When use 2 rtsp streams as input,the output stream did not show the labels of boundingbox
• Hardware Platform ( GPU- T 4)
**• DeepStream Version 6.1.1,docker environment
• TensorRT Version
• NVIDIA GPU Driver Version (470.129.06)
Can the label show correctly when only one RTSP is used? Can this issue be reproduced in DeepStream examples? Thanks.
Also, could you attach your pipeline? Do you use your own code or our demo code?
when one rtsp strea was used ,labels was corrected
deepstream_app_config_yolo.txt (5.1 KB)
here is my config.
Could you try to add -t 1 when you run the deepstream-app?
like this ?
deepstream-app -c -t 1 deepstream_app_config_yolo.txt
deepstream-app -c deepstream_app_config_yolo.txt -t 1
thanks for You guys,babel was displayed.
when i used 8 rtsp steams as input and yolov5n as model, the screen was blurred but but not stuck. could you tell me how to fix this problem and the reason why this thing happend?
Could you open a new topic for the new problem? Thanks
