Device : Jetson Orin Nano 8G
JetPack : JetPack6.2.1
I want to modify the device tree to configure HDMI 4K,then I modify the device tree and flash it onto the machine.
By decompiling, it was found that there was no change in the device tree before and after modification.
Decompile command:
sudo dtc -I fs -O dts -o extracted_proc.dts /proc/device-tree
And I tried the same thing on the following devices, and it worked.
Device : Jetson AGX Orin 32G
JetPack : JetPack5.1.4
How is that possible?
Can anyone tell me why?
Thank you!!!
Hi ZXZhang,
Are you using the devkit or custom board for Orin Nano?
This is the device tree extracted from run-time which is used to check the current configuration.
Please share the detailed steps how did you apply the device tree change.
I use custom board.
This is what I did:
diff --git a/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi b/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi
index b2cb7f6c9..3bb24f9dc 100644
--- a/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi
+++ b/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi
@@ -376,9 +376,18 @@
nvidia,lpdr = <TEGRA_PIN_DISABLE>;
+ #dp_aux_ch0_hpd_pm0 {
+ # nvidia,pins = "dp_aux_ch0_hpd_pm0";
+ # nvidia,function = "dp";
+ # nvidia,pull = <TEGRA_PIN_PULL_NONE>;
+ # nvidia,tristate = <TEGRA_PIN_ENABLE>;
+ # nvidia,enable-input = <TEGRA_PIN_ENABLE>;
+ # nvidia,io-high-voltage = <TEGRA_PIN_DISABLE>;
+ # nvidia,lpdr = <TEGRA_PIN_DISABLE>;
- nvidia,function = "dp";
+ nvidia,function = "rsvd1";
diff --git a/Linux_for_Tegra/bootloader/tegra234-mb1-bct-gpio-p3701-0000-a04.dtsi b/Linux_for_Tegra/bootloader/tegra234-mb1-bct-gpio-p3701-0000-a04.dtsi
index 26041b325..0783bbb2c 100644
--- a/Linux_for_Tegra/bootloader/tegra234-mb1-bct-gpio-p3701-0000-a04.dtsi
+++ b/Linux_for_Tegra/bootloader/tegra234-mb1-bct-gpio-p3701-0000-a04.dtsi
@@ -54,6 +54,7 @@
TEGRA234_MAIN_GPIO(Q, 6)
TEGRA234_MAIN_GPIO(Q, 7)
TEGRA234_MAIN_GPIO(R, 1)
+ TEGRA234_MAIN_GPIO(M, 0)
TEGRA234_MAIN_GPIO(N, 4)
TEGRA234_MAIN_GPIO(N, 1)
TEGRA234_MAIN_GPIO(G, 0)
diff --git a/Linux_for_Tegra/source/hardware/nvidia/t23x/nv-public/nv-platform/tegra234-dcb-p3701-0000-a02-p3737-0000-a01_hdmi.dtsi b/Linux_for_Tegra/source/hardware/nvidia/t23x/nv-public/nv-platform/tegra234-dcb-p3701-0000-a02-p3737-0000-a01_hdmi.dtsi
new file mode 100755
index 000000000..82d09288f
--- /dev/null
+++ b/Linux_for_Tegra/source/hardware/nvidia/t23x/nv-public/nv-platform/tegra234-dcb-p3701-0000-a02-p3737-0000-a01_hdmi.dtsi
@@ -0,0 +1,561 @@
+ * Copyright (c) 2022, NVIDIA CORPORATION. All rights reserved.
+ * This program is free software; you can redistribute it and/or modify
+ * it under the terms of the GNU General Public License as published by
+ * the Free Software Foundation; either version 2 of the License, or
+ * (at your option) any later version.
+ * This program is distributed in the hope that it will be useful, but WITHOUT
+ * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
+ * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
+ * more details.
+ display@13800000 {
+ os_gpio_hotplug_a = <&gpio TEGRA234_MAIN_GPIO(M, 0) GPIO_ACTIVE_HIGH>;
+ nvidia,dcb-image = [
+ 55 aa 16 00 00 37 34 30 30 e9 4c 19 77 cc 56 49
+ 44 45 4f 20 0d 00 00 00 70 01 00 00 00 00 49 42
+ 4d 20 56 47 41 20 43 6f 6d 70 61 74 69 62 6c 65
