236 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:1 status:0x00000004
Here is the pstore system restart log
[ 135.247584] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 135.247743] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 135.247881] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 135.270787] tegra-capture-ivc ivc-bc00000.rtcpu:ivccontrol@3: No callback found for msg id: 0x39
[ 135.270980] tegra-capture-ivc ivc-bc00000.rtcpu:ivccontrol@3: No callback found for msg id: 0x41
[ 135.271117] tegra-capture-ivc ivc-bc00000.rtcpu:ivccontrol@3: No callback found for msg id: 0x37
[ 144.440070] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 144.440241] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 233.812132] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 233.812291] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 233.812431] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 243.032586] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 243.120888] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 6292068
[ 243.154181] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 6291556
[ 243.187540] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 6291556
[ 243.220823] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 512
[ 243.254180] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 164
[ 243.320860] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 6292068
[ 243.321044] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 243.354238] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 6291556
[ 243.387519] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 6291556
[ 243.420886] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 512
[ 243.454228] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 164
[ 243.685224] CPU6: SError detected, daif=1c0, spsr=0x80c000c5, mpidr=80000300, esr=be000000
[ 243.685246] CPU4: SError detected, daif=1c0, spsr=0x40c000c5, mpidr=80000200, esr=be000000
[ 243.685251] CPU5: SError detected, daif=1c0, spsr=0x40c000c5, mpidr=80000201, esr=be000000
[ 243.685261] CPU2: SError detected, daif=1c0, spsr=0x40c000c5, mpidr=80000100, esr=be000000
[ 243.685267] CPU3: SError detected, daif=1c0, spsr=0x40c000c5, mpidr=80000101, esr=be000000
[ 243.685279] CPU0: SError detected, daif=1c0, spsr=0x40c000c5, mpidr=80000000, esr=be000000
[ 243.685285] CPU1: SError detected, daif=1c0, spsr=0x40c000c5, mpidr=80000001, esr=be000000
[ 243.685290] CPU7: SError detected, daif=140, spsr=0x60400145, mpidr=80000301, esr=be000000
[ 243.685321] **************************************
[ 243.685324] * For more Internal Decode Help
[ 243.685327] * http://nv/cbberr
[ 243.685329] * NVIDIA userID is required to access
[ 243.685330] **************************************
[ 243.685333] CPU:4, Error:RCE-NOC
[ 243.685337] Error Logger : 1
[ 243.685349] ErrLog0 : 0x80030600
[ 243.685352] Transaction Type : RD - Read, Incrementing
[ 243.685357] Error Code : TMO
[ 243.685360] Error Source : Target NIU
[ 243.685362] Error Description : Target time-out error
[ 243.685364] Packet header Lock : 0
[ 243.685366] Packet header Len1 : 3
[ 243.685368] NOC protocol version : version >= 2.7
[ 243.685371] ErrLog1 : 0x157600
[ 243.685372] ErrLog2 : 0x0
[ 243.685375] RouteId : 0x157600
[ 243.685378] InitFlow : cpu_p_i/I/0
[ 243.685380] Targflow : cbb_t/T/0
[ 243.685382] TargSubRange : 27
[ 243.685384] SeqId : 0
[ 243.685386] ErrLog3 : 0x5c01400
[ 243.685389] ErrLog4 : 0x0
[ 243.685430] Address : 0x15c01400 (unknown device)
[ 243.685432] ErrLog5 : 0x387e31
[ 243.685435] Master ID : RCE
[ 243.685437] Security Group(GRPSEC): 0x3f
[ 243.685440] Cache : 0x1 – Device
[ 243.685443] Protection : 0x3 – Privileged, Non-Secure, Data Access
[ 243.685445] FALCONSEC : 0x0
[ 243.685447] Virtual Queuing Channel(VQC): 0x0
[ 243.685452] **************************************
[ 243.685468] **************************************
[ 243.685469] * For more Internal Decode Help
[ 243.685471] * http://nv/cbberr
[ 243.685473] * NVIDIA userID is required to access
[ 243.685475] **************************************
