Wi-FI Module AW-CB375NF not detected on Jetson after upgrading to Jetpack 6.2
I am facing an issue after upgrading to Jetpack 6.2. My wifi module is not being recognized and I don’t have wifi or bluetooth.
Specs:
  • Jetson Orin Nano Developer Kit (8Gb)
  • Jetpack 6.2
  • AW-CB375NF Wi-Fi module
  • Firmware version: 36.4.3
  • Kernel version: 5.15.148-tegra
So far I have checked the module is correctly installed in the PCIe slot.
  • lspci does not show any wireless module.
  • iwconfig shows no wireless extension.
  • dmesg | grep pcie shows Phy link never came up.
Are there any known issues with this wifi moduel?
Would like to get more information. Do you re-flash the system to Jetpack 6.2 and hit the issue? And are you able to re-flash developer kit to 6.1 and see if it is specific to 6.2?
Hello Dane,
Just in case I reflashed to 6.1 and even the latest 6.2.1. all of them with no wifi module detected. As far as I know this issue started when I moved to 6.1, to be honest I did not care much about the wifi working because I had a ethernet cable all the time, but now that I need to use the wifi module is when I noticed there was something wrogn with the wifi module.
You meantioned that Wi-FI Module AW-CB375NF not detected on Jetson after upgrading to Jetpack 6.2, so we would like to know whether it works on either previous Jetpack version. All module should be detected physically, although certain WIFI module needs addition software driver.
We have a list of suggestion:
Wi-Fi 6/6E/7 modules that have been validated with AGX Orin devkits
Yes, when I started using the device, it had Jetpack 5.1.5 and wifi was working fine. Could connect to the network and the device was recognized. After upgrading to Jetpack 6.2 I noticed that my wifi module was not being recognized. I tried plugging wifi modules to the usb port as a workaround but that did not work either.
For upgrading from 5.1.5 to 6.2, do you re-flash the whole system? Although additional driver is not enabled, you should still see it be detected and shown in sudo lspci -v
For upgrading to 6.2 I used the SDK Manager in my Linux PC, selected Jetpack 6.2 and flashed the system.
Running lspci -v gives me this output:
0004:00:00.0 PCI bridge: NVIDIA Corporation Device 229c (rev a1) (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 193, IOMMU group 6
        Bus: primary=00, secondary=01, subordinate=ff, sec-latency=0
        I/O behind bridge: [disabled]
        Memory behind bridge: 40000000-400fffff [size=1M]
        Prefetchable memory behind bridge: [disabled]
        Capabilities: [40] Power Management version 3
        Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
        Capabilities: [70] Express Root Port (Slot-), MSI 00
        Capabilities: [b0] MSI-X: Enable- Count=8 Masked-
        Capabilities: [100] Advanced Error Reporting
        Capabilities: [148] Secondary PCI Express
        Capabilities: [168] Physical Layer 16.0 GT/s <?>
        Capabilities: [18c] Lane Margining at the Receiver <?>
        Capabilities: [1ac] L1 PM Substates
        Capabilities: [1bc] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
        Capabilities: [2bc] Vendor Specific Information: ID=0001 Rev=1 Len=038 <?>
        Capabilities: [2f4] Data Link Feature <?>
        Capabilities: [300] Precision Time Measurement
        Capabilities: [30c] Vendor Specific Information: ID=0004 Rev=1 Len=054 <?>
        Capabilities: [374] Vendor Specific Information: ID=0006 Rev=0 Len=018 <?>
        Kernel driver in use: pcieport
        Kernel modules: tegra_pcie_dma_test
0004:01:00.0 Non-Volatile memory controller: Kingston Technology Company, Inc. Device 5017 (rev 03) (prog-if 02 [NVM Express])
        Subsystem: Kingston Technology Company, Inc. Device 5017
        Memory at 2428000000 (64-bit, non-prefetchable) [size=16K]
        Capabilities: [50] MSI: Enable- Count=1/8 Maskable+ 64bit+
        Capabilities: [70] Express Endpoint, MSI 00
        Capabilities: [b0] MSI-X: Enable+ Count=16 Masked-
        Capabilities: [158] Secondary PCI Express
        Capabilities: [178] Physical Layer 16.0 GT/s <?>
        Capabilities: [19c] Lane Margining at the Receiver <?>
        Capabilities: [1b4] Latency Tolerance Reporting
        Kernel driver in use: nvme
        Kernel modules: nvme
0008:00:00.0 PCI bridge: NVIDIA Corporation Device 229c (rev a1) (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 189, IOMMU group 40
        I/O behind bridge: 00000000-00000fff [size=4K]
0008:01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
        Subsystem: Realtek Semiconductor Co., Ltd. RTL8111/8168 PCI Express Gigabit Ethernet controller
        I/O ports at 300000 [size=256]
        Memory at 3528004000 (64-bit, non-prefetchable) [size=4K]
        Memory at 3528000000 (64-bit, non-prefetchable) [size=16K]
        Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
        Capabilities: [70] Express Endpoint, MSI 01
        Capabilities: [b0] MSI-X: Enable+ Count=4 Masked-
        Capabilities: [d0] Vital Product Data
        Capabilities: [140] Virtual Channel
        Capabilities: [160] Device Serial Number 00-00-00-00-00-00-00-00
        Capabilities: [170] Latency Tolerance Reporting
        Capabilities: [178] L1 PM Substates
        Kernel driver in use: r8168
        Kernel modules: r8168
There is a default WIFI module on Orin Nano developer kit, being connected to Key E slot. Please try and see if it can be detected. Or try any other modules. If none can be detected, it may be hardware defect. You may consider go RMA process if the developer kit is in warranty.
