Windows IoT Core
It is not exactly very clear how to use the metadata buffers, given I just want to forward like /dev/pts/26 output with it, right?
terminal 1:
nvidia@nx_xavier:~$  socat -d -d pty,raw,echo=0 pty,raw,echo=0
2021/05/06 13:13:55 socat[23720] N PTY is /dev/pts/25
2021/05/06 13:13:55 socat[23720] N PTY is /dev/pts/26
2021/05/06 13:13:55 socat[23720] N starting data transfer loop with FDs [5,5] and [7,7]
terminal 2:
sudo apt install csh -y
wget https://iweb.dl.sourceforge.net/project/gpsfeed/gpsfeed-latest.zip
unzip gpsfeed-latest.zip
nvidia@nx_xavier:~$ tclsh8.6 gpsfeed+.tcl
From this point there will be opened GUI of the gpsfeed. - two
GUI windows;
e.g. in serial section goes insteead of default COM1 → /dev/pts/25; baudrate to ->9600
Then in second GUI window = pressing play [ in the top left - a circle icon with a dot in the center;]
Now from the third terminal the GPS feed is available
:~$ cat /dev/pts/26
$GPGGA,180756,3756.2421,N,02346.8948,E,1,04,5.6,724.4,M,34.5,M,,*43
$GPRMC,180756,A,3756.2421,N,02346.8948,E,,,060521,5,E,A*01
$GPGGA,180758,3751.4936,N,02349.1123,E,1,04,5.6,384.3,M,34.5,M,,*4D
$GPRMC,180758,A,3751.4936,N,02349.1123,E,9109.2,159.8,060521,5,E,A*30
$GPGGA,180800,3747.8756,N,02353.0000,E,1,04,5.6,134.0,M,34.5,M,,*4C
$GPRMC,180800,A,3747.8756,N,02353.0000,E,8541.7,139.7,060521,5,E,A*3E
$GPGGA,180802,3745.9547,N,02358.0261,E,1,04,5.6,9.7,M,34.5,M,,*49
$GPRMC,180802,A,3745.9547,N,02358.0261,E,7942.4,115.8,060521,5,E,A*31
So figuring out how to pass it through Deepstream might be overcomplicated, given the gps feed gonna be transmitted maybe?
I tried asking Message broker to send GPS - #7 by Amycao
Maybe if to omit the DeepStream it would be less complicated to transfer the stream? Otherwise I will try to add more details to the DeepSteram post maybe someone will figure out how to do it