[ 243.685477] CPU:4, Error:CBB-NOC
[ 243.685479] Error Logger : 1
[ 243.685488] ErrLog0 : 0x80030600
[ 243.685490] Transaction Type : RD - Read, Incrementing
[ 243.685492] Error Code : TMO
[ 243.685495] Error Source : Target NIU
[ 243.685498] Error Description : Target time-out error
[ 243.685500] Packet header Lock : 0
[ 243.685502] Packet header Len1 : 3
[ 243.685504] NOC protocol version : version >= 2.7
[ 243.685506] ErrLog1 : 0x9528aa
[ 243.685508] ErrLog2 : 0x0
[ 243.685510] RouteId : 0x9528aa
[ 243.685513] InitFlow : rce_p2ps/I/rce_p2ps
[ 243.685515] Targflow : host1x_p2pm/T/host1x_p2pm
[ 243.685517] TargSubRange : 20
[ 243.685519] SeqId : 0
[ 243.685521] ErrLog3 : 0x1400
[ 243.685524] ErrLog4 : 0x0
[ 243.685535] Address : 0x15c01400 (unknown device)
[ 243.685537] ErrLog5 : 0x2af0fc71
[ 243.685540] Non-Modify : 0x1
[ 243.685542] AXI ID : 0x55
[ 243.685544] Master ID : RCE
[ 243.685546] Security Group(GRPSEC): 0x3f
[ 243.685548] Cache : 0x1 – Device
[ 243.685551] Protection : 0x3 – Privileged, Non-Secure, Data Access
[ 243.685553] FALCONSEC : 0x0
[ 243.685556] Virtual Queuing Channel(VQC): 0x0
[ 243.685559] **************************************
[ 243.685562] ras_ccplex_serr_callback: Scanning CCPLEX Error Records for Uncorrectable Errors
[ 243.685592] **************************************
[ 243.685595] RAS Error in SCF:IOB, ERRSELR_EL1=1025:
[ 243.685597] Status = 0xf4009604
[ 243.685599] IERR = CBB Interface Error: 0x96
[ 243.685602] SERR = Assertion Failure: 0x4
[ 243.685603] Uncorrectable (this is fatal)
[ 243.685612] MISC0 = 0x40
[ 243.685613] MISC1 = 0x264e4444e3
[ 243.685618] ADDR = 0x80000000152000dc
[ 243.685626] **************************************
[ 243.685631] ras_corecluster_serr_callback:Scanning CoreCluster Error Records for Uncorrectable Errors
[ 243.685696] **************************************
[ 243.685698] RAS Error in L2, ERRSELR_EL1=560:
[ 243.685700] Status = 0xfc006612
[ 243.685702] IERR = SCF to L2 Slave Error Read: 0x66
[ 243.685705] SERR = Error response from slave: 0x12
[ 243.685706] Overflow (there may be more errors) - Uncorrectable
[ 243.685708] Uncorrectable (this is fatal)
[ 243.685716] MISC0 = 0x100000000400000
[ 243.685718] MISC1 = 0x40240000000
[ 243.685722] ADDR = 0x80000000152000dc
[ 243.685729] **************************************
[ 243.685740] ras_core_serr_callback: Scanning Core Error Records for Uncorrectable Errors
[ 243.685885] Bad mode in Error handler detected on CPU4, code 0xbe000000 – SError
[ 243.685889] Internal error: Oops - bad mode: 0 [#1] PREEMPT SMP
[ 243.685922] Modules linked in: fuse bnep zram option usb_wwan overlay iwldvm mac80211 iwlwifi cfg80211 bluedroid_pm ip_tables x_tables
[ 243.685943] CPU: 4 PID: 0 Comm: swapper/4 Not tainted 4.9.140-tegra #34
[ 243.685950] Hardware name: Jetson-AGX (DT)
[ 243.685954] task: ffffffc7dbc55400 task.stack: ffffffc7dbc6c000
[ 243.685956] **************************************
[ 243.685958] * For more Internal Decode Help
[ 243.685960] * http://nv/cbberr
[ 243.685962] * NVIDIA userID is required to access
[ 243.685963] **************************************
[ 243.685964] PC is at tegra_read_chipid+0x58/0xa8
[ 243.685967] CPU:5, Error:CBB-NOC
[ 243.685968] LR is at tegra_read_chipid+0x28/0xa8
[ 243.685973] Error Logger : 1
[ 243.685975] pc : [] lr : [] pstate: 40c000c5
[ 243.685977] sp : ffffffc7dbc6fe50
[ 243.685991] x29: ffffffc7dbc6fe50
[ 243.685991] ErrLog0 : 0x80030600
[ 243.685999] x28: 0000000000000001 [ 243.685999] Transaction Type : RD - Read, Incrementing
[ 243.686002] Error Code : TMO
[ 243.686008] x27: ffffff8009fd6000
[ 243.686009] Error Source : Target NIU
[ 243.686016] x26: ffffff800996aac8 [ 243.686018] Error Description : Target time-out error
[ 243.686021] Packet header Lock : 0
[ 243.686027] x25: 0000000000000000
[ 243.686027] Packet header Len1 : 3
[ 243.686034] x24: 00000038b3e3af60 [ 243.686034] NOC protocol version : version >= 2.7
[ 243.686037] ErrLog1 : 0x350e26
[ 243.686043] x23: ffffff800a1581e8
[ 243.686043] ErrLog2 : 0x0
[ 243.686049] x22: ffffffc7ffd27ad0 [ 243.686050] RouteId : 0x350e26