+ 01 00 00 00 10 00 82 18 30 34 2f 32 35 2f 32 32
+ 00 00 00 00 00 00 00 00 21 18 50 00 e1 2b 00 00
+ 50 4d 49 44 00 00 00 00 00 00 00 a0 00 b0 00 b8
+ 00 c0 00 0e 47 41 31 30 42 20 56 47 41 20 42 49
+ 4f 53 0d 0a 00 00 00 00 00 00 00 00 00 00 00 00
+ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
+ 00 00 00 00 00 56 65 72 73 69 6f 6e 20 39 34 2e
+ 30 42 2e 30 30 2e 30 30 2e 32 31 20 0d 0a 00 43
+ 6f 70 79 72 69 67 68 74 20 28 43 29 20 31 39 39
+ 36 2d 32 30 32 32 20 4e 56 49 44 49 41 20 43 6f
+ 72 70 2e 0d 0a 00 00 00 ff ff 00 00 00 00 ff ff
+ 47 50 55 20 42 6f 61 72 64 00 00 00 00 00 00 00
+ 00 00 00 43 68 69 70 20 52 65 76 20 20 20 00 00
+ 00 00 00 00 00 00 00 ba 91 98 96 91 9a 9a 8d 96
+ 91 98 df ad 9a 93 9a 9e 8c 9a df d2 df b1 90 8b
+ df b9 90 8d df af 8d 90 9b 8a 9c 8b 96 90 91 df
+ aa 8c 9a f2 f5 ff 00 00 00 00 00 00 00 00 00 00
+ 50 43 49 52 de 10 94 22 00 00 18 00 00 00 00 03
+ 16 00 01 00 00 80 00 00 2e 8b c0 2e 8b c0 8b c0
+ 4e 50 44 45 01 01 14 00 16 00 00 01 00 00 00 00
+ ff b8 42 49 54 00 00 01 0c 06 13 44 32 01 04 00
+ 3e 02 42 02 25 00 4a 02 43 02 2c 00 6f 02 44 01
+ 04 00 9b 02 49 01 24 00 9f 02 4d 02 29 00 c3 02
+ 4e 00 00 00 00 00 50 02 fc 00 ec 02 53 02 18 00
+ e8 03 54 01 02 00 00 04 55 01 05 00 0a 04 56 01
+ 06 00 0f 04 78 01 08 00 15 04 64 01 02 00 1d 04
+ 70 02 04 00 1f 04 75 01 11 00 23 04 69 02 6e 00
+ 34 04 45 01 04 00 02 04 73 01 04 00 06 04 00 00
+ a2 04 a2 04 e9 21 f0 21 e0 2b 00 00 00 00 00 00
+ 00 00 00 00 00 00 00 00 00 00 00 00 0b 94 21 00
+ 00 00 00 00 a8 07 00 00 00 00 00 00 00 00 02 00
+ 5c 5c 2e 02 00 00 42 02 04 00 10 00 00 00 00 e9
+ 0e 00 00 00 00 00 00 39 44 00 00 e7 2d 00 00 00
+ 00 00 00 00 00 00 00 00 00 00 00 92 30 00 00 e5
+ 44 00 00 23 45 00 00 4a 45 00 00 00 00 00 00 f6
+ 04 00 00 00 00 fa 04 00 00 66 08 fa 04 16 2b 66
+ 08 18 2b a2 04 ef 09 04 22 d4 09 c2 21 18 2b 90
+ 00 9b 22 01 68 08 56 09 f4 43 00 00 fe 43 00 00
+ f7 0f 00 00 f0 21 00 00 fc 21 00 00 54 4a 00 00
+ 00 00 00 00 00 00 00 00 00 00 00 00 d5 33 00 00
+ bb 36 00 00 00 00 00 00 00 00 00 00 00 00 00 00
+ 00 00 00 00 00 00 00 00 00 00 00 00 b3 3c 00 00
+ 00 00 00 00 ed 3c 00 00 12 43 00 00 00 00 00 00
+ 00 00 00 00 df 33 00 00 32 3d 00 00 a0 43 00 00
+ ad 36 00 00 00 00 00 00 00 00 00 00 c2 43 00 00
+ 00 00 00 00 61 0b 00 00 dd 0a 00 00 77 0b 00 00
+ 11 3c 00 00 17 3c 00 00 1c 3c 00 00 20 3c 00 00
+ 2a 3c 00 00 31 3c 00 00 3f 3c 00 00 81 3c 00 00
+ 00 00 00 00 00 00 00 00 96 3c 00 00 f0 45 00 00
+ 96 47 00 00 0b 48 00 00 91 49 00 00 80 4b 00 00
+ bc 4b 00 00 e6 49 00 00 9c 3c 00 00 79 3c 00 00
+ 00 00 00 00 00 00 00 00 00 00 00 00 ec 4d 00 00
+ a0 3c 00 00 a9 3c 00 00 00 00 00 00 00 00 00 00
+ 00 00 00 00 00 00 00 00 64 00 50 b5 00 19 cf 00
+ 28 91 0e 14 a5 0e 23 00 01 23 23 01 14 00 00 00
+ 0c 11 00 00 00 00 83 17 00 00 c8 0e 01 00 00 0d
+ 0e df 0c 00 00 00 00 01 01 00 00 00 00 af 1d 31
+ 4e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
+ b2 2d 00 00 00 00 0b 94 21 00 00 b3 ef dc 01 58
+ 03 00 00 30 34 2f 32 35 2f 32 32 00 00 00 00 00
+ 00 00 00 00 00 00 00 21 01 10 00 00 00 80 01 00
+ 00 00 00 00 30 30 30 30 30 30 30 30 30 30 30 30
+ 00 00 00 00 00 00 00 00 03 42 00 00 62 5a 08 00
+ ad c1 45 18 8a 1c 7f 9f 7f fa 3e 96 54 33 00 00
+ 00 00 00 00 c9 4c 00 00 00 00 00 00 00 00 97 4e
+ 00 00 01 00 10 00 bf 09 30 00 02 00 94 22 00 00
