When compiling the latest Video SDK using Visual Studio 2013 and CUDA 8+, all the project compile fine.
Upon execution, getting an error of:
The procedure entry point cuvidReconfigureDecoder could not be located in the dynamic library AppEncDec.exe
Which driver you are using? Please refer to ReadMe.txt which lists the minimum driver version that should be installed in your system before you can use the API. Let us know if you are seeing the issue after installing the minimum required driver on your machine.