[ 243.686052] InitFlow : ccroc_p2ps/I/ccroc_p2ps
[ 243.686059] x21: ffffff800a158200
[ 243.686059] Targflow : host1x_p2pm/T/host1x_p2pm
[ 243.686066] x20: ffffff800a321548 [ 243.686067] TargSubRange : 7
[ 243.686069] SeqId : 0
[ 243.686081] x19: ffffff800a321548
[ 243.686081] ErrLog3 : 0xdc
[ 243.686093] x18: 0000007f87b11a70 [ 243.686093] ErrLog4 : 0x0
[ 243.686106] x17: 0000007f87a8d738 x16: ffffff80082b1740
[ 243.686112] x15: 0000000000000000
[ 243.686113] Address : 0x152000dc (unknown device)
[ 243.686120] x14: 0004bbfaf55bd0b9 [ 243.686120] ErrLog5 : 0x989f851
[ 243.686123] Non-Modify : 0x1
[ 243.686129] x13: 0000000000002a5c
[ 243.686129] AXI ID : 0x13
[ 243.686135] x12: 071c71c71c71c71c [ 243.686136] Master ID : CCPLEX
[ 243.686138] Security Group(GRPSEC): 0x7e
[ 243.686145] x11: 000000000000000b
[ 243.686145] Cache : 0x1 – Device
[ 243.686152] x10: 0101010101010101 [ 243.686152] Protection : 0x2 – Unprivileged, Non-Secure, Data Access
[ 243.686155] FALCONSEC : 0x0
[ 243.686159] x9 : fffffffffffffffb
[ 243.686160] Virtual Queuing Channel(VQC): 0x0
[ 243.686164] x8 : 7f7f7f7f7f7f7f7f [ 243.686164] **************************************
[ 243.686167] ras_ccplex_serr_callback: Scanning CCPLEX Error Records for Uncorrectable Errors
[ 243.686173] x7 : fefefeff646c606d x6 : 00170401e9e1acf4
[ 243.686180] x5 : 742c616901041700 x4 : 8080808000000000
[ 243.686186] x3 : b34b234b0963a000 x2 : 000000000000000b
[ 243.686191] x1 : ffffffc7dbc55400 x0 : 0000000000021917
[ 243.686193]
[ 243.686202] Process swapper/4 (pid: 0, stack limit = 0xffffffc7dbc6c000)
[ 243.686209] ras_corecluster_serr_callback:Scanning CoreCluster Error Records for Uncorrectable Errors
[ 243.686211] Call trace:
[ 243.686218] [] tegra_read_chipid+0x58/0xa8
[ 243.686226] [] tegra_get_platform+0x14/0x80
[ 243.686234] [] t19x_cpu_enter_state+0x1c/0x118
[ 243.686241] [] cpuidle_enter_state+0x84/0x380
[ 243.686246] [] cpuidle_enter+0x34/0x48
[ 243.686252] [] call_cpuidle+0x44/0x70
[ 243.686256] [] cpu_startup_entry+0x1b0/0x200
[ 243.686263] [] secondary_start_kernel+0x190/0x1f8
[ 243.686267] [<00000000810441a4>] 0x810441a4
[ 243.686280] —[ end trace f058ac42b8ffc763 ]—
[ 243.686283] ras_core_serr_callback: Scanning Core Error Records for Uncorrectable Errors
[ 243.691814] Bad mode in Error handler detected on CPU5, code 0xbe000000 – SError
[ 243.691818] ras_ccplex_serr_callback: Scanning CCPLEX Error Records for Uncorrectable Errors
[ 243.691821] Internal error: Oops - bad mode: 0 [#2] PREEMPT SMP
[ 243.691845] Modules linked in: fuse bnep zram option usb_wwan overlay iwldvm mac80211 iwlwifi cfg80211 bluedroid_pm ip_tables x_tables
[ 243.691869] CPU: 5 PID: 0 Comm: swapper/5 Tainted: G D 4.9.140-tegra #34
[ 243.691872] ras_corecluster_serr_callback:Scanning CoreCluster Error Records for Uncorrectable Errors
[ 243.691874] Hardware name: Jetson-AGX (DT)
[ 243.691878] task: ffffffc7dbc56200 task.stack: ffffffc7dbc78000
[ 243.691883] PC is at tegra_read_chipid+0x58/0xa8
[ 243.691887] LR is at tegra_read_chipid+0x28/0xa8
[ 243.691890] pc : [] lr : [] pstate: 40c000c5
[ 243.691891] sp : ffffffc7dbc7be50
[ 243.691911] x29: ffffffc7dbc7be50 x28: 0000000000000001
[ 243.691926] x27: ffffff8009fd6000 x26: ffffff800996aac8
[ 243.691941] x25: 0000000000000000 x24: 00000038b8559760
[ 243.691951] x23: ffffff800a1581e8
[ 243.691952] ras_core_serr_callback: Scanning Core Error Records for Uncorrectable Errors
[ 243.691961] x22: ffffffc7ffd40ad0
x21: ffffff800a158200 x20: ffffff800a321548
[ 243.691991] x19: ffffff800a321548 x18: 0000000000000000
[ 243.692006] x17: 0000007f7cbc9f50 x16: ffffff80082756f8
[ 243.692021] x15: 0000000000000000 x14: 000000000000c124
[ 243.692053] x13: 000000000000881d x12: 071c71c71c71c71c
[ 243.692058] x11: 000000000000000b x10: 0101010101010101
[ 243.692065] x9 : fffffffffffffffb x8 : 7f7f7f7f7f7f7f7f
[ 243.692070] x7 : fefefeff646c606d x6 : 00170401e9e1acf4
[ 243.692076] x5 : 742c616901041700 x4 : 8080808000000000
[ 243.692082] x3 : b34b234b0963a000 x2 : 000000000000000b
[ 243.692088] x1 : ffffffc7dbc56200 x0 : 0000000000021917
[ 243.692089]