+ 00 00 01 00 44 00 6b 09 00 00 a2 04 00 00 56 09
+ 00 00 fa 04 00 00 00 00 00 00 66 08 00 00 78 08
+ 00 00 61 0b 00 00 dd 0a 00 00 77 0b 00 00 8d 0b
+ 00 00 0d 0e 00 00 df 0c 00 00 00 00 00 00 00 00
+ 00 00 00 00 00 00 2c 22 00 00 30 c0 61 40 00 00
+ 00 10 00 00 00 00 08 23 61 00 80 00 00 00 80 00
+ 00 00 88 23 61 00 80 00 00 00 80 00 00 00 08 24
+ 61 00 80 00 00 00 80 00 00 00 88 24 61 00 80 00
+ 00 00 80 00 00 00 08 25 61 00 80 00 00 00 80 00
+ 00 00 88 25 61 00 80 00 00 00 80 00 00 00 08 26
+ 61 00 80 00 00 00 80 00 00 00 00 2a 13 00 00 00
+ 04 00 00 00 04 00 00 2a 13 00 00 00 01 00 00 00
+ 01 00 00 6e 13 00 00 00 04 00 00 00 04 00 00 6e
+ 13 00 00 00 01 00 00 00 01 00 4c 00 12 00 3f 00
+ 00 00 00 00 00 00 0c 24 02 00 01 00 00 00 00 00
+ 00 00 e4 05 02 00 7c 00 00 00 00 00 00 00 e4 05
+ 02 00 7c 00 00 00 18 00 00 00 e4 05 02 00 7c 00
+ 00 00 0c 00 00 00 e4 05 02 00 7c 00 00 00 04 00
+ 00 00 e4 05 02 00 7c 00 00 00 08 00 00 00 e4 05
+ 02 00 7c 00 00 00 14 00 00 00 20 0e 9a 00 00 00
+ 02 00 00 00 02 00 00 0e 9a 00 00 00 02 00 00 00
+ 02 00 00 0e 9a 00 01 00 00 00 01 00 00 00 34 c0
+ 61 40 00 00 00 80 00 00 00 00 00 0c 82 00 ff ff
+ ff ff 00 00 00 00 00 0c 82 00 01 00 00 00 00 00
+ 00 00 00 0c 82 00 02 00 00 00 00 00 00 00 00 0c
+ 82 00 04 00 00 00 00 00 00 00 00 0c 82 00 08 00
+ 00 00 00 00 00 00 00 0c 82 00 10 00 00 00 00 00
+ 00 00 00 0c 82 00 20 00 00 00 00 00 00 00 90 02
+ 82 00 01 00 00 00 00 00 00 00 88 02 82 00 ff 00
+ 00 00 00 00 00 00 c0 04 82 00 07 00 00 00 00 00
+ 00 00 00 0a 00 00 00 00 f0 1f 00 00 00 00 88 80
+ 08 00 00 00 0f 00 00 00 01 00 40 c0 08 00 00 00
+ 0c 00 00 00 0c 00 40 c0 08 00 1f 00 00 00 00 00
+ 00 00 00 0a 00 00 00 00 f0 1f 00 00 00 00 74 09
+ 9a 00 0f 00 00 00 00 00 00 00 e8 73 13 00 01 00
+ 00 00 01 00 00 00 0c 06 9a 00 40 00 00 00 40 00
+ 00 00 64 00 12 00 40 00 00 00 40 00 00 00 04 14
+ 00 00 04 00 00 00 00 00 00 00 04 14 00 00 08 00
+ 00 00 08 00 00 00 14 38 82 00 00 00 01 00 00 00
+ 01 00 00 0a 00 00 00 00 f0 1f 00 00 00 00 0c 14
+ 00 00 01 00 00 00 01 00 00 00 0c 14 00 00 02 00
+ 00 00 01 00 00 00 88 54 62 00 00 00 01 00 00 00
+ 00 00 88 54 62 00 00 00 02 00 00 00 00 00 88 54
+ 62 00 00 00 04 00 00 00 00 00 9c 8b 11 00 00 00
+ 00 80 00 00 00 00 14 0c 82 00 01 00 00 00 00 00
+ 00 00 14 0c 82 00 02 00 00 00 00 00 00 00 14 0c
+ 82 00 04 00 00 00 00 00 00 00 14 0c 82 00 08 00
+ 00 00 00 00 00 00 14 0c 82 00 10 00 00 00 00 00
+ 00 00 14 0c 82 00 20 00 00 00 00 00 00 00 9c 8b
+ 11 00 00 00 00 80 00 00 00 00 10 01 82 00 01 00
+ 00 00 00 00 00 00 d4 06 82 00 ff 03 00 00 00 00
+ 00 00 14 0c 82 00 3f 00 00 00 01 00 00 00 00 14
+ 00 00 02 00 00 00 00 00 00 00 44 c1 61 60 01 00
+ 00 00 01 00 00 00 20 87 08 00 04 00 00 00 00 00
+ 00 00 40 00 82 00 01 00 00 00 00 00 00 00 54 9b
+ 41 00 ff 00 00 00 00 00 00 00 68 9b 41 00 03 00
+ 00 00 00 00 00 00 40 80 11 00 02 00 00 00 00 00
+ 00 00 04 0c 82 00 01 00 00 00 00 00 00 00 04 14
+ 00 00 00 04 00 00 00 00 00 00 34 04 82 00 01 00
+ 00 00 00 00 00 00 68 08 00 01 02 03 04 05 06 07
+ 00 01 02 03 04 05 06 07 41 06 24 06 00 00 00 07
+ 00 02 bf 00 01 51 00 04 bf 00 02 5e 00 01 bf 00
+ 03 52 00 03 bf 00 84 19 00 00 4f 00 85 7b 59 98
+ 4f 00 06 ff 00 00 4f 00 07 ff 00 00 ef 00 08 ff
+ 00 00 ef 00 09 ff 00 00 ef 00 0a ff 00 00 ef 00
+ 0b ff 00 00 ef 00 0c ff 00 00 ef 00 0d ff 00 00
