Seems when I installed my Cuda toolkill all of my environment system variables got messed up. Where can I find out what environment variables I need for CUDA to work? I can’t get nvcc to work in command prompt. The toolkill is installed. I fixed the environment variable for cl.exe and then it told me that nvcc wasn’t able to be run and couldn’t be found. This is after I installed it. Can someone tell me the names of the variables I need and what paths I should be using to get this to work?
Related topics
| Driver, toolkit and SDK installed, but nvcc doesn't work | 2 | 1674 | February 28, 2011 | |
| NVCC "No command 'nvcc' found" | 5 | 213470 | January 25, 2010 | |
| Cant seem to find nvcc! | 3 | 1089 | October 8, 2010 | |
| Path error trying to run nvcc | 0 | 1188 | September 27, 2020 | |
| How to emulate cuda without GPU | 5 | 4762 | June 4, 2010 | |
| How to set the enviorment variable? | 2 | 4681 | April 24, 2008 | |
| CUDA toolkit install problem on Jetson TK1 | 3 | 1954 | October 11, 2014 | |
| Failed installation of CUDA - nvcc won't work and can't set PATH | 1 | 747 | November 23, 2023 | |
| No nvcc after installing toolkit | 1 | 17588 | September 21, 2011 | |
| installation problem - nvcc command not found | 2 | 2850 | September 25, 2010 |