[ 243.692101] Process swapper/5 (pid: 0, stack limit = 0xffffffc7dbc78000)
[ 243.692103] Call trace:
[ 243.692110] [] tegra_read_chipid+0x58/0xa8
[ 243.692115] [] tegra_get_platform+0x14/0x80
[ 243.692120] [] t19x_cpu_enter_state+0x1c/0x118
[ 243.692126] [] cpuidle_enter_state+0x84/0x380
[ 243.692131] [] cpuidle_enter+0x34/0x48
[ 243.692136] [] call_cpuidle+0x44/0x70
[ 243.692141] [] cpu_startup_entry+0x1b0/0x200
[ 243.692146] [] secondary_start_kernel+0x190/0x1f8
[ 243.692150] [<00000000810441a4>] 0x810441a4
[ 243.692160] —[ end trace f058ac42b8ffc764 ]—
[ 243.692162] ras_ccplex_serr_callback: Scanning CCPLEX Error Records for Uncorrectable Errors
[ 243.692192] ras_corecluster_serr_callback:Scanning CoreCluster Error Records for Uncorrectable Errors
[ 243.692270] ras_core_serr_callback: Scanning Core Error Records for Uncorrectable Errors
[ 243.692483] ras_ccplex_serr_callback: Scanning CCPLEX Error Records for Uncorrectable Errors
[ 243.692515] ras_corecluster_serr_callback:Scanning CoreCluster Error Records for Uncorrectable Errors
[ 243.692589] ras_core_serr_callback: Scanning Core Error Records for Uncorrectable Errors
[ 243.692792] camera_trigger_interrupt_handler
[ 243.692795] ras_ccplex_serr_callback: Scanning CCPLEX Error Records for Uncorrectable Errors
[ 243.692825] ras_corecluster_serr_callback:Scanning CoreCluster Error Records for Uncorrectable Errors
[ 243.692898] ras_core_serr_callback: Scanning Core Error Records for Uncorrectable Errors
[ 243.693109] ras_ccplex_serr_callback: Scanning CCPLEX Error Records for Uncorrectable Errors
[ 243.693142] ras_corecluster_serr_callback:Scanning CoreCluster Error Records for Uncorrectable Errors
[ 243.693219] ras_core_serr_callback: Scanning Core Error Records for Uncorrectable Errors
[ 243.693229]
[ 243.693229]
[ 243.693229] ###################### RTCPU EXCEPTION ######################
[ 243.693229] [RCE] Data abort
[ 243.693229] R0: 00000001 R1: ffffffcf R2: 15c00000 R3: 15c01400
[ 243.693229] R4: 0bca2c28 R5: 00005017 R6: 00000024 R7: 00000010
[ 243.693229] R8: 000003c9 R9: 00000000 R10: 0000000f R11: 0bca3788
[ 243.693229] R12: 0bcb5168 SP: 0bcdf800 LR: 0bc8a638 PC: 0bc80308
[ 243.693229] SP: 0bcb5df0 LR: 0bc847bc
[ 243.693229] CPSR: 20000197 SPSR: 2000001f
[ 243.693229] DFSR: 00001008 DFAR: 15c01400 ADFSR: 00000000
[ 243.693229] IFSR: 00000000 IFAR: 00000000 AIFSR: 00000000
[ 243.693229] Callstack
[ 243.693229] [0bcb5dec]: 0bc8a5f8
[ 243.693229] [0bcb5e90]: 0bc8a5dc
[ 243.693229] [0bcb5ff4]: 0bca01f9
[ 243.693229] [0bcb6b78]: 0bc83610
[ 243.693229] [0bcb6b7c]: 0bc848c8
[ 243.693229] [0bcb6ba4]: 0bc92844
[ 243.693229] [0bcb6be8]: 0bc92820
[ 243.693229] #############################################################
[ 243.693451] CPU0: SError detected, daif=1c0, spsr=0x204000c5, mpidr=80000000, esr=be000000
[ 243.693458] CPU1: SError detected, daif=140, spsr=0xa0000000, mpidr=80000001, esr=be000000
[ 243.693470] CPU2: SError detected, daif=1c0, spsr=0x80c000c5, mpidr=80000100, esr=be000000
[ 243.693476] CPU7: SError detected, daif=140, spsr=0x60c00045, mpidr=80000301, esr=be000000
[ 243.693524] * NVIDIA userID is requ[ 243.693526] **************************************[ 243.693529] CPU:0, Error:CBB-NOC
[ 243.693534] Error Logger : 1
C
[ 243.693544] ErrLog0 : 0x8003[ 243.693547] Transaction Type : WR[ 243.693549] Error Code : TMO
WR - Write, Incrementing
[ 243.693552] Error Source : Ta[ 243.693554] Error Description : Target [ 243.693557] Packet header Lock : 0
get time-out error
[ 243.693559] Packet header Len1 : 3
[ 243.693562] NOC protocol version : [ 243.693565] ErrLog1 : 0x350e1b
n : version >= 2.7
[ 243.693567] ErrLog2 : 0x0
0e1b
[ 243.693569] RouteId : 0x3[ 243.693572] InitFlow : ccroc_p2[ 243.693576] Targflow : host1x_p2pm/T/host1x_p2p[ 243.693580] TargSubRange : 7
_p2pm/T/host1x_p2pm
[ 243.693582] SeqId : 0
: 7
[ 243.693585] ErrLog3 : 0x[ 243.693587] ErrLog4 : 0x0
[ 243.693615] Address : 0x1[ 243.693617] ErrLog5 : 0x689f851
c (unknown device)
[ 243.693620] Non-Modify : 0x1
1
[ 243.693622] AXI ID : 0xd
0x1
[ 243.693625] Master ID : C[ 243.693627] Security Group(GRPSE[ 243.693629] Cache : 0x1 – Device