+ ef 00 0e ff 00 00 ef 00 0f ff 00 00 ef 00 10 42
+ 50 11 e4 00 11 41 42 0b e2 00 12 40 41 0a e1 00
+ 13 70 51 12 e5 00 14 ff 00 00 ef 00 15 ff 00 00
+ ef 00 16 ff 00 00 ef 00 17 ff 00 00 ef 00 18 ff
+ 00 00 ef 00 19 ff 00 00 ef 00 1a ff 00 00 ef 00
+ 1b ff 00 00 ef 00 1c ff 00 00 ef 00 1d ff 00 00
+ ef 00 1e ff 00 00 ef 00 1f ff 00 00 ef 00 00 ff
+ 00 00 0f 00 00 ff 00 00 0f 00 00 ff 00 00 0f 00
+ 00 ff 00 00 0f 00 10 07 16 10 00 bd 0a 01 f0 10
+ 03 00 00 00 00 ff ff ff 00 ff ff 00 10 00 00 00
+ 00 00 00 1f 01 00 00 00 00 00 00 ff ff ff 00 ff
+ ff 00 10 00 00 00 00 00 00 2f 02 00 00 00 00 00
+ 00 ff ff ff 00 ff ff 00 10 00 00 00 00 00 00 3f
+ 03 00 00 00 00 00 00 ff ff ff 00 ff ff 00 10 00
+ 00 00 00 00 00 4f 04 00 00 00 00 00 00 ff ff ff
+ 00 ff ff 00 10 00 00 00 00 00 00 5f 05 00 00 00
+ 00 00 00 ff ff ff 00 ff ff 00 10 00 00 00 00 00
+ 00 6f 06 00 00 00 00 00 00 ff ff ff 00 ff ff 00
+ 10 00 00 00 00 00 00 7f 07 00 00 00 00 00 00 ff
+ ff ff 00 ff ff 00 10 00 00 00 00 00 00 8f 00 00
+ 00 00 00 00 00 ff ff ff 00 ff ff 00 10 00 00 00
+ 00 00 00 9f 01 00 00 00 00 00 00 ff ff ff 00 ff
+ ff 00 10 00 00 00 00 00 00 af 02 00 00 00 00 00
+ 00 ff ff ff 00 ff ff 00 10 00 00 00 00 00 00 bf
+ 00 00 00 00 00 cf 04 00 00 00 00 00 00 ff ff ff
+ 00 ff ff 00 10 00 00 00 00 00 00 df 05 00 00 00
+ 00 ef 06 00 00 00 00 00 00 ff ff ff 00 ff ff 00
+ 10 00 00 00 00 00 00 ff 07 00 00 00 00 00 00 ff
+ ff ff 00 ff ff 00 10 00 00 00 00 00 00 00 01 02
+ 03 04 05 06 07 08 09 0a 0b 0c 0d 0e 0f 10 11 12
+ 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f 10 04 20
+ 04 00 00 80 00 b8 4c 0a ff e0 93 04 00 20 d6 13
+ 00 e0 93 04 01 20 d6 13 00 ff 00 00 00 00 00 00
+ 00 00 00 00 00 00 00 00 ff 00 00 00 00 00 00 00
+ 00 00 00 00 01 00 00 00 00 ff 00 00 00 00 00 00
+ 00 20 05 11 01 00 00 35 0c 00 ff ff ff ff ff ff
+ ff ff ff 00 00 00 00 10 05 11 01 00 00 00 00 ff
+ ff 00 00 00 00 00 00 00 00 00 00 00 00 30 08 10
+ 01 14 01 15 0e 00 00 00 00 00 00 00 00 00 00 00
+ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10
+ 0d 17 34 b0 8f 11 00 00 00 00 00 00 00 00 00 34
+ a8 04 82 00 00 00 00 00 00 00 00 00 34 a0 04 82
+ 00 00 00 00 00 00 00 00 00 34 d4 02 82 00 00 00
+ 00 00 00 00 00 00 34 a4 04 82 00 00 00 00 00 00
+ 00 00 00 34 7c 14 00 00 00 00 00 00 00 00 00 00
+ 34 08 0e 82 00 00 00 00 00 00 00 00 00 34 0c 0e
+ 82 00 00 00 00 00 00 00 00 00 34 a8 83 11 00 00
+ 00 00 00 00 00 00 00 34 78 01 82 00 00 00 00 00
+ 00 00 00 00 34 78 01 82 00 00 00 00 00 00 00 00
+ 00 34 ac 04 82 00 00 00 00 00 00 00 00 00 34 94
+ 10 82 00 00 00 00 00 00 00 00 00 34 88 10 82 00
+ 00 00 00 00 00 00 00 00 34 8c 10 82 00 00 00 00
+ 00 00 00 00 00 34 90 10 82 00 00 00 00 00 00 00
+ 00 00 34 ac 83 11 00 00 00 00 00 00 00 00 00 34
+ 78 01 82 00 00 00 00 00 00 00 00 00 34 d4 02 82
+ 00 00 00 00 00 00 00 00 00 34 78 05 82 00 00 00
+ 00 00 00 00 00 00 34 b0 04 82 00 00 00 00 00 00
+ 00 00 00 34 78 01 82 00 00 00 00 00 00 00 00 00
+ 34 7c 07 82 00 00 00 00 00 00 00 00 00 10 03 1b
+ 05 80 00 07 60 05 08 40 08 09 60 0d 0a 40 10 0d
+ f0 17 0c e0 15 0e 60 18 0f 40 1c 10 e0 23 15 80
+ 24 16 26 29 17 60 2d 18 40 30 19 60 35 1a 60 39
+ 1b 60 3d 1d e0 43 1e a5 44 1f 60 49 20 60 4d 21
+ 60 51 22 fc 47 23 a0 58 24 66 59 25 2c 5a 26 f2
+ 5a 68 74 e1 61 8d e9 54 da de d0 33 c4 0d 30 30
+ cb 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
