so I’m setting up Scale-Out file server on Windows Server 2016 (fully patched for this date). When I use WinOF-2 newer then 1.70 (tried 1.80.50 and 1.80.51) The QoS is not working properly.
I’m using MXC416A-BCAT with firmware 12.21.2010.
I get RDMA to work but “WinOF-2 Port QoS” indicate that incorrect priorities are used and traffic is marked with wrong DSCP values. Also Get-NetAdapterQos indicates some kind of a problem.
My configuration:
Set-NetAdapterAdvancedProperty -Name SMB1 -RegistryKeyword "*JumboPacket" -RegistryValue 4200 Set-NetAdapterAdvancedProperty -Name SMB1 -RegistryKeyword VlanID -RegistryValue "4029" Set-NetQosDcbxSetting -Willing 0 -Confirm:$false Enable-NetQosFlowControl -Priority 4,5 Disable-NetQosFlowControl -Priority 0,1,2,3,6,7 New-NetQosTrafficClass "SMB" -Priority 5 -BandwidthPercentage 95 -Algorithm ETS New-NetQosPolicy "SMBD" -NetDirectPortMatchCondition 445 -PriorityValue8021Action 5 -Confirm:$false -Precedence 255 -NetworkProfile All New-NetQosPolicy "SMB" -SMB -PriorityValue8021Action 5 -DSCPAction 42 -Confirm:$false -Precedence 255 -NetworkProfile All New-NetQosPolicy "DEFAULT" -Default -PriorityValue8021Action 5 -DSCPAction 42 -Confirm:$false -Precedence 240 -NetworkProfile All New-NetQosPolicy "CLUSTER" -Cluster -PriorityValue8021Action 7 -DSCPAction 56 -Confirm:$false -Precedence 240 -NetworkProfile All New-NetQosPolicy "TCP" -IPProtocolMatchCondition TCP -PriorityValue8021Action 0 -DSCPAction 0 -Confirm:$false -Precedence 10 -NetworkProfile All New-NetQosPolicy "UDP" -IPProtocolMatchCondition UDP -PriorityValue8021Action 0 -DSCPAction 0 -Confirm:$false -Precedence 10 -NetworkProfile All Enable-NetAdapterQos -Name SMB1 Set-NetAdapterQos -Name SMB1 -Enabled $true $m=HKLM:\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0001 new-itemProperty -Path $m -Name "RxTrustedState" -PropertyType "String" -Value "2" -Force new-itemProperty -Path $m -Name "TxUntagPriorityTag" -PropertyType "String" -Value "1" -Force new-itemProperty -Path $m -Name "PriorityToDscpMappingTable_7" -PropertyType "String" -Value "56" -Force new-itemProperty -Path $m -Name "PriorityToDscpMappingTable_5" -PropertyType "String" -Value "42" -Force new-itemProperty -Path $m -Name "PriorityToDscpMappingTable_4" -PropertyType "String" -Value "34" -Force Mlx5Cmd.exe -Qosconfig -Dcqcn -Name SMB1 -Set -DcqcnCnpDscp 58 -DcqcnCnp802pPrio 7 Mlx5Cmd.exe -Qosconfig -Dcqcn -Name SMB1 -Disable Mlx5Cmd.exe -Qosconfig -Dcqcn -Name SMB1 -Enable 4 Mlx5Cmd.exe -Qosconfig -Dcqcn -Name SMB1 -Enable 5 #Mlx5Cmd.exe -Qosconfig -Dcqcn -Name "SMB1" -Set –DcqcnCnpPrioMode 0 #btw. this is not working - Invalid command or flag, Restart-NetAdapter SMB Enable-NetAdapterRDMA SMB1
So I want to see SMB Direct on priority 5 with DSCP 42. However counters indicate priority 3 is used instead of 5.
So I’m checking:
PS C:\Windows\system32> Get-NetAdapterqos SMB1 Name : SMB1 Enabled : True Capabilities : Hardware Current -------- ------- MacSecBypass : NotSupported NotSupported DcbxSupport : IEEE IEEE NumTCs(Max/ETS/PFC) : 1/1/1 1/1/1
This is clearly wrong.
Then I reboot the server. And get the same result.
Then I check QoSPolicy:
PS C:\Windows\system32> Get-NetQosPolicy -PolicyStore "ActiveStore" | select elementname,name,owner,NetworkProfile,Precedence,IPProtocol,Template,PriorityValue,DSCPValue,DSCPAction,NetDirectPort | sort -Descending Precedence,elelementname | ft elementname name owner NetworkProfile Precedence IPProtocol Template PriorityValue DSCPValue DSCPAction ----------- ---- ----- -------------- ---------- ---------- -------- ------------- --------- ---------- livemigration livemigration Group Policy (Machine) All 255 None LiveMigration 4 34 34 smb smb Group Policy (Machine) All 255 None SMB 5 42 42 smbd smbd Group Policy (Machine) All 255 None None 5 -1 -1 cluster cluster Group Policy (Machine) All 240 None Cluster 7 56 56 default default Group Policy (Machine) All 240 None Default 5 42 42 tcp tcp Group Policy (Machine) All 10 TCP None 0 0 0 udp udp Group Policy (Machine) All 10 UDP None 0 0 0
So policy is ok. But traffic is using priority 3 and DSCP 26 - and these values are not configured anywhere!
When I use driver 1.70 priorites are used correctly.
Any one has any ideas what can I do to get priorities working correctly with current driver version ?