0x7e
[ 243.693633] Protection : 0x2 – Unp[ 243.693635] FALCONSEC : 0x0
[ 243.693637] Virtual Queuing C[ 243.693641] ************************************[ 243.693644] ras_ccplex_serr_callback: Scanning CCPLE[ 243.693671] **************************************
[ 243.693677] RAS Error in SCF:IOB, ERRSELR_EL1=1025:[ 243.693679] Status = 0xf4009604
ERRSELR_EL1=1025:
[ 243.693681] IERR = CBB Interface[ 243.693684] SERR = Assertion Failure: 0x4
96
[ 243.693686] Uncorrectable (this is fatal)
[ 243.693694] MISC0 = 0x40
(this is fatal)
[ 243.693696] MISC1 = 0x16a[ 243.693700] ADDR = 0x8000000015200[ 243.693708] ***************************[ 243.693714] ras_corecluster_serr_callback:Scanning [ 243.693777] **************************************
[ 243.693780] RAS Error in L2, ERRSELR_EL1=560:
[ 243.693781] Status = 0xf4006512
ELR_EL1=560:
[ 243.693784] IERR = SCF to L2 Sla[ 243.693786] SERR = Error response from slave: 0x12
5
[ 243.693788] Uncorrectable (this is fatal)
ve: 0x12
[ 243.693796] MISC0 = 0x100000000200000
al)
[ 243.693798] MISC1 = 0x40ac0000005
000
[ 243.693803] ADDR = 0x8000000015200[ 243.693809] ***************************[ 243.693821] ras_core_serr_callback: Scanning Core E[ 243.693964] Bad mode in Error handler detected on CPU0, code 0xbe000000 – SError
Errors
[ 243.693968] Internal error: Oops - bad mode: 0 [#3] PREEMPT SMP
e000000 – SError
[ 243.694001] Modules linked in: fuse bnep zram option usb_wwan ov[ 243.694025] CPU: 0 PID: 3553 Comm: haveged Tainted: G D 4.9.140-tegra #34
[ 243.694028] ras_ccplex_serr_callback: Scanning CCPLEX Error Records for Uncorrectable E[ 243.694032] Hardware name: Jetson-AGX (DT)
[ 243.694035] task: ffffffc7c36f4600 task.sta[ 243.694048] PC is at find_busiest_group+0x15e8/0x17f8
7bffe4000
[ 243.694053] LR is at find_busiest_group+0x9f4/0x17f8
[ 243.694056] pc : [] lr : [<ffffff80[ 243.694058] sp : ffffffc7bffe73d0
0>] lr : [] pstate: 204000c5
[ 243.694060] ras_corecluster_serr_c[ 243.694072] x29: ffffffc7bffe73d0 x28: 000000000002532d
[ 243.694083] x27: ffffffc7bffe7680 x26: 0000000000000004
[ 243.694090] x25: ffffff8009fd7000 x24: ffffff8009fd8000
[ 243.694096] x23: ffffffc7ffd28d40 x22: 0000000000000004
[ 243.694102] x21: 0000000000000000 x20: ffffffc7bffe74e0
[ 243.694108] x19: ffffff800996b000 x18: 0000000000000057
[ 243.694116] x17: 000000000bc80308 x16: 000000000002532d
[ 243.694121] x15: 000000000000000a x14: ffffff8009059000
[ 243.694127] x13: 000000009b8d39b9 x12: 0000000000000000
[ 243.694131] x11: 0000000000000400
[ 243.694132] ras_core_serr_callback:[ 243.694136] x10: 0000000000004dc6
x9 : 000000000000021a x8 : 00000000000[ 243.694149] x7 : 0000000000000400 x6 : fff[ 243.694154] x5 : 00000000000000ac x4 : ffffffc7ffd28da8
[ 243.694160] x3 : 0000000000000057 x2 : 0000000000000056
[ 243.694167] x1 : 000000000000021a x0 : 000000000000000a
[ 243.694169]
[ 243.694181] P[ 243.694183] Call trace:
ged (pid: 3553, stack limit = 0xffffffc7bffe4000)
[ 243.694192] [<ffffff8008[ 243.694197] [] load_balance+0x174/0xa20
/0x17f8
[ 243.694202] [] pick_next_task_fair+0x270[ 243.694210] [] _schedule+0xe8/0x780
270/0x778
[ 243.694214] [] schedule+0x40/0xa8
80
[ 243.694220] [] schedule_hrtimeout
[ 243.694225] [] schedule_hrtimeout_range+0x38/0x48
/0xf0
[ 243.694232] [] poll_schedule_timeout+0x4c/0x78
48
[ 243.694236] [] do_select+0x420/0x618
0x4c/0x78
[ 243.694241] [] core_sys_select+0x1bc/[ 243.694245] [] SyS_pselect6+0x2c8/0x3e8
00
[ 243.694252] [] __sys_trace_return+0x0/0x[ 243.694259] —[ end trace f058ac42b8ffc765 ]—
rn+0x0/0x4
[ 243.694343] ras_ccplex_serr_callback: Scanning CC[ 243.694373] ras_corecluster_serr_callback:Scanning CoreCluster Error Records for Uncorrectabl[ 243.694447] ras_core_serr_callback: Scanning Core Error Records for Uncorrectable Errors
table Errors
[ 243.694648] ras_ccplex_serr_callback: Scanning CCPLEX Error Records for Uncorrectable Err[ 243.694679] ras_corecluster_serr_callback:Scanning CoreCluster Error Records for Uncorrectabl[ 243.694752] ras_core_serr_callback: Scanning Core Error Records for Uncorrectable Errors
table Errors
