Hi
I have been debugging a device using IIC protocol with Jetson Xavier Nx recently. I have identified the device, but there was an error when running the program, which indicated that I did not install the IIC protocol related library. I actually have the SMbus library installed
mahan@jsteon-nano-desktop:~/Documents/IIc/MPU-6050-Python-master/MPU-6050-Python-master$ sudo apt-get install python3-smbus
Reading package lists… Done
Building dependency tree
Reading state information… Done
python3-smbus is already the newest version (4.0-2).
The following packages were automatically installed and are no longer required:
apt-clone archdetect-deb bogl-bterm busybox-static cryptsetup-bin
dpkg-repack gir1.2-timezonemap-1.0 gir1.2-xkl-1.0 grub-common
kde-window-manager kinit kio kpackagetool5 kwayland-data kwin-common
kwin-data kwin-x11 libaio1 libdebian-installer4 libibverbs1
libkdecorations2-5v5 libkdecorations2private5v5 libkf5activities5
libkf5attica5 libkf5completion-data libkf5completion5 libkf5declarative-data
libkf5declarative5 libkf5doctools5 libkf5globalaccel-data libkf5globalaccel5
mahan@jsteon-nano-desktop:~/Documents/IIc/MPU-6050-Python-master/MPU-6050-Python-master$ sudo pip3 install smbus
The directory ‘/home/mahan/.cache/pip/http’ or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo’s -H flag.
The directory ‘/home/mahan/.cache/pip’ or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo’s -H flag.
Requirement already satisfied: smbus in /usr/local/lib/python3.6/dist-packages
mahan@jsteon-nano-desktop:~/Documents/IIc/MPU-6050-Python-master/MPU-6050-Python-master$ sudo apt-get install l -y i2c-tools
E: Unable to locate package l
mahan@jsteon-nano-desktop:~/Documents/IIc/MPU-6050-Python-master/MPU-6050-Python-master$ apt-cache search smbus
python-smbus - Python bindings for Linux SMBus access through i2c-dev
python3-smbus - Python 3 bindings for Linux SMBus access through i2c-dev
mahan@jsteon-nano-desktop:~/Documents/IIc/MPU-6050-Python-master/MPU-6050-Python-master$ python MPU6050.py
File “MPU6050.py”, line 8, in
import smbus
ModuleNotFoundError: No module named ‘smbus’
Yes I tried it and the result was the same as performing python MPU6050.py, both showed no smbus.
mahan@jsteon-nano-desktop:~/Documents/IIc/MPU-6050-Python-master/MPU-6050-Python-master$ python3 MPU6050.py
import smbus
Just give it a try, the smbus module can be imported on Jetson without issues.
Would you mind checking it again?
The directory '/home/nvidia/.cache/pip/http' or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
The directory '/home/nvidia/.cache/pip' or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
Collecting smbus
Downloading https://files.pythonhosted.org/packages/4d/5c/70e14aa4f0c586efc017e1d1aa6e2f7921eefc7602fc2d03368ff912aa91/smbus-1.1.post2.tar.gz (104kB)
100% |████████████████████████████████| 112kB 1.9MB/s
Installing collected packages: smbus
Running setup.py install for smbus ... done
Successfully installed smbus-1.1.post2
$ python3
Python 3.6.9 (default, Mar 15 2022, 13:55:28)
[GCC 8.4.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import smbus
When I execute sudo pip3 install smbus, I get the following prompts:
When I execute python3, I get the following prompts:
mahan@jsteon-nano-desktop:~$ python3
Python 3.7.5 (default, Dec 9 2021, 17:04:37)
Type “help”, “copyright”, “credits” or “license” for more information.
import smbus
File “”, line 1, in
Is there a problem with the installed Version of Python?
When I run sudo pip3 install smbus, the following message appears:
mahan@jsteon-nano-desktop:~$ sudo pip3 install smbus
When I run python3, the following message appears:
import smbus
File “”, line 1, in