+ 00 4e 56 49 44 49 41 00 00 00 00 00 00 00 00 00
+ 00 00 00 00 00 4e 56 49 44 49 41 20 43 6f 72 70
+ 6f 72 61 74 69 6f 6e 00 00 00 00 00 00 00 00 00
+ 00 00 00 00 00 00 00 00 22 05 02 0e 0c 00 00 00
+ 00 00 00 00 00 00 00 00 00 50 04 13 0e 07 95 01
+ 95 01 d0 07 a0 0f 1b 00 1b 00 0f 0f 32 ff 01 3f
+ 08 95 01 95 01 d0 07 a0 0f 1b 00 1b 00 0f 0f 32
+ ff 01 3f 0b 95 01 95 01 d0 07 a0 0f 1b 00 1b 00
+ 0f 0f 32 ff 01 3f 04 e1 00 13 01 94 11 28 23 e1
+ 00 13 01 01 01 14 ff 01 02 0c 1b 00 1b 00 40 06
+ 80 0c 1b 00 1b 00 01 01 28 ff 01 3f 41 1b 00 1b
+ 00 40 06 8c 0a 1b 00 28 00 01 ff 28 ff 03 3f 42
+ 1b 00 1b 00 40 06 8c 0a 1b 00 28 00 01 ff 28 ff
+ 03 3f 80 1b 00 1b 00 20 03 54 06 1b 00 1b 00 01
+ 01 14 ff 01 3f 81 1b 00 1b 00 20 03 54 06 1b 00
+ 1b 00 01 01 14 ff 01 3f 82 1b 00 1b 00 20 03 54
+ 06 1b 00 1b 00 01 01 14 ff 01 3f 83 1b 00 1b 00
+ 20 03 54 06 1b 00 1b 00 01 01 14 ff 01 3f 0d 1b
+ 00 1b 00 20 03 54 06 1b 00 1b 00 01 01 14 ff 01
+ 3f 0e 1b 00 1b 00 e8 03 d0 07 0d 00 1b 00 01 ff
+ 28 ff 01 1f 0f 95 01 95 01 d0 07 a0 0f 1b 00 1b
+ 00 0f 0f 32 ff 01 3f 10 04 02 06 00 00 00 07 00
+ 07 00 07 00 07 00 07 10 05 04 10 04 0f 0f 0f 0f
+ 2f 2f 2f 2f 1c 1c 1c 1c 0f 46 40 00 0f 0f 0f 0f
+ 2f 2f 2f 2f 1d 1d 1d 1d 0f 46 40 00 0f 0f 0f 0f
+ 2f 2f 2f 2f 1e 1e 1e 1e 0f 46 40 00 0f 0f 0f 0f
+ 2f 2f 2f 2f 1f 1f 1f 1f 0f 46 40 00 0f 0f 0f 0f
+ 2d 2d 2d 2d 19 19 19 19 0f 46 40 00 0f 0f 0f 0f
+ 2c 2c 2c 2c 1b 1b 1b 1b 0f 46 40 00 0f 0f 0f 0f
+ 2b 2b 2b 2b 1d 1d 1d 1d 0f 46 40 00 0f 0f 0f 0f
+ 2a 2a 2a 2a 1f 1f 1f 1f 0f 46 40 00 0e 0e 0e 0e
+ 29 29 29 29 18 18 18 18 0f 46 40 00 0e 0e 0e 0e
+ 28 28 28 28 1a 1a 1a 1a 0f 46 40 00 0e 0e 0e 0e
+ 27 27 27 27 1c 1c 1c 1c 0f 46 40 00 0e 0e 0e 0e
+ 26 26 26 26 1e 1e 1e 1e 0f 46 40 00 0f 0f 0f 0f
+ 2a 2a 2a 2a 1f 1f 1f 1f 0f 46 40 00 20 19 04 00
+ 00 50 32 74 40 e8 80 e4 57 01 04 04 06 31 1a 00
+ 00 07 10 00 00 3d 11 00 00 3b 12 00 00 39 13 00
+ 00 37 14 00 00 35 15 00 00 33 16 00 00 10 08 0e
+ 05 00 2c 04 04 d1 84 00 00 00 00 0a 05 00 06 00
+ 00 00 00 00 38 3d 3e 3f 3a 00 00 00 00 05 05 05
+ 05 00 00 00 00 00 00 00 00 88 58 24 00 00 00 00
+ 00 75 40 00 00 00 00 0a 05 00 06 00 00 00 00 00
+ 38 3d 3e 3f 3a 3f 3f 3f 3f 05 05 05 05 0a 0a 0a
+ 0a 00 00 00 00 88 58 24 00 00 00 00 00 65 19 00
+ 00 00 00 0a 05 00 06 00 00 00 00 00 48 3a 3a 3a
+ 3a 3a 3a 3a 3a 00 00 00 00 00 00 00 00 00 00 00
+ 00 f8 5a 24 00 00 00 00 00 00 00 00 00 00 00 0a
+ 0a 00 06 00 00 00 00 00 58 3a 3a 3a 3a 3a 3a 3a
+ 3a 00 00 00 00 00 00 00 00 00 00 00 00 f8 5a 24
+ 00 00 00 00 00 03 00 00 01 0a 05 0f 46 40 00 00
+ 03 00 44 06 00 00 01 0a 08 0f 46 40 00 00 03 00
+ 44 08 00 00 01 0a 05 0f 46 40 00 00 03 00 44 0a
+ 00 00 01 0a 05 0f 46 40 00 00 03 00 44 0c 00 00
+ 01 0a 08 0f 46 40 00 00 03 00 44 10 08 0e 05 00
+ 2c 04 04 d1 84 00 00 00 00 0a 05 00 06 00 00 00
+ 00 00 38 3d 3e 3f 3a 00 00 00 00 05 05 05 05 00
+ 00 00 00 00 00 00 00 88 58 24 00 00 00 00 00 75
+ 40 00 00 00 00 0a 05 00 06 00 00 00 00 00 38 3d
+ 3e 3f 3a 00 00 00 00 05 05 05 05 00 00 00 00 00
+ 00 00 00 88 58 24 00 00 00 00 00 65 19 00 00 00
+ 00 0a 05 00 06 00 00 00 00 00 48 3a 3a 3a 3a 00
+ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 f8
+ 5a 24 00 00 00 00 00 00 00 00 00 00 00 0a 0a 00
+ 06 00 00 00 00 00 58 3a 3a 3a 3a 00 00 00 00 00
+ 00 00 00 00 00 00 00 00 00 00 00 f8 5a 24 00 00