[ 243.694950] CPU1: SError detected, daif=140, spsr=0xa0000000, mpidr=80000001, esr=be00000[ 243.694955] CPU7: SError detected, daif=140, spsr=0x60c00045, mpidr=80000301, esr=be000000
[ 243.694972] CPU2: SError detected, daif=1c0, spsr=0x80c000c5, mpidr=80000100, esr=be000000
[ 243.694989] **************************************
[ 243.694991] * For more Internal Decode Help
[ 243.694994] * http://nv/cbberr
ode Help
[ 243.694995] * NVIDIA userID is requ[ 243.694997] **************************************[ 243.694999] CPU:3, Error:CBB-NOC
[ 243.695004] Error Logger : 1
C
[ 243.695013] ErrLog0 : 0x8003[ 243.695016] Transaction Type : RD[ 243.695018] Error Code : TMO
[ 243.695021] Error Source : Ta[ 243.695023] Error Description : Target [ 243.695025] Packet header Lock : 0
get time-out error
[ 243.695027] Packet header Len1 : 3
[ 243.695033] NOC protocol version : [ 243.695035] ErrLog1 : 0x350e2a
n : version >= 2.7
[ 243.695037] ErrLog2 : 0x0
0e2a
[ 243.695039] RouteId : 0x3[ 243.695042] InitFlow : ccroc_p2[ 243.695044] Targflow : host1x_p2pm/T/host1x_p2p[ 243.695046] TargSubRange : 7
_p2pm/T/host1x_p2pm
[ 243.695048] SeqId : 0
: 7
[ 243.695050] ErrLog3 : 0x[ 243.695052] ErrLog4 : 0x0
[ 243.695078] Address : 0x1[ 243.695080] ErrLog5 : 0xa89f851
0 (unknown device)
[ 243.695082] Non-Modify : 0x1
1
[ 243.695084] AXI ID : 0x15
x1
[ 243.695086] Master ID : CC[ 243.695088] Security Group(GRPSE[ 243.695091] Cache : 0x1 – Device
0x7e
[ 243.695094] Protection : 0x2 – Unp[ 243.695096] FALCONSEC : 0x0
[ 243.695099] Virtual Queuing C[ 243.695102] ************************************[ 243.695104] ras_ccplex_serr_callback: Scanning CCPLE[ 243.695131] **************************************
[ 243.695134] RAS Error in SCF:IOB, ERRSELR_EL1=1025:[ 243.695135] Status = 0xf4009604
ERRSELR_EL1=1025:
[ 243.695139] IERR = CBB Interface[ 243.695141] SERR = Assertion Failure: 0x4
96
[ 243.695143] Uncorrectable (this is fatal)
[ 243.695151] MISC0 = 0x40
(this is fatal)
[ 243.695152] MISC1 = 0x264[ 243.695157] ADDR = 0x800000001520[ 243.695165] ***************************[ 243.695170] ras_corecluster_serr_callback:Scanning [ 243.695231] **************************************
[ 243.695233] RAS Error in L2, ERRSELR_EL1=560:
[ 243.695235] Status = 0xfc006612
ELR_EL1=560:
[ 243.695237] IERR = SCF to L2 Sla[ 243.695239] SERR = Error response from slave: 0x12
[ 243.695241] Overflow (there may be more errors) - U[ 243.695242] Uncorrectable (this is fatal)
[ 243.695250] MISC0 = 0x100000000400000
al)
[ 243.695251] MISC1 = 0x40240000000
000
[ 243.695256] ADDR = 0x8000000015200[ 243.695262] ***************************[ 243.695273] ras_core_serr_callback: Scanning Core E[ 243.695417] Bad mode in Error handler detected on CPU3, code 0xbe000000 – SError
Errors
[ 243.695421] Internal error: Oops - bad mode: 0 [#4] PREEMPT SMP
e000000 – SError
[ 243.695448] Modules linked in: fuse bnep zram option usb_wwan ov[ 243.695464] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G D 4.9.140-tegra #34
[ 243.695467] Hardware name: Jetson-AGX (DT)
[ 243.695470] task: ffffffc7dbc54600 task.sta[ 243.695477] ras_ccplex_serr_callback: Scanning CCPLEX Error Reco[ 243.695480] PC is at t19x_cpu_enter_state+0x4c/0x118
[ 243.695484] LR is at t19x_cpu_enter_state+0x1c/0x118
[ 243.695486] pc : [] lr : [<ffffff80[ 243.695493] sp : ffffffc7dbc6be80
c>] lr : [] pstate: 80c000c5
[ 243.695500] x29: ffffffc7dbc6be80 [ 243.695505] x27: ffffff8009fd6000 x26: ffffff800996aac8
[ 243.695509] x25: 0000000000000000
[ 243.695510] ras_corecluster_serr_ca[ 243.695515] x24: 00000038bd3417c0
x23: ffffff800a1581e8 x22: ffffffc7ffd[ 243.695526] x21: ffffff800a158200 x20: fff[ 243.695531] x19: 0000000000000000 x18: 0000007f9820fa70
[ 243.695536] x17: 00000044200989c0 x16: ffffff800814f5e8
[ 243.695541] x15: 0000000000000000 x14: 0000000000006a32
[ 243.695546] x13: 000000000000c6d7 x12: 071c71c71c71c71c
[ 243.695551] x11: 000000000000000b x10: 0101010101010101
[ 243.695556] x9 : fffffffffffffffb x8 : 7f7f7f7f7f7f7f7f
[ 243.695563] x7 : fefefeff646c606d x6 : 00170401e9e1acf4
[ 243.695568] x5 : 742c616901041700 x4 : 8080808000000000
