I want to bring up HDMI on custom board using jetson agx orin but unable…
I have taken the reference of tegra234-dcb-p3767-0000-hdmi.dts and added it into the tegra234-dcb-p3737-0000-p3701-0000.dtsi but still getting problem…
var_log_Xor.0.log_1.txt (22.6 KB)
check this log once
please refer to
then please review your hardware design.
Did you cross verified that, everything is fine from software side?
yes, they look fine to me.
this is not related to original topic. Please ask in another thread.
As per the Technical Documentation of Jetson agx orin for HDMI:
Display : 1x 8K60 multi-mode DP 1.4a (+MST)/eDP 1.4a/HDMI 2.1
but in our custom board Esd protection diodes are compatible for HDMI 2.0.
is this effects on working of HDMI ?
No, it does not matter. Actually HDMI2.1 is not supported on Orin software either.
Module datasheet is just hardware capability. You need to check L4T developer guide for actual software support.
Just to clarify. We’ve been guiding lots of users how to enable HDMI2.0 in the past 3 years.
What you are asking is not the main problem/cause to your issue. If you follow the design guide, then with above software would make it work.
GCTS means HDMI 2.1 Cat 3 Cable Generic Compliance Test Specification (GCTS).
Please directly refer to design guide document. We don’t do fully review to the schematic here.
If any specific questions, we can answer.
Is there still “L4TConfiguration_updated.dts” under bootloader directory after flash? If so, what is the content of it?
It is not available in any folder…