+ 00 00 00 0c 00 00 01 0a 05 0f 46 40 00 00 03 00
+ 44 0d 00 00 01 0a 08 0f 46 40 00 00 03 00 44 0e
+ 00 00 01 0a 05 0f 46 40 00 00 03 00 44 0f 01 00
+ 01 0a 05 0f 46 40 00 00 03 00 44 10 01 00 01 0a
+ 08 0f 46 40 00 00 03 00 44 10 08 0e 05 00 2c 04
+ 04 d1 84 00 00 00 00 0a 05 00 06 00 00 00 00 00
+ 38 3d 3e 3f 3a 00 00 00 00 05 05 05 05 00 00 00
+ 00 00 00 00 00 88 58 24 00 00 00 00 00 75 40 00
+ 00 00 00 0a 05 00 06 00 00 00 00 00 38 3d 3e 3f
+ 3a 3f 3f 3f 3f 05 05 05 05 05 05 05 05 00 00 00
+ 00 88 58 24 00 00 00 00 00 65 19 00 00 00 00 0a
+ 05 00 06 00 00 00 00 00 48 3a 3a 3a 3a 3a 3a 3a
+ 00 00 00 00 00 00 00 00 00 00 00 0a 0a 00 06 00
+ 00 00 00 00 58 3a 3a 3a 3a 3a 3a 3a 3a 00 00 00
+ 00 00 00 00 00 00 00 00 00 f8 5a 24 00 00 00 00
+ 00 0c 01 00 01 0a 05 0f 46 40 00 00 03 00 44 0d
+ 01 00 01 0a 08 0f 46 40 00 00 03 00 44 0e 02 00
+ 01 0a 05 0f 46 40 00 00 03 00 44 0f 02 00 01 0a
+ 05 0f 46 40 00 00 03 00 44 10 02 00 01 0a 08 0f
+ 46 40 00 00 03 00 44 10 08 0e 05 00 2c 04 04 d1
+ 84 00 00 00 00 0a 05 00 06 00 00 00 00 00 38 3d
+ 00 00 00 88 58 24 00 00 00 00 00 75 40 00 00 00
+ 00 0a 05 00 06 00 00 00 00 00 38 3d 3e 3f 3a 00
+ 00 00 00 05 05 05 05 00 00 00 00 00 00 00 00 88
+ 58 24 00 00 00 00 00 65 19 00 00 00 00 0a 05 00
+ 06 00 00 00 00 00 48 3a 3a 3a 3a 00 00 00 00 00
+ 00 00 00 00 00 00 00 00 00 0a 0a 00 06 00 00 00
+ 00 00 58 3a 3a 3a 3a 00 00 00 00 00 00 00 00 00
+ 00 00 00 00 00 00 00 f8 5a 24 00 00 00 00 00 0c
+ 00 00 01 0a 05 0f 46 40 00 00 03 00 44 0d 00 00
+ 01 0a 08 0f 46 40 00 00 03 00 44 0e 00 00 01 0a
+ 05 0f 46 40 00 00 03 00 44 0f 01 00 01 0a 05 0f
+ 46 40 00 00 03 00 44 10 01 00 01 0a 08 0f 46 40
+ 00 00 03 00 44 10 08 0e 05 00 2c 04 04 d1 84 00
+ 3a 00 00 00 00 05 05 05 05 00 00 00 00 00 00 00
+ 00 88 58 24 00 00 00 00 00 75 40 00 00 00 00 0a
+ 05 00 06 00 00 00 00 00 38 3d 3e 3f 3a 3f 3f 3f
+ 3f 05 05 05 05 08 08 08 08 00 00 00 00 88 58 24
+ 00 00 00 00 00 65 19 00 00 00 00 0a 05 00 06 00
+ 00 00 00 00 48 3a 3a 3a 3a 3a 3a 3a 3a 00 00 00
+ 00 00 00 00 00 00 00 0a 0a 00 06 00 00 00 00 00
+ 58 3a 3a 3a 3a 3a 3a 3a 3a 00 00 00 00 00 00 00
+ 00 00 00 00 00 f8 5a 24 00 00 00 00 00 0c 01 00
+ 01 0a 05 0f 46 40 00 00 03 00 44 0d 01 00 01 0a
+ 08 0f 46 40 00 00 03 00 44 0e 02 00 01 0a 05 0f
+ 46 40 00 00 03 00 44 0f 02 00 01 0a 05 0f 46 40
+ 00 00 03 00 44 10 02 00 01 0a 08 0f 46 40 00 00
+ 03 00 44 10 08 0e 05 00 2c 04 04 d1 84 00 00 00
+ 58 24 00 00 00 00 00 75 40 00 00 00 00 0a 05 00
+ 06 00 00 00 00 00 38 3d 3e 3f 3a 00 00 00 00 05
+ 05 05 05 00 00 00 00 00 00 00 00 88 58 24 00 00
+ 00 00 00 65 19 00 00 00 00 0a 05 00 06 00 00 00
+ 00 00 48 3a 3a 3a 3a 00 00 00 00 00 00 00 00 00
+ 00 00 00 00 00 00 00 f8 5a 24 00 00 00 00 00 00
+ 00 00 00 00 00 0a 0a 00 06 00 00 00 00 00 58 3a
+ 3a 3a 3a 00 00 00 00 00 00 00 00 00 00 00 00 00
+ 00 00 00 f8 5a 24 00 00 00 00 00 0c 00 00 01 0a
+ 05 0f 46 40 00 00 03 00 44 0d 00 00 01 0a 08 0f
+ 46 40 00 00 03 00 44 0e 00 00 01 0a 05 0f 46 40
+ 00 00 03 00 44 0f 01 00 01 0a 05 0f 46 40 00 00
+ 03 00 44 10 01 00 01 0a 08 0f 46 40 00 00 03 00
+ 44 7a 14 c0 61 40 01 00 c2 0d 74 05 00 6e 14 c0
+ 61 40 ff ff bf ff 00 00 00 00 6e e4 c5 61 40 fe
+ ff ff ff 00 00 00 00 71 5b b0 1a 71 5b 63 17 5b
+ 68 17 71 56 00 ff 72 71 6e 0c c1 61 40 fe ff ff
+ ff 00 00 00 00 6e 40 65 61 80 fe ff ff ff 00 00