[ 243.695573] x3 : b34b234b0963a000 x2 : 000000000000000b
[ 243.695578] x1 : 0000000000000000 x0 : 0000000000000000
[ 243.695579]
[ 243.695590] P[ 243.695593] ras_core_serr_callback: Scanning Core Error Records for Uncor[ 243.695596] Call trace:
[ 243.695603] [<ffffff8008[ 243.695610] [] cpuidle_enter_state+0x84/0x380
[ 243.695615] [] cpuidle_enter+0x34/0x48
/0x380
[ 243.695621] [] call_cpuidle+0x44/0x70
[ 243.695625] [] cpu_startup_entry+0x1b0[ 243.695632] [] secondary_start_kernel+0x190/0[ 243.695635] [<00000000810441a4>] 0x810441a4
[ 243.695647] —[ end trace f058ac42b8ffc766 [ 243.695797] ras_ccplex_serr_callback: Scanning CC[ 243.695828] ras_corecluster_serr_callback:Scanning CoreCluster Error Records for Uncorrectabl[ 243.695901] ras_core_serr_callback: Scanning Core Error Records for Uncorrectable Errors
table Errors
[ 243.696113] ras_ccplex_serr_callback: Scanning CCPLEX Error Records for Uncorrectable Err[ 243.696143] ras_corecluster_serr_callback:Scanning CoreCluster Error Records for Uncorrectabl[ 243.696216] ras_core_serr_callback: Scanning Core Error Records for Uncorrectable Errors
table Errors
[ 243.696558] CPU7: SError detected, daif=140, spsr=0x40c00045, mpidr=80000301, esr=be00000[ 243.696578] CPU2: SError detected, daif=1c0, spsr=0x80c000c5, mpidr=80000100, esr=be000000
[ 243.696585] CPU1: SError detected, daif=140, spsr=0x40400045, mpidr=80000001, esr=be000000
[ 243.696625] **************************************
[ 243.696628] * For more Internal Decode Help
[ 243.696631] * http://nv/cbberr
ode Help
[ 243.696633] * NVIDIA userID is requ[ 243.696636] **************************************[ 243.696638] CPU:7, Error:CBB-NOC
[ 243.696643] Error Logger : 1
C
[ 243.696653] ErrLog0 : 0x8003[ 243.696657] Transaction Type : WR[ 243.696660] Error Code : TMO
[ 243.696663] Error Source : Ta[ 243.696666] Error Description : Target [ 243.696668] Packet header Lock : 0
get time-out error
[ 243.696671] Packet header Len1 : 3
[ 243.696673] NOC protocol version : [ 243.696677] ErrLog1 : 0x350e1b
n : version >= 2.7
[ 243.696679] ErrLog2 : 0x0
0e1b
[ 243.696682] RouteId : 0x3[ 243.696685] InitFlow : ccroc_p2[ 243.696688] Targflow : host1x_p2pm/T/host1x_p2p[ 243.696690] TargSubRange : 7
_p2pm/T/host1x_p2pm
[ 243.696692] SeqId : 0
: 7
[ 243.696695] ErrLog3 : 0x[ 243.696697] ErrLog4 : 0x0
[ 243.696725] Address : 0x1[ 243.696727] ErrLog5 : 0x689f851
0 (unknown device)
[ 243.696730] Non-Modify : 0x1
1
[ 243.696732] AXI ID : 0xd
0x1
[ 243.696735] Master ID : C[ 243.696738] Security Group(GRPSE[ 243.696741] Cache : 0x1 – Device
0x7e
[ 243.696744] Protection : 0x2 – Unp[ 243.696746] FALCONSEC : 0x0
[ 243.696749] Virtual Queuing C[ 243.696753] ************************************[ 243.696757] ras_ccplex_serr_callback: Scanning CCPLE[ 243.696784] **************************************
[ 243.696787] RAS Error in SCF:IOB, ERRSELR_EL1=1025:[ 243.696789] Status = 0xf4009604
ERRSELR_EL1=1025:
[ 243.696792] IERR = CBB Interface[ 243.696795] SERR = Assertion Failure: 0x4
96
[ 243.696797] Uncorrectable (this is fatal)
[ 243.696806] MISC0 = 0x40
(this is fatal)
[ 243.696808] MISC1 = 0x12a[ 243.696813] ADDR = 0x8000000015200[ 243.696821] ***************************[ 243.696827] ras_corecluster_serr_callback:Scanning [ 243.696891] **************************************
[ 243.696894] RAS Error in L2, ERRSELR_EL1=560:
[ 243.696896] Status = 0xf4006512
ELR_EL1=560:
[ 243.696898] IERR = SCF to L2 Sla[ 243.696901] SERR = Error response from slave: 0x12
5
[ 243.696903] Uncorrectable (this is fatal)
ve: 0x12
[ 243.696911] MISC0 = 0x100000000200000
al)
[ 243.696913] MISC1 = 0x40ac0000004
000
[ 243.696919] ADDR = 0x8000000015200[ 243.696925] ***************************[ 243.696937] ras_core_serr_callback: Scanning Core E[ 243.697084] Bad mode in Error handler detected on CPU7, code 0xbe000000 – SError
Errors
[ 243.697089] Internal error: Oops - bad mode: 0 [#5] PREEMPT SMP
e000000 – SError
[ 243.697125] Modules linked in: fuse bnep zram option usb_wwan ov[ 243.697150] CPU: 7 PID: 1435 Comm: irq/81-15200000 Tainted: G D 4.9.140-tegra #34
