Why use the command"show interface ib transceiver raw" can get datas,but use command"show interface ib transceiver" ,it show I2C error .QM9700
If there is a basic communication channel to the transceiver, the “show interface ib transceiver raw“ command will provide some data.
The “show interface ib transceiver“ command involves the switch firmware to provide the output. You can try rebooting the switch to see if this helps. You may need to replace the transceiver.
