I am new to Jetson Nano. I just wanted to know which pre trained deeplearning model will give me greater than 60fps on 1400x1401 resolution image.
Kindly reply.
Kindly reply.
none that I know of because of your 1400x1401 resolution image.
ya down scale it to 640x640 and use yolov5n ya might get 60fps… not likely. Depends on the model you train for it and how many objects your trying to detect in each image.
Start reading … allot… dive down the rabbit holes. try some code.
| Model | size | objects | mAP | Jetson Nano 2015 MHz |
| NanoDet | 320x320 | 80 | 20.6 | 28.2 FPS |
| YoloFastestV2 | 352x352 | 80 | 24.1 | 38.4 FPS |
| YoloV2 | 416x416 | 20 | 19.2 | 10.1 FPS |
| YoloV3 | 352x352 tiny | 20 | 16.6 | 17.7 FPS |
| YoloV4 | 416x416 tiny | 80 | 21.7 | 11.2 FPS |
| YoloV4 | 608x608 full | 80 | 45.3 | 0.7 FPS |
| YoloV5 | 640x640 small | 80 | 22.5 | 4.0 FPS |
| YoloX | 416x416 nano | 80 | 25.8 | 17.6 FPS |
| YoloX | 416x416 tiny | 80 | 32.8 | 8.3 FPS |
| YoloX | 640x640 small | 80 | 40.5 | 2.6 FPS |
Due to Nano’s limited resources, it’s recommended to try our TAO toolkit for some pruning mechanisms.
You can find the performance of these models on the below page:
I just want to detect only 2 objects for the time being. Yolov5 is a bigger model right? I cannot use tensorflow/tensorRt I am supposed to use only opencv.
Maybe you can try some lightweight models, ex. YOLOv3 tiny, to see if it can meet your requirement.
