Hi, I am using NvBufSurfTransformCompositeBlend function, but got the error: "VIC operation is not supported
". So I want to verify is the function NvBufSurfTransformCompositeBlend not supported on VIC ? or other reasons.
https://docs.nvidia.com/jetson/archives/r35.4.1/ApiReference/group__ds__bbb.html#ga30737c04cf7ebf543ec4c10f9cb3b3ff
Now my NvBufSurface type is:
src0 : NVBUF_COLOR_FORMAT_RGBA
src1 : NVBUF_COLOR_FORMAT_RGBA
alpha: NVBUF_COLOR_FORMAT_GRAY8
My jetpack is 5.1.2. Thanks for your help, and my codes are shown as below:
void CameraStitcher::CompositeImage() {
// get NvBufSurface from cv::Mat
NvBufSurface** composite_imput = new NvBufSurface*[2];
for (int i = 0; i < 2; i++) {
NvBufSurfaceCreateParams create_params;
create_params.gpuId = 0;
create_params.width = crop_info_.width;
create_params.height = crop_info_.height;
create_params.size = 0;
create_params.colorFormat = NVBUF_COLOR_FORMAT_RGBA;
create_params.layout = NVBUF_LAYOUT_PITCH;
create_params.memType = NVBUF_MEM_DEFAULT;
if (NvBufSurfaceCreate(&composite_imput[i], 1, &create_params) != 0) {
std::cout<<"Nv surface create error"<<std::endl;
composite_imput[i]->numFilled = 1;
if (NvBufSurfaceMap(composite_imput[i], 0, 0, NVBUF_MAP_READ_WRITE) != 0){
std::cout<<"Nv surface map error"<<std::endl;
cv::Mat remap_image = cv::imread("test_" + std::to_string(i) + ".png");
cv::cvtColor(remap_image, remap_image, cv::COLOR_BGR2RGBA);
memcpy(composite_imput[i]->surfaceList[0].mappedAddr.addr[0], remap_image.ptr(),
remap_image.total() * remap_image.elemSize());
// get alpha from CV_8UC1 cv::Mat
NvBufSurface* alpha;
NvBufSurfaceCreateParams mask_params;
mask_params.gpuId = 0;
mask_params.width = crop_info_.width;
mask_params.height = crop_info_.height;
mask_params.size = 0;
mask_params.colorFormat = NVBUF_COLOR_FORMAT_GRAY8;
mask_params.layout = NVBUF_LAYOUT_PITCH;
mask_params.memType = NVBUF_MEM_DEFAULT;
if (NvBufSurfaceCreate(&alpha, 1, &mask_params) != 0) {
alpha->numFilled = 1;
if (NvBufSurfaceMap(alpha, 0, 0, NVBUF_MAP_READ_WRITE) != 0){
cv::Mat mask = camera_masks_[0].clone(); // CV_8UC3 type
memcpy(alpha->surfaceList[0].mappedAddr.addr[0], mask.ptr(),
mask.total() * mask.elemSize());
// initialize output
NvBufSurf::NvCommonAllocateParams input_params = {0};
input_params.width = crop_info_.width;
input_params.height = crop_info_.height;
input_params.colorFormat = NVBUF_COLOR_FORMAT_RGBA;
input_params.layout = NVBUF_LAYOUT_PITCH;
input_params.memType = NVBUF_MEM_DEFAULT;
int composited_frame = 0;
if(-1 == NvBufSurf::NvAllocate(&input_params, 1, &composited_frame)) {
std::cout<<"NvAllocate error"<<std::endl;
if (!composited_frame) {
std::cout<<"Failed to allocate composited buffer"<<std::endl;
NvBufSurface *output;
if (-1 == NvBufSurfaceFromFd(composited_frame, (void**)(&output))) {
std::cout<<"Failed to get output"<<std::endl;
// get params
NvBufSurfTransformCompositeBlendParams composite_param;
memset(&composite_param, 0, sizeof(composite_param));
composite_param.composite_blend_flag = NVBUFSURF_TRANSFORM_BLEND;
composite_param.input_buf_count = 2;
composite_param.composite_blend_filter = NvBufSurfTransformInter_Bilinear;
int comp_value =NvBufSurfTransformCompositeBlend(composite_imput[0], composite_imput[1], alpha, output, &composite_param);
std::cout<<"comp_value "<<comp_value<<std::endl;
return;