[ 243.697152] ras_ccplex_serr_callback: Scanning CCPLEX Error Records for Uncorrectable Errors
4
[ 243.697156] Hardware name: Jetson-AGX (DT)
[ 243.697160] task: ffffffc7da0a3800 task.sta[ 243.697171] PC is at tegra_dc_put+0x0/0xe0
ck: ffffffc7d7f20000
[ 243.697177] LR is at tegra_dc_irq+0xa30/0x1[ 243.697181] pc : [] lr : [<ff[ 243.697183] ras_corecluster_serr_callback:Scanning CoreCluster Error Records for [ 243.697186] sp : ffffffc7d7f23ce0
[ 243.697194] x29: ffffffc7d7f23ce0 [ 243.697201] x27: 0000000000000000 x26: 0000000000000000
[ 243.697208] x25: 0000000000000000 x24: 0000000000000000
[ 243.697214] x23: 0000000000000000 x22: 0000000000000000
[ 243.697221] x21: ffffffc7d7eac378 x20: ffffff800a31a000
[ 243.697227] x19: ffffffc7d7ea8000 x18: 0000000000000f43
[ 243.697234] x17: 0000000000004378 x16: 00000000000743a9
[ 243.697241] x15: 000000000005fa45 x14: ffffff80090599f8
[ 243.697248] x13: 0000000000000000 x12: 0000000000000003
[ 243.697255] x11: 000000000000000b x10: 0101010101010101
[ 243.697261] ras_core_serr_callback: Scanning Core Error R[ 243.697270] x9 : fffffffffffffffb x8 : 7f7f7f7f7f7f7f7f
[ 243.697277] x7 : fefefeff646c606d x6 : 0000000000000000
[ 243.697285] x5 : 742c616901041700 x4 : 8080808000000000
[ 243.697292] x3 : 0000000000000000 x2 : 0000000000800000
[ 243.697298] x1 : 0000000000000001 x0 : ffffffc7d7ea8000
[ 243.697300]
[ 243.697311] P[ 243.697313] Call trace:
81-15200000 (pid: 1435, stack limit = 0xffffffc7d7f20000)
[ 243.697320] [<ffffff8008[ 243.697327] [] irq_thread_fn+0x30/0x8[ 243.697332] [] irq_thread+0x11c/0x1a8
[ 243.697339] [] kthread+0xec/0xf0
x1a8
[ 243.697345] [] ret_from_fork+0x10[ 243.697352] —[ end trace f058ac42b8ffc767 ]—
10/0x30
[ 243.697466] ras_ccplex_serr_callback: Scanning CC[ 243.697497] ras_corecluster_serr_callback:Scanning CoreCluster Error Records for Uncorrectabl[ 243.697568] ras_core_serr_callback: Scanning Core Error Records for Uncorrectable Errors
table Errors
[ 243.699257] Kernel panic - not syncing: Attempted to kill the idle task!
rectable Errors
[ 243.699271] note: haveged[3553] exited with preempt_count 2
e idle task!
[ 243.699274] SMP: stopping secondary CPUs
th preempt_count 2
[ 244.902311] SMP: failed to stop secondary[ 244.902317] Kernel Offset: disabled
ndary CPUs 3-6
[ 244.902319] Memory Limit: none
bled
[ 246.549106] trusty-log panic notifier - trusty version Built: 21:16:17 Jun 25 2020
[ 246.549107] ras_ccplex_serr_callback: Scanning CCPLEX Error Records for Uncorrectable Errors
[ 246.549139] ras_corecluster_serr_callback:Scanning CoreCluster Error Records for Uncorrectable Errors
[ 246.549177] ras_core_serr_callback: Scanning Core Error Records for Uncorrectable Errors
[ 246.549260] CPU6: SError detected, daif=1c0, spsr=0x80c000c5, mpidr=80000300, esr=be000000
[ 246.549323] ras_ccplex_serr_callback: Scanning CCPLEX Error Records for Uncorrectable Errors
[ 246.549352] ras_corecluster_serr_callback:Scanning CoreCluster Error Records for Uncorrectable Errors
[ 246.549390] ras_core_serr_callback: Scanning Core Error Records for Uncorrectable Errors
[ 246.619812] Rebooting in 5 seconds..
[ 251.624721] SMP: stopping secondary CPUs
[ 252.827595] SMP: failed to stop secondary CPUs 3-5
hello 840764397,
it’s camera bring-up issue.
are you using Jetson Partner Supported Cameras supported by Jetson Camera Partners on the Jetson platforms?
please share the commands and may I know which sensor module you’re working with.
you may refer to Sensor Software Driver Programming Guide if you’re developer your own sensor drivers,
you may also check the Debugging Tips session to examine your sensor drivers.
thanks
we use imx390 sensor.
hello 840764397,
you may found there’s IMX390 reference driver, please access L4T sources via download center for the kernel sources.
for example,
$L4T_Sources/r32.4.3/Linux_for_Tegra/source/public/kernel/nvidia/drivers/media/i2c/imx390.c
$L4T_Sources/r32.4.3/Linux_for_Tegra/source/public/hardware/nvidia/platform/t19x/common/kernel-dts/t19x-common-modules/tegra194-camera-imx390-a00.dtsi
so, were you working with IMX390 supported by Jetson Camera Partners on the Jetson platforms?
