My xavier-agx (32G memory) , Jetpack 4.4
I have plugin M.2 ssd to xavier-agx and mount it under /home/myName as my home directory, and tensorRT-Yolov4(GitHub - jkjung-avt/tensorrt_demos: TensorRT MODNet, YOLOv4, YOLOv3, SSD, MTCNN, and GoogLeNet) has been install and work correctly on this Xavier.
When I load and run 1 python3 trt_yolo.py --video ${HOME}/myVideo.mp4
-m yolov4-416, the memory usage is 3.6Gbyte,
However, if 4 TrtYOLO(args.model(416), args.category_num, args.letter_box) are load and run in same trt_yolo.py and args, the input images are arrange inferenced by above 4 trtYOLO engines round-robin, the memory usage only 5.3 Gbyte, instead of 3.6Gbyte x4 =14.4Gbyte, why?
the memory usage is monitor by tegrastats Utility.