+ 00 00 71 10 07 01 60 01 60 00 00 00 00 00 00 00
+ 00 00 00 00 00 00 00 00 00 00 6e 00 23 61 40 ff
+ ff 80 fc 00 00 23 00 71 6e 00 23 61 40 ff ff 80
+ fc 00 00 27 00 71 6e 00 23 61 40 ff ff 80 fc 00
+ 00 2b 00 71 6e 00 23 61 40 ff ff 80 fc 00 00 2f
+ 00 71 41 23 10 08 25 19 cb bd dc 4e 78 08 00 00
+ 00 00 00 00 67 19 ec 19 c1 00 00 00 00 00 00 00
+ 00 00 00 00 00 02 03 80 01 10 00 62 04 0e 03 80
+ 01 10 00 02 04 0e 11 02 01 10 00 02 00 2e 32 03
+ 02 10 00 02 00 fe 40 04 00 00 00 00 00 0f 00 00
+ 00 00 00 00 00 0f 00 00 00 00 00 00 00 0f 00 00
+ 00 00 00 00 00 41 06 0f 04 02 0f 06 00 00 10 ff
+ 03 00 80 ff 03 00 80 ff 03 00 10 ff 03 00 10 ff
+ 03 00 10 ff 03 00 10 ff 03 00 10 ff 03 00 10 ff
+ 03 00 10 ff 03 00 00 ff 03 00 00 ff 03 00 00 ff
+ 03 00 00 ff 03 00 00 40 05 20 04 01 ff 00 00 00
+ ff 00 00 00 ff 00 00 00 ff 00 00 00 ff 00 00 00
+ ff 00 00 00 ff 00 00 00 ff 00 00 00 40 05 10 04
+ 00 61 10 00 00 ff 01 00 00 ff 02 00 00 ff 03 00
+ 00 ff 04 00 00 ff 00 00 00 ff 00 00 00 ff 00 00
+ 00 ff 00 00 00 ff 00 00 00 ff 00 00 00 ff 00 00
+ 00 10 05 40 01 00 00 00 0b 03 00 00 0a 02 00 00
+ 08 02 00 20 04 02 00 80 00 00 00 80 00 00 00 80
+ 00 00 00 80 00 00 00 20 00 00 00 20 00 03 00 00
+ 0c 03 00 00 0a 03 00 80 0b 03 00 80 0b 03 00 80
+ 0b 03 00 80 0b 03 71 71 6e 14 c0 61 40 ff ff 3f
+ fa 00 00 c0 01 74 05 00 6e 14 c0 61 40 f7 ff ff
+ ff 08 00 00 00 6e b8 c1 61 40 ff ff 3f 81 00 03
+ 00 08 6e 00 23 61 40 ff ff 83 fc 00 00 00 00 71
+ 58 40 c0 61 40 10 00 00 0a 1d 00 00 0a 04 00 00
+ 08 04 00 20 04 04 00 80 00 00 00 80 00 00 00 80
+ 00 00 00 80 00 00 00 20 00 00 00 20 00 1d 00 00
+ 0c 1d 00 00 0a 1d 00 80 0a 1d 00 80 0a 1d 00 80
+ 0a 1d 00 80 0a 1d 71 6e 00 23 61 40 ff ff fc fc
+ 00 00 02 03 71 7a 14 c0 61 40 14 00 c2 0d 74 05
+ 00 6e 14 c0 61 40 ff ff bf ff 00 00 00 00 74 14
+ 00 71 6e 14 c0 61 40 ff ff ff f2 00 00 00 00 74
+ 0a 00 6e 00 23 61 40 ff ff fc ff 00 00 01 00 6e
+ 0c c1 61 60 ff bf ff ff 00 40 00 00 6e 14 c0 61
+ 40 ff ff 7f ff 00 00 00 00 6e 30 c1 61 60 f0 ff
+ ff ff 0f 00 00 00 6e 34 c0 61 40 ff ff ee 7f 00
+ 00 00 80 56 17 ff 6e 0c c1 61 60 fc ff ff ff 01
+ 00 00 00 6e 30 c1 61 60 0f ff ff ff f0 00 00 00
+ 74 0a 00 6e 30 c1 61 60 0f ff ff ff 00 00 00 00
+ 6e 10 c1 61 40 e0 e0 e0 e0 00 00 00 00 6e 2c c1
+ 61 40 e0 e0 e0 e0 00 00 00 00 3a 05 15 6e 40 c1
+ 61 60 fd ff ff ff 02 00 00 00 98 0a 01 00 00 01
+ fe 01 71 98 02 01 00 00 01 d0 00 6e 10 c1 61 40
+ e0 e0 e0 e0 10 10 10 10 6e 2c c1 61 40 e0 e0 e0
+ e0 10 10 10 10 71 5f 0c c1 61 60 00 01 40 ff 40
+ 00 00 00 00 40 65 61 80 fe bf 00 bf 3a 00 03 5b
+ 14 1c 72 71 3a 07 01 38 6e 40 c1 61 60 fe ff ff
+ ff 01 00 00 00 72 5b 68 1d 52 e8 df 00 71 71 6e
+ 0c c1 61 60 fe ff 00 ff 00 00 00 00 6e 30 c1 61
+ 40 f0 ff ff ff 00 00 00 00 6e b0 c1 61 40 f0 ff
+ ff ff 00 00 00 00 6e 34 c0 61 40 ff ff ee 7f 00
+ 00 11 80 56 17 ff 6e 14 c0 61 40 ff ff 7f ff 00
+ 00 80 00 6e 00 23 61 40 ff ff fc ff 00 00 02 00
+ 74 05 00 6e 14 c0 61 40 ff ff ff f2 00 00 00 0d
+ 74 05 00 6e 14 c0 61 40 ff ff bf ff 00 00 40 00
+ 74 05 00 6e 14 c0 61 40 f7 ff ff ff 08 00 00 00
+ 6e 0c c0 61 40 ff f0 f0 f0 00 03 05 05 6e b8 c1
+ 61 40 ff ff ff 81 00 03 00 08 6e 00 23 61 40 ff
+ ff 83 fc 00 00 00 00 6e 40 c1 61 60 fe ff ff ff
+ 00 00 00 00 71 6e 0c c1 61 60 fd ff ff ff 02 00
+ 00 00 6e 30 c1 61 60 ff ff bf ff 00 00 40 00 71
+ 10 05 40 01 01 00 00 00 00 0a 10 00 00 00 a0 40
+ 00 00 80 40 00 00 80 40 00 00 80 40 00 00 80 40
+ 00 00 80 40 00 00 20 00 00 32 10 80 00 0a 90 80
+ 00 00 80 80 00 00 80 80 00 00 80 80 00 00 80 80
+ 00 00 80 80 00 71 71 6e 40 65 61 80 fe ff ff ff
+ 00 00 00 00 71 71 98 07 01 00 00 01 ef 10 71 98
+ 07 01 00 00 01 ef 00 71 58 40 c0 61 40 10 00 00
+ 00 00 32 10 00 00 00 a0 40 00 00 80 40 00 00 80
+ 40 00 00 80 40 00 00 80 40 00 00 80 40 00 00 20
+ 00 00 32 10 80 00 96 90 80 00 00 80 80 00 00 80
+ 80 00 00 80 80 00 00 80 80 00 00 80 80 00 71 42
+ 15 02 07 13 04 03 0a 04 28 23 28 23 01 04 04 06
+ 00 1d 00 00 00 00 00 00 00 00 00 00 00 00 00 00
+ 00 00 14 00 02 19 0a 03 1e 14 04 2b 28 06 1e 00
+ 03 25 0f 04 2f 21 06 28 00 04 32 14 06 3c 00 06
+ 14 00 02 19 0a 03 1e 14 04 2b 28 06 1e 00 03 25
+ 0f 04 2f 21 06 28 00 04 32 14 06 3c 00 06 14 00
+ 02 19 0a 03 1e 14 04 2b 28 06 1e 00 03 25 0f 04
+ 2f 21 06 28 00 04 32 14 06 3c 00 06 0f 00 02 16
+ 09 03 1d 0e 04 27 12 06 17 00 03 21 09 04 27 0e
+ 06 1f 00 04 27 09 06 27 00 06 62 1e 00 00 f2 1e
+ 00 00 82 1f 00 00 12 20 00 00 a2 20 00 00 32 21
+ 00 00 10 08 00 00 00 11 08 00 1e 00 00 00 00 01
+ 05 05 00 40 00 00 00 00 00 30 00 14 00 00 00 00
+ 01 05 05 00 40 00 00 00 00 00 30 00 10 00 00 00
+ 00 01 05 05 00 40 00 00 00 00 00 30 00 0c 00 00
+ 00 00 01 05 05 00 40 00 00 00 00 00 30 00 0a 00
+ 00 00 00 01 05 05 00 40 00 00 00 00 00 30 00 09
+ 00 00 00 00 01 05 05 00 40 00 00 00 00 00 30 00
+ 08 00 00 00 00 01 05 05 00 40 00 00 00 00 00 30
+ 00 06 00 00 00 00 01 05 05 00 40 00 00 00 00 00
+ 30 00 10 08 00 00 00 11 08 00 1e 00 00 00 00 00
+ 05 05 00 00 00 00 00 00 00 00 00 14 00 00 00 00
+ 00 05 05 00 00 00 00 00 00 00 00 00 10 00 00 00
+ 00 03 00 01 00 50 00 00 00 00 00 00 00 0c 00 00
+ 00 00 03 00 01 00 50 00 00 00 00 00 00 00 0a 00
+ 00 00 00 00 05 05 00 00 00 00 00 00 00 00 00 09
+ 00 00 00 00 03 00 01 00 40 00 00 00 00 00 00 00
+ 08 00 00 00 00 03 00 01 00 40 00 00 00 00 00 00
+ 00 06 00 00 00 00 00 05 05 00 00 00 00 00 00 00
+ 00 00 10 08 00 00 00 11 08 00 1e 00 00 00 00 00
+ 00 00 ];
diff --git a/Linux_for_Tegra/source/hardware/nvidia/t23x/nv-public/nv-platform/tegra234-p3737-0000+p3701-0008-nv.dts b/Linux_for_Tegra/source/hardware/nvidia/t23x/nv-public/nv-platform/tegra234-p3737-0000+p3701-0008-nv.dts
index 5aabde9f5..a71a8b4eb 100644
--- a/Linux_for_Tegra/source/hardware/nvidia/t23x/nv-public/nv-platform/tegra234-p3737-0000+p3701-0008-nv.dts
+++ b/Linux_for_Tegra/source/hardware/nvidia/t23x/nv-public/nv-platform/tegra234-p3737-0000+p3701-0008-nv.dts
@@ -5,4 +5,5 @@
#include "staging/tegra234-p3737-0000+p3701-0008.dts"
#include "tegra234-p3737-0000+p3701-xxxx-nv-common.dtsi"
+#include "tegra234-dcb-p3701-0000-a02-p3737-0000-a01_hdmi.dtsi"
#include "tegra234-p3701-0008.dtsi"
tegra234-p3737-0000+p3701-0008-nv.dts is a device tree that is only for Orin AGX industrial. It won’t be in use when you are trying to flash a Orin Nano.
So do you know how can I achieve 4K 30Hz or 2K 60Hz over HDMI?
請問你是要用Orin NX/Nano還是其他平台?
前面我們要說的只有你改錯檔案而已. 你大方向是對的只是檔案全用錯.
So do you know which file to edit?
You could read your flash log. It will tell you the answer.
pinmux and kernel dts are all different.
And if you want to enable HDMI on JP6, please check p3509 board config too. It already configured the HDMI mode with what you need in rel-36.
